![]() | | #81 | ![]() |
![]() Join Date: Sep 2009 Location: Clinton,NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 11
| Not Ranked : 0 score
__________________ Black Gen 2//DDM 6K HIDS//DDM 3K HIDS Fogs///JBR SSP//Solid Shifter Bushings//TRZ RMM//CorkSport SRI+TIP//RHO Plate// |
![]() | | #82 | ![]() |
| Not Ranked : 0 score No sweat- Delete row 1 - DOn't need the "From" bit, and if that's not there it's easier to do the chart by just selecting the column Select Column E & Column G Insert > Scatter Chart - Scatter with only markers Then back to following the steps as outlined
![]() | | #83 | ![]() |
| Not Ranked : 0 score That worked out great! Now I have the chart up, but now I cant get the chart to show the power curve. I can pick the other trends except that one and exponential.
![]() | | #84 | ![]() |
| Not Ranked : 0 score There are two extra rows at the end/bottom hosing things up- Select the chart, so the data in the columns have the purple & blue box around the data selected for the chart, then scroll to the bottom of the data and you'll see em. Grab the bar and move it up two rows to good data- both data boxes will move at once. Then with the good data selected you can go back & do the trendline again and power will work
![]() | | #85 | ![]() |
| Not Ranked : 0 score You sir are a excel guru!!! Thank you!
| The Following 2 Users Say Thank You to tavio025 For This Useful Post: | rfinkle2 (04-02-2013), TiGraySpeed6 (03-25-2013) |
![]() | | #86 | ![]() |
![]() Join Date: Dec 2010 Location: Humble, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,643
| Not Ranked : 0 score Ok guys and gals, I made an updated template for everyone. It is essentially a complete walkthrough on how to perform what rfinkle has laid out. This should make it easy for even a novice to grasp, understand, and implement the calibration of the MAF based on the line of best fit. I hope this helps some of you!!! @rfinkle2; Mike
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN Last edited by mrmonk7663; 04-01-2013 at 10:51 PM. Reason: Tag |
| The Following 3 Users Say Thank You to mrmonk7663 For This Useful Post: |
![]() | | #87 | ![]() |
![]() Join Date: Nov 2011 Location: Greece-Athens
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 470
| Not Ranked : 0 score Very nice...great help for us the knobs....
__________________ 2008 speed3 True red. Pte 6466 & AWD Mode on !!!! 11.114@131.04 .........GTX3071.....FWD 10.62@136.64............PTE6466.....AWD [SIGPIC][/SIGPIC] |
| The Following User Says Thank You to RE-ACTIONENGSPEED3 For This Useful Post: | mrmonk7663 (04-02-2013) |
![]() | | #88 | ![]() |
![]() Join Date: Jul 2011 Location: Pittsburgh, PA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 12
| Not Ranked : 0 score I have been testing this to see if can get my AFRs more on target, but I had a question from what I've been seeing. It seems every revision I use increases the corrected curve g/s and in turn just keeps increasing the g/s in ATR in each cell. An example is my 5.0v cell was 347 OTS, but after 3 revisions it was sitting at like 408. Is there a point that this will eventually stop increasing the corrected curve? I'm worried this is going to make my OL AFRs go all over the place. If it helps, I have a gen2 which maybe this really isn't effective for with OL maf cals.
__________________ 2013 LSM Mazdaspeed3 Non-Tech Currently Installed: | JBR WidePath 3.5" Intake | JBR Coolant Bypass & EGR Delete | JBR Shift Weight | JBR RMM 88dm | Cobb APV2 | Cobb 3Port EBCS | Ebay Catless DP | Corksport CBE | JBR OCC S2 | HKS SSQV4 | Autotech Internals | NGK Step Colder Plugs | Cobb FMIC | 3-BAR MAP Sensor | DNP Turbo Manifold | ATP GT3076R | Tial 38mm EWG | Next In Line: | Build a motor fund for gofasts | |
![]() | | #89 | ![]() |
In some cases, it can help if you are using the same intake, but have upgraded the turbo and may see voltages much greater than your k04. It is a predicted value / line of best fit given previous logs so if your wot logs are close to your targets, running the equation over and over again will sometimes exaggerate the end value. You should be well below 5v @ wot on the k04 so no worries. | |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | ms3blackmica (04-03-2013), TiGraySpeed6 (04-03-2013) |
![]() | | #90 | ![]() |
| Nishan ![]() Join Date: Apr 2012
Rep Power: 9816 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 13,290
| Not Ranked : 0 score Agreed with above statement ^^^^^ If the curve is off by a good amount, using this method will help you out a lot. If you are already on target and are just trying to do it to "smoothen" things out, it actually will exagerate your MAF curve by a lot.
