 Old 11-20-2014, 04:39 PM   #1
Steve@VersaTune's Avatar
Posts: 432   (View Stats)
Default VersaTuner 1.9.3 Released
The update includes these changes:
All Platforms
The duration of DTC clearing has been significantly reduced.
Mazdaspeed6/Mazda6 MPS, Mazdaspeed3/Mazda3 MPS, Mazda CX-7
Added a new table "Volumetric Efficiency - VVT Modifier" in Tune Editor. This table contains the volumetric efficiency adjustment for the valve timing at each RPM and load point. The result of this table lookup is multiplied by the valve timing and is then added to the base volumetric efficiency lookup.
2nd generation Mazdaspeed3/Mazda3 MPS
Added gear ratio tables in Tune Editor.
Bug fixes
Fixed a bug in Gen 1 Mazdaspeed6/Mazda6 MPS Mazdaspeed3/Mazda3 MPS that caused MegaSpool ignition retard to be set to zero.
Fixed a bug in Tune editor that informed about unsaved changes after the Save As command.
Steve
Lead Tuner
The Following 5 Users Say Thank You to Steve@VersaTune For This Useful Post:
HawkeyeGeoff (11-20-2014), phate (11-20-2014), Polish_Eagle (11-21-2014), SpeedRebirth (11-20-2014), TiGraySpeed6 (11-21-2014)
VersaTuner 1.9.3 Released Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 0 11-20-2014 04:38 PM
VersaTuner v1.9 Released! Steve@VersaTune 2010 MS3 - ECU Computer Tuning 1 11-04-2014 07:43 PM
VersaTuner 1.8.5 Released Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 1 03-21-2013 09:45 AM
VersaTuner 1.7 Released! Steve@VersaTune MazdaSpeed 3/6 - ECU Computer Tuning 8 05-03-2012 07:20 PM
VersaTuner 1.7 Released! Ugnius@VersaTune VersaTune 0 04-25-2012 11:39 PM
Page generated in 0.22484 seconds with 20 queries
