  • 1 Post By atvfreek
 Old 06-02-2012, 05:54 PM   #1
DarkPasseng3r's Avatar
Posts: 165   (View Stats)
DarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond reputeDarkPasseng3r has a reputation beyond repute
Default '11 motor/tranny into '10 chassis
Pardon my naive question but I'm just really interested in a straightforward answer.
I blew my motor in my 2010 MS3 on my birthday about a week ago, and of course it will not be covered under warranty. Luckily, I've found a motor from a 2011 MS3 that only has 300ish miles on it. My plan it to drop this motor and transmission into my 2010...
My question is in regards to the ECM, TCM... will the 2010 ECM and TCM work with the 2011? Also, are there any known revisions about the motor/tranny in the 2011?
2010 Speed 3
JBR RMM|Shifter Bushings//CS SRI|TIP|Skidplate//Cobb AP//UR DP|TP//Autotech Internals//Falken RT-5//C-Clamp
321HP/436TQ 3gal E85 (Self-tune in progress)
DarkPasseng3r is offline   Reply With Quote
 Old 06-02-2012, 05:59 PM   #2
xtasy's Avatar
Posts: 685   (View Stats)
xtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the worldxtasy is the leader of the world
Groaned at 6 Times in 4 Posts
I would call Mazda first and check if the part numbers are the same.
Mazdaspeed3 E85 ~ Sold 333/383
Mazdaspeed6 #10018 TiGrey
Forged Internals, PTE5858.
2015' Freektuned on 93Octane 322/337 (stock top mount and BPV)
2016' Freektuned on e85/93 480/444 (maxed out 3bar map sensor)
2017' Freektuned on e85/93 525/497 (maxed out pte5858 @ 35/36psi & fueling)
Mazda CX-5 AWD Daily
xtasy is offline   Reply With Quote
 Old 06-02-2012, 06:08 PM   #3
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
Moar details on blown motor. Circumstances? Etc
 Old 06-02-2012, 06:12 PM   #4
Blown motor - rod through the block. Happened while cruising 2700-2900k @60mph in 6th gear. Knock was .1 when it happened.
2010 Speed 3
 Old 06-02-2012, 08:16 PM   #5
Steven's Avatar
Posts: 634   (View Stats)
Steven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the worldSteven is the leader of the world
Why wouldnt the warranty cover it?
2012 Mazdaspeed3 w/tech
Electronics: Cobb AP - Ultragauge - CS EBCS - Bosch 3 Bar
Engine: Autotech HPFP - Sure Aeros - Sure Return - HTP TIP - CS BPV - CS DP + RP - NGK 1 Step Colder Plugs
Steven is offline   Reply With Quote
 Old 06-02-2012, 08:47 PM   #6
manila's Avatar
Posts: 1,767   (View Stats)
I'm really interested on how you blew your motor. That's some massive torque you got on that tune. Typo?
Why not just stock out and flash the OEM map?
You can always just try that route and blame Mazda for your mess-up.
'12 MS3 Black Mica w/ Tech
 Old 06-02-2012, 08:48 PM   #7
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
2011 engine/tranny is same as 2010.
not sure about late late 2011 when they transitioned into 2012 tho...
cesaros is offline   Reply With Quote
 Old 06-02-2012, 08:58 PM   #8
akbrazil's Avatar
Posts: 287   (View Stats)
akbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond repute
I'm also interested to know about how the engine blew.
Full details please
MODS: BNR STAGE 3 Turbo - CP-E Turbo Inlet - CP-E Cold Air Intake - Forge BPV - Street Unit Silicone Inlet & Outlet Hoses - UR Catted Down Pipe - UR Test Pipe - ETS Top Mount Intercooler - COBB AP (WOT-Tune) - KMD Internals - Grimmspeed EBC - HAWK HPS Front Pads - JB dog bone rear mount - NGK (1 step colder plugs) - DDM HID (Headlights & Fogs)
akbrazil is offline   Reply With Quote
 Old 06-02-2012, 09:03 PM   #9
InFeXIoN's Avatar
Posts: 1,159   (View Stats)
InFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the worldInFeXIoN is the leader of the world
Groaned at 42 Times in 15 Posts
He was playing mad scientist in atr playing with stuff ye shouldn't n then compounding driving hard over the course of the time the damage was done then kaboom.