__________________ www.tunedbynishan.com |
![]() | | #91 | ![]() |
__________________ 2013 LSM Mazdaspeed3 Non-Tech Currently Installed: | JBR WidePath 3.5" Intake | JBR Coolant Bypass & EGR Delete | JBR Shift Weight | JBR RMM 88dm | Cobb APV2 | Cobb 3Port EBCS | Ebay Catless DP | Corksport CBE | JBR OCC S2 | HKS SSQV4 | Autotech Internals | NGK Step Colder Plugs | Cobb FMIC | 3-BAR MAP Sensor | DNP Turbo Manifold | ATP GT3076R | Tial 38mm EWG | Next In Line: | Build a motor fund for gofasts | | |
| The Following User Says Thank You to shane5747 For This Useful Post: | rfinkle2 (04-19-2013) |
![]() | | #92 | ![]() |
| Approved MSF Vendor ![]() ![]() Join Date: Mar 2008 Location: Vancouver, WA
Rep Power: 4731 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,820
| Not Ranked : 0 score Anyone ever think about making a macro in Excel to do this? Would save time if it would auto sort the values and then make a MAF curve for you. At the end you could just copy your original MAF values in and it would auto give you and output. |
| The Following 2 Users Say Thank You to CorkSport For This Useful Post: | ms3blackmica (04-19-2013), rfinkle2 (04-19-2013) |
![]() | | #93 | ![]() |
| Not Ranked : 0 score Enki was working on one. Takes quite a bit of work to interpolate between dynamic values (from data log) and generate the values for the mafv curve points.
| The Following 2 Users Say Thank You to phate For This Useful Post: | ms3blackmica (04-19-2013), rfinkle2 (04-20-2013) |
![]() | | #94 | ![]() |
| Not Ranked : 0 score Its a neat idea Brydon. I prefer to manually set these things up though. P.s. I still use this method now and then and it works every single time. Thanks again Rob.
![]() | | #95 | ![]() |
| Not Ranked : 0 score Thinking about this again. I'm not sure VBA has the capability to grab an equation from a chart. I use vb to control a lot of things, but charts and pivots were a bitch in 2007. Maybe they've added some functionality since I last looked. That would be sweet. But, if it doesn't, that brings us back to generating either an equation or a piecewise correction curve. I do the latter, manually, and it is quick and works really well. But, taking that logic that is in my head and putting it into code is rather difficult. This is where Enki was going with his program, it became extremely complex, lol.
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (04-20-2013) |
![]() | | #96 | ![]() |
![]() Join Date: Nov 2012 Location: Pinehurst, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 624
| Not Ranked : 0 score @rfinkle2; ok so I have a question, and maybe this has already been covered and is just over my head, but how do you calculate Commanded AFR's between rpm breakpoints from your Fuel OL/WOT Commanded EQ table? I'm assuming you interpolate correct? So between 3500 and 4000 rpm, for my commanded AFR as I transition from 11.8 to 11.4 AFR, I just interpolated based on the number of cells I had in my log the commanded values for each point. Is this correct? Does that make sense? Anyone willing to check my work to make sure I didn't f' this up?
__________________ 2006 TGM MS6 Cobb AP w/ SELFtune // Split Second AIC1-V4H // Stratified Guardian Angel // Stratified Boost Dial // ATP GTX3071r IWG // Devils Own Stage 1 WMI // JMF v2 Intake Manifold // 4 x Siemens DEKA IV 60 lph Injectors // Outlaw4shrt In-Tank Fuel Pump Kit w/ 255 lph pump // CP-E CDFP // CP-E SAFEseals // Clutchmasters 350 & flywheel // CX Racing FMIC // HTP 3.5" Intake // 3.5 Bar MAP // Cobb EBCS // Forge BPV v1 // XS Power Exhaust Manifold // M2 Downpipe w/ Highflow Cat // Corksport 80mm CBE // Blackworks Racing VTA OCC // NGK +1's // JBR EGR delete // Speedy 17x7.5 Lite Fin's w/ Hankook Ventus V2 225/50/R17 // TooLateTuning Springs // Bilstein B6 HD Shocks // Whiteline RSB // SPC Adjustable Ball Joints // Airlift 1000 "Drag Bags" // JBR 80 duro RMM // JBR 80 duro TMM // JBR 80 duro PMM // CP-E RDM // Turbine Tech FDM // OEM Spin-On Oil Filter Conversion // Prosport Oil Pressure and Oil Temp Gauge with Oil Filter Adapter Plate, Boost and EGT Gauges // AEM UEGO Wideband O2 & Fuel Pressure Gauges // Block8head MS6 dual 52mm vent pod // Lotek triple 52mm gauge pod // Prosport EVO Single Gauge Pod // Cobb Knob // Corksport LED Kit // Corksport LED Fogs // LED Tails // Audi LED DRL's 2008 MazdaSpeed 3 - R.I.P. 1/3/13 - from ENM 2014 |
![]() | | #97 | ![]() |
| Not Ranked : 0 score It would be much easier to command a baseline of 11.6 if you want extra safeguards by running richer, than going from 11.8 down to 11. 11 is much too rich. 11.6 will be fine....and more than likely 11.8 would be fine as well. The graph looks correct, but I would not use the graph until I picked the AFR I wanted for sure, maf cal manually as close as you can, then use the graph as needed. The graph will make your g/s higher, so you might have to multiply it by a reduced percentage...which will give you a tight curve with a smooth overall g/s transition.
