 Old 09-05-2013, 10:11 PM   #1
Ace99899's Avatar
Posts: 439   (View Stats)
Ace99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond reputeAce99899 has a reputation beyond repute
Groaned at 36 Times in 20 Posts
Default Weird AFR's
It had been a while since i had done a first gear pull so I did a 10 mph roll and stood on the pedal. AFR's went to 8.8's and bucked real hard, kind of freaked out I decided to do another real quick. The second time it didn't buck at all but still saw 8's. After that I tried a second gear pull and I had 11.4's and 11.7's. I don't understand so I'v done a log. For the log I did a first gear pull, it bucks and I let off until the RPM's come back down some then threw it into second and hit the gas so you can see the nice AFR's. I'm not sure what would be causing this.
datalog38.csv
Ace99899 is offline   Reply With Quote
 Old 09-05-2013, 10:31 PM   #2
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
SWAS
Nator is what it does.
The Following 3 Users Say Thank You to kritz For This Useful Post:
CJM (09-09-2013), rfinkle2 (09-09-2013), silvapain (09-09-2013)
 Old 09-09-2013, 12:48 PM   #3
metalgear386's Avatar
Posts: 33   (View Stats)
metalgear386 is a glorious beacon of lightmetalgear386 is a glorious beacon of lightmetalgear386 is a glorious beacon of lightmetalgear386 is a glorious beacon of lightmetalgear386 is a glorious beacon of lightmetalgear386 is a glorious beacon of light
Attachment 126078
Your LTFTs are in the 10s, thats kinda bad. Need a MAF calibration if possible.
Hold the traction control button for 10 seconds and give it another shot after the car is fully warmed up.
Do you have any mods?
Late 2013 Silver MS3
Mods: Cobb AP.
Future mods: Autotech Internals, Corksport Stage 2 Intake and TIP, Gutted DP.
metalgear386 is offline   Reply With Quote
The Following User Says Thank You to metalgear386 For This Useful Post:
Brennan (09-09-2013)
 Old 09-09-2013, 01:16 PM   #4
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
Why are we looking at 1st gear pulls again?
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
Agent_Orange (09-09-2013), SLOWHATCH (09-09-2013)
 Old 09-09-2013, 04:11 PM   #5
Ace99899's Avatar
Bc it's the only gear that's fucking up. It's like it fuel cuts in first
Mods are Sri tip internals 3inch Catless dp tp with cut out and stag 2 tune on ap
 Old 09-09-2013, 04:36 PM   #6
JeffroMS3's Avatar
Posts: 75   (View Stats)
JeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud ofJeffroMS3 has much to be proud of
My car did the same thing your talking about, Did a Maf Cal and it fixxed it. Not saying thats whats wrong with yours but just throwing it out there
2013 Mazdaspeed 3 LSM
2007 Mazdaspeed 3 SSM -GONE-
JeffroMS3 is offline   Reply With Quote
 Old 09-09-2013, 04:44 PM   #7
himurax13's Avatar
Posts: 4,585   (View Stats)
Groans: 255
Wait, you are running a Catless DP with an OTS map?
Pickles Tune in progress
 Old 09-09-2013, 04:55 PM   #8
Ace99899's Avatar
Yea, I have been for a while now. the ots map is slightly moddifed, as in just the wastegate tables.
 Old 09-09-2013, 05:18 PM   #9
Brennan's Avatar
Posts: 220   (View Stats)
Brennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the worldBrennan is the leader of the world
This + MAF cal. Report back.
It's probably SWAS.
'10 Velocity Red Mica MS3 with Tech
Performance: JBR SSP + Bushings, JBR 80a RMM, Ebay TP, CS SRI + TIP, AP (Self Tooned @18.5 PSI), MD OCC, CP-e HPFP, ITV22s, EGR delete, Forge V1 BPV, Ford Motorcraft Tranny Fluid
Other: DDM 6000k HID Lows, CS LED Fogs, CS Interior/Plate LEDs, RallyArmor Flaps, 34/17 Tint, Heavy Knob, Rockford Fosgate PRIME R500-1 Amp + Alpine SWR1242D 12" Sub + PAC AOEM-MAZ2
Future/wishlist: Driver mod, CS TMIC (on the way!), CS turbo-back, H&R Coilovers
Check out the Gen2 "ECU Computer Tuning" sticky on software that will trim/highlight your AP datalogs!