GTX3071R EWG, DNP Tubular Manifold, SSP Ported/VTCS deleted intake manifold, DCR VVT Actuator, CP-E FMIC, Cobb AP, JBR 3.5" WP Intake ||| JBR 80 Duro RMM, JBR 80 Duro PSMM ||| CNT Racing Catless full 3" DP/TP, Speed Daddy 3" CBE ||| AEM Water/Methanol Kit, Autotech FP Internals, PTP Inj Seals, Synapse Engineering Bypass Valve, Matt Jackson map sensor harness, 3 Bar map sensor, Grimmspeed 3-port EBCS, NGK 1 Step Colder Plugs ||| Sure AGS 621G, Sure Shortcut, JBR Solid Base Bushings and Weight ||| AMR Engineering Coilovers, JBR Rear Sway, JBR Rear Camber Arms, XXR 527 18x8.75 +35 Chromium Black ||| CP-E Tow Plate, Rotella T6, FoMoCo XT-M5-QS, JBR OCC, JBR EGR Delete, JBR TB Gasket, JBR TIG and Coolant Bypass, EBC Redstuff.
Build Complete!!!!
InFeXIoN is offline   Reply With Quote
 Old 06-02-2012, 09:04 PM   #10
snailD's Avatar
Posts: 3,039   (View Stats)
Well it was my belief that Mazda has fixed the highway boom for the 2010 plus, aparantly not. How do u know knock was .1? Were u logging? Monitoring and afte it happend all you saw was a .1 for max on the ap? Why won't Mazda cover it for you? Did u not stock out? Please update us with some details
 Old 06-02-2012, 09:24 PM   #11
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
well his sig does say self tune. maybe he fucked up big time.
anyways, i think it might work but then again dont quote me.
@rfinkle2 @atvfreek
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following User Says Thank You to rghispanic88 For This Useful Post:
atvfreek (06-03-2012)
 Old 06-02-2012, 09:31 PM   #12
kritz's Avatar
Posts: 7,290   (View Stats)
Groans: 95
I don't know why it vented the block but would guess timing was a little aggressive. Are those numbers (HP and TQ) from a dyno or VD? Stock it out bud!
Nator is what it does.
 Old 06-02-2012, 10:16 PM   #13
GunGuru727's Avatar
Posts: 3,486   (View Stats)
GunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the worldGunGuru727 is the leader of the world
Groans: 38
Groaned at 20 Times in 14 Posts
You were cruising or did you punch it at 2700 while cruising?
Me confuzzzzzed
FreekTuned 2006 CWP MazdaSpeed6
ATP EWG GTX3076r - HTP 3" Intake System - CPE Single Exit Exhaust
ATP Catless Down Pipe - CPE Differential Mount - CPE Top Mount Intercooler
JBR 80D Trilogy Mount Package - Grimmspeed EBCS Autotech Internals
Bosch 3 Bar Map Sensor - Bit Wise Plug n Play - GFB Hybrid BOV
Bilstein Struts - H&R Sport Lowering Springs - Cobb v3 - e85
Granite State Dyno 4/3/15: 363hp/370trq
2013 Plasma Blue Subaru STI Hatch
E85 FreekTune - Full Bolt-ons
5/14/14 - 12.4@110
2010 NASA Space Shuttle Silver GenPu
E85 FreekTune
EWG GTX3071r: 401HP/386TRQ
K04: 323HP/TachFail SAE
GunGuru727 is offline   Reply With Quote
 Old 06-03-2012, 02:41 AM   #14
Me confuzzzzzed
I was only cruising...Just normal driving. Wasnt trying to punch it at all.
I've already been dealing with Mazda. They will not cover anything. Everything is out of my pocket.