__________________ 2011 Speed3-BT and shit ![]() "There is a war going on for your mind. If you are thinking, you are winning. Resistance is victory. Defeat is impossible. Your weapons are already in hand. Reach within you and find the means by which to gain your freedom. Fight with tools. Your fate,and that of everyone you know, depends on it." TEAM LBN BEERS -- FYCN TEAM MUMFORD -- FYCN |
| The Following 2 Users Say Thank You to mrmonk7663 For This Useful Post: | Outlaw4shrt (04-22-2013), rfinkle2 (04-22-2013) |
![]() | | #98 | ![]() |
Then all I have to do is just change my target as I like. You can taper the AFR richer as you please or whatever it is you are trying to achieve. Once dialed in, the car should hit AFR you command. This will save you ALL of the hassle of trying to interpolate in excel and what not.. 1) Target static rich AFR 2) Adjust MAF 3) Set AFR's the way you want.
__________________ www.tunedbynishan.com | |
| The Following 4 Users Say Thank You to ms3blackmica For This Useful Post: |
![]() | | #99 | ![]() |
| The Following 2 Users Say Thank You to mymps11 For This Useful Post: | mrmonk7663 (08-19-2013), rfinkle2 (08-19-2013) |
![]() | | #100 | ![]() |
![]() Join Date: May 2009 Location: Memphis, IN
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,249
I normally make a long log of all driving conditions and multiple WOT pulls and use all the data collectively for the first revision or two and then go back and tweak just the WOT part of your MAF curve. Shouldn't need much tweaking after doing the prior. Sent from my SCH-I605 using Tapatalk 4
__________________ 2006 MS6 Titanium Grey BSD, Custom 3" SRI, 3" HTP TIP, Custom 2.5" Single Exit Exhaust, Nator Sytle Downpipe, E40 Selftune, AutoTechs, Ghetto Mod'ed Stock BPV, VTCS Delete, IM PnP & AWR RMM3 Tuned with | |
| The Following User Says Thank You to Mfinlay04 For This Useful Post: | rfinkle2 (08-19-2013) |
![]() | | #101 | ![]() |
![]() Join Date: Jan 2012 Location: Central IL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 19,219
Groans: 118
| Not Ranked : 0 score So I am attempting to do this in excel 2013 and cannot get it to paste vertically anyone else have this issue. Or know how to fix it. Been banging my head on it for an hour Sent from my XT1080 using Tapatalk 4
__________________ Damond Built Speed 6 |
| The Following User Says Thank You to Deldran For This Useful Post: | rfinkle2 (10-21-2013) |
![]() | | #102 | ![]() |
| Not Ranked : 0 score If it will past horizontally, do that first. Then highlight, copy, then paste special using the 'transpose' check box (cannot overlap any portion of the horizontal data).
| The Following 3 Users Say Thank You to phate For This Useful Post: |
![]() | | #103 | ![]() |
Groans: 118
| Not Ranked : 0 score Thanks phate Sent from my XT1080 using Tapatalk 4
| The Following User Says Thank You to Deldran For This Useful Post: | phate (10-09-2013) |
![]() | | #104 | ![]() |
| Not Ranked : 0 score If needed there are a couple of other cases earlier in this thread that go into detail with screenshots & such too If it continues to be a problem post the log & we'll get you sorted
![]() | | #105 | ![]() |
![]() Join Date: Jun 2012 Location: Mesa, Arizona
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,244
Code: Public Sub getEquation()
Dim trendData As Chart
Dim strEq As String
Set trendData = Charts(2) '<-- would be the chart name
trendData .SeriesCollection(1).Trendlines(4).DisplayEquation = True
With trendData
strEq = .SeriesCollection(1).Trendlines(4).DataLabel.Text
End With
End Sub you would then parse that and get your x,y values. Completely untested and randomly generated, it may even blow up your computer. I don't have excel on this box, but will test it out later on if no one else gets the gull to.