Brennan is offline   Reply With Quote
 Old 09-09-2013, 05:31 PM   #10
Ace99899's Avatar
just tried stomping first again with swas off and got the same results. I guess I'll do a maf cal and see if that fixes it
 Old 09-09-2013, 05:36 PM   #11
chaser27's Avatar
Groans: 42
Just FYI. This seems to be a topic that we don't all agree on, but unless you physically disable SWAS, it is still engaged. Holding the button only locks traction control off. (In my experience)
Sent from the lead
ECU: self-tuned
The Following User Says Thank You to chaser27 For This Useful Post:
Brennan (09-10-2013)
 Old 09-09-2013, 07:38 PM   #12
Ace99899's Avatar
It just seems weird that it would just now start happening. I also just tried different tunes and it still does it. I had a extremely small vacuum leak, so i fixed that...still does it. I also notice that i have never reached peak boost of 18.5 pounds. I have before but only because i modified the waste-gate tables to do so(just made boost come on sooner) I haven't done a maf cal yet because I'm afraid ill fuck it up(its what i do best) but i guess ill just have to man up and try and understand this.
 Old 09-09-2013, 07:46 PM   #13
kritz's Avatar
Groans: 95
Ambient air temperatures are dropping so that may enter the equation here.
 Old 09-09-2013, 08:40 PM   #14
JeffroMS3's Avatar
The Maf Cal is not too hard if you just follow the videos on here in the stickies section, I was worried to do one too at first, but I just went for it and im glad that i did
 Old 09-09-2013, 08:48 PM   #15
NCspecV81's Avatar
Posts: 2,867   (View Stats)
Attachment 126078
Here you go. http://www.mazdaspeedforum.org/forum/foru...nigans-153649/
cliff notes; hold the dsc button for approximately 7 seconds after you crank the car (after releasing I usually press it again to make sure it stays on instead of cutting off). try another first gear pull.
 Old 09-10-2013, 05:31 AM   #16
Mistersix's Avatar
Posts: 2,585   (View Stats)
Learning to calibrate the maf is the first thing anyone who wishes to tune should learn. Its some simple math and common sense, a few revisions and its good. At first it took me many revisions now a days i can do it in 2 maybe 3. And there's some tricks in excel that pretty much do it for you.
If it seems like to much, or think you might fuck it up as you posted just get an e-tune from one or the tuners on here. It's money well spent.
The Following 2 Users Say Thank You to Mistersix For This Useful Post:
Ace99899 (09-10-2013), Brennan (09-10-2013)
 Old 09-10-2013, 12:33 PM   #17
Ace99899's Avatar
It's not that I don't think I could do it, I can follow the video. But I don't want to do something I dont understand. I wanna know why I'm having to what it is that I'm doing so I can not only do the maf cal but understand it as well. I guess I'll just do an etune, iv been wanting one anyway
 Old 09-10-2013, 05:11 PM   #18
Mistersix's Avatar
Its definitely worth the money. I've been studying tuning for almost 3 yrs now and i've got it down and made huge improvements. With a good tuner, they'll have you running real good in a much, much shorter amount of time. That itself is worth the money.
 Old 09-10-2013, 09:24 PM   #19
Ace99899's Avatar
Yea it's something im ready to do now. I did just now go ahead and try the closed loop maf cal because imo it looked the easiest. So far so good, just made my second correction.
Weird Anomalies Ray Danger 2020 2010 MS3 - ECU Computer Tuning 9 06-10-2012 05:31 PM
weird phillyb Website Help/Feedback 11 12-19-2008 06:21 PM
Page generated in 0.39029 seconds with 29 queries