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! | |
| The Following User Says Thank You to mr.speedy3 For This Useful Post: | phate (10-16-2013) |
![]() | | #106 | ![]() |
Altered your code a bit, but get a subscript out of range error: I tried altering the chart name to reflect the .activate procedure's chart name and it still doesn't work. Not really sure why at this point (might be a pivot chart thing, haven't tried it with a regular chart).
__________________ -06 MS6 -Corn fed 07 MS3 - Sold ![]() www.mazdamotorsports.com <<--Mazda racer support program that is free to join and will save you a ton of money. | |
![]() | | #107 | ![]() |
![]() | | #108 | ![]() |
| Not Ranked : 0 score No template, I just made a quick pivot chart from a data log I had. Threw in RPM as the x-axis and used MAF V for the data (not the correction since this was just a test). Added the trend line and data label from there.
| The Following User Says Thank You to phate For This Useful Post: | rfinkle2 (10-21-2013) |
![]() | | #109 | ![]() |
Minor update, @phate; I recorded a macro, that did this: create a scatter plot select maf voltag (random) as x selecy g/s (random) as y add equation copy equation paste equation end macro Code: ActiveChart.SeriesCollection.NewSeries
ActiveChart.SeriesCollection(1).XValues = "=datalog2!$K$2:$K$55"
ActiveChart.SeriesCollection(1).Values = "=datalog2!$L$2:$L$42"
ActiveChart.SeriesCollection(1).Select
ActiveChart.SeriesCollection(1).Trendlines.Add
ActiveChart.SeriesCollection(1).Trendlines(1).Select
Selection.Type = xlPower
Selection.DisplayEquation = True
ActiveChart.SeriesCollection(1).Trendlines(1).DataLabel.Select
Range("U23").Select
ActiveSheet.Paste
__________________ Fastest GTX3076r, T3 twinscroll, built block, D14 meth spraying gen1 on the internet! Last edited by mr.speedy3; 10-16-2013 at 08:41 PM. | |
![]() | | #110 | ![]() |
| Not Ranked : 0 score So I am almost positive this is what we need: Code: ActiveChart.SeriesCollection(x).Trendlines(1).DataLabel.Select
Range("y").Select
ActiveSheet.Paste
'would vary, most likely 1 though
'y would be the desired location of the cell. I'll give it more though later in the evening if that doesn't work!
| The Following User Says Thank You to mr.speedy3 For This Useful Post: | phate (10-17-2013) |
![]() | | #111 | ![]() |
| The Following 2 Users Say Thank You to phate For This Useful Post: | mr.speedy3 (10-21-2013), rfinkle2 (10-21-2013) |
![]() | | #112 | ![]() |
. So I haven't had much time in between this and tuning lol.
| The Following User Says Thank You to mr.speedy3 For This Useful Post: | rfinkle2 (10-21-2013) |
![]() | | #113 | ![]() |
(Thread Starter) | Not Ranked : 0 score Thanks to you guys mr. Speedy and Phate for taking this to a whole other level. BTW, this does have its place when trying to use the aux fueling kits available now. It is much easier (and more accurate) having excel predict the shape of a fuel curve in voltages not previously seen. LOL. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
![]() | | #114 | ![]() |
Everything I've learned tuning the speeds is helping tune this car; including the MAF correction stuff we're discussing here, lol. But, having a completely open ECU (megasquirt III) is a real eye opener in terms of what we can and cannot do with the speeds. Some things I greatly wish we had, and others I wish we could port over to the MSIII, haha.
| The Following 5 Users Say Thank You to phate For This Useful Post: | atvfreek (10-21-2013), mr.speedy3 (10-21-2013), ms3blackmica (10-21-2013), rfinkle2 (10-21-2013), TiGraySpeed6 (10-21-2013) |
![]() | | #115 | ![]() |
(Thread Starter) | Not Ranked : 0 score So jealous of those build programs and competitions... I had a friend who built some of one of those cars and it seems like such a great experience. What engine is in that car Clint? A motorcycle engine? |
| The Following 2 Users Say Thank You to rfinkle2 For This Useful Post: | ms3blackmica (10-21-2013), phate (10-21-2013) |
![]() | | #116 | ![]() |
| Not Ranked : 0 score It's a Kawasaki ZX-6R engine. 600cc 4 cylinder (makes ~80hp with a 20mm intake restrictor). It doesn't really wake up until ~8500 rpm, and we're revving to 13k. Hoping to get some solid tuning time in the next two weeks to build power in the mid range and get more throttle response out of it.
![]() | | #117 | ![]() |
![]() Join Date: Jun 2008 Location: Tucson, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 752
Groaned at 9 Times in 7 Posts
| Not Ranked : 0 score Edit: I'll post this in my thread... Not to sidetrack this one.
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 Last edited by udntknw; 10-21-2013 at 08:16 PM. |
![]() | | #118 | ![]() |
| Not Ranked : 0 score ![]()
' Not sure where the "Your mother"emoji came from... but I'll keep it .
![]() | | #119 | ![]() |
![]() ![]() Join Date: Mar 2008 Location: Foothill Ranch, CA
Rep Power: 2705 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 766
| Not Ranked : 0 score mmm dat curve i just discovered this thread, and tried it out using the template... wow
__________________ 2017 Daytona 392 SOLD//2014 Porsche 981 Cayman S 3.4L STOLEN//2015 BMW S1000R SOLD//2014 Mustang GT// Brembos - Bob's Can - SCT X4 - MGW - GT500 Quad-tip Axle back - Vorshlag Street Pro - Ford K Springs - BMR PHB 2007 MS6 w/ Cheez // COBB V3 AP // Corksport CTS4 // HKS Ignition // SURE ID300 MAF // COBB TIP // CXRacing FMIC // PTP BSD // PTP Windage Tray // PTP TIG // KMD V2.1 CDFP Internals // HD Coil Packs // Corksport DP // TurboXS RP // CP-e 3" Single Cat-back // Bilstein Shocks & H&R Springs // DSS Axle // TSW Interlagos 19x8 +35 // 235/35 Rubber // Defi Red Racer // Block8head Defrost Pod // DDM 3k Fogs & 6k Lowbeams // Custom iPod Integration Hackjob // |
![]() | | #120 | ![]() |
| Not Ranked : 0 score I've used this on my cp-e cold air intake and was pretty well spot on. Now that I'm using the JBR 3.5, I'm getting consistent lean spots. Is that normal for the MAF to not be linear, or could something be throwing it off? Sent from my ADR6300 using Tapatalk 2
__________________ Wiseco OTS pistons, Eagle Rods, ARP mainstuds, JBR BSD w/ baffle,GT2871R, 51R battery, JBR V1 3.5 aluminum widepath, CP-e Catted DP, custom 3in cat-back, Treadstone TR8L core w/ COBB piping, Damond OCC, HKS SSQV3 (full VTA), autotech HPFP internals, Self tune 33% E85, Grimmspeed EBCS (3port), JBR TM & PM, TRZ Rmm, COBB short shifter, COBB Front/Rear swaybars, Koni STR.T struts, AXIS Circuits 18x8.5 45offset **Old Motor** Best 1/4 -13.19 Stock Turbo/ street tires Best trap speed - 112mph **New Motor** Best 1/4 - 13.35 Stock turbo/ street tires Best trap speed - 112.5 |
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f426/using-excel-dial-your-maf-curve-meth-137570/ | ||||
| Self-tuning adventure! - Mazda3 Forums : The #1 Mazda 3 Forum | This thread | Refback | 10-24-2014 03:02 AM | |
| Meth and MAF cal | This thread | Pingback | 08-02-2013 05:40 AM | |
| Hard cut/jerking + other issues - Page 2 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-18-2013 11:21 AM | |
| WOT MAF/AFR correction worksheet - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Pingback | 02-10-2013 03:25 PM | |
| Beaner time! - Page 6 - Mazda 6 Forums : Mazda 6 Forum / Mazda Atenza Forum | This thread | Refback | 02-10-2013 08:34 AM | |
| Trying to dial in this tune | Guerra88 | 2010 MS3 - ECU Computer Tuning | 23 | 05-24-2012 10:50 PM |
| Help me dial in my 3076. :) | dsmluck | MazdaSpeed 3/6 - ECU Computer Tuning | 63 | 09-04-2011 09:45 AM |
| dial in on proposed thought of egr delete... | burntmushu | MazdaSpeed 6 - Engine, Transmission & Driveline | 10 | 08-09-2011 09:01 PM |
| cpe stand back users and meth | phillyb | MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection | 14 | 04-24-2009 12:06 PM |