My tune is aggressive. Although those numbers come from VD, I was running some very aggressive timing. I was unaware that 320ish ft lb was probably the most reliable for a daily driver with stock engine internals.
2010 Speed 3
 Old 06-03-2012, 04:52 AM   #15
Groans: 819
Your still unaware of what is ok for a daily driver on stock internals
melbaro (06-03-2012)
 Old 06-03-2012, 07:29 AM   #16
2010's ecu is different than 2011 and 2012, and there may be small transmission changes from 2011-2012.
Sorry to hear about your motor.
The rods were likely already compromised from being beyond MBT and finally let go during casual driving.
Where you tuning off of the knock sensor?
 Old 06-03-2012, 09:47 AM   #17
snailD's Avatar
We're u dealing with Mazda while you were modded? Can u answer my previous questions on how u saw knock of .1?
 Old 06-03-2012, 10:11 AM   #18
@rfinkle2 - yes, I was tuning off the knock sensor.
@snailD - I usually have the knock screen up on my AP when I am driving. At this time, I happen to be on that screen because it is able to log any peaks. That was the peak at the time of the occurrence. And yes, I was dealing with Mazda while I was modded. But regardless of if I was modded or not, they are easily able to check into the computer to see if any computer modifications were made.
Would you clarify it for everyone just in case you have that information?
2010 Speed 3
Last edited by DarkPasseng3r; 06-03-2012 at 10:11 AM. Reason: MSF Database - Automerged Doublepost
The Following User Says Thank You to DarkPasseng3r For This Useful Post:
rfinkle2 (06-03-2012)
 Old 06-03-2012, 11:32 AM   #19
But regardless of if I was modded or not, they are easily able to check into the computer to see if any computer changes were made
no they aren't
 Old 06-03-2012, 11:41 AM   #20
dantes5823's Avatar
Posts: 6,576   (View Stats)
Yes they are. Once they plug in with their comp they can see every little shit you did. But they have to look for it. So if a tech sees your fully bolted and thinks hmm lets take a look, he'll find it.
As for timing, phate has a thread on here with dyno proven MBT numbers. Thank god i found it in time cause i was literally in the middle of a revision and when i checked i was passing it, with no knock.
 Old 06-03-2012, 12:33 PM   #21
Steven's Avatar
From what Ive read somehwere on here our ECU's dont have KAM (Keep alive memory). Uninstalling the AP and disconnecting the batt should leave no trace of the AP, but the tech inspecting your car might see only a few key cycles. Just come up with a bs excuse like you thought it would fix your problem.
 Old 06-03-2012, 05:56 PM   #22
Qft
 Old 06-03-2012, 06:18 PM   #23
backward_0's Avatar
Posts: 773   (View Stats)
backward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the worldbackward_0 is the leader of the world
If they can tell i have flashed my ECU, COBB is lying. I think Mazda are the proven liars in my experience.
2013 WRX Stock as Fuck.
1997 Eclipse GSX
The Red Rocket, 2011 MS3 Some other bastards problem now.
backward_0 is offline   Reply With Quote
The Following User Says Thank You to backward_0 For This Useful Post:
Easter Bunny (06-04-2012)
 Old 06-03-2012, 06:32 PM   #24
atvfreek's Avatar
Posts: 7,787   (View Stats)
2011 motor and trans will work. There is no reason to swap a 2011 PCM into your car, so just use your stock one. If you were to try and swap PCM's your car wouldn't start, due to the PATS system and incorrect VIN ID.
P.S. I am a tech and we wouldn't check for codes for a hole in the block. Unmarry the AP and stock out. Even if they did check codes, just say your car wouldn't start so you disconnected the battery and re connected. Play dumb. Take your chances and send it to a dealer that you haven't been to. Worse case scenario they decline te repair.
2010 Speed3-PTE5858
Freek built/Freektuned
510hp420tq
11.321@129.93
The Following 4 Users Say Thank You to atvfreek For This Useful Post:
DarkPasseng3r (06-04-2012), Easter Bunny (06-04-2012), JTMS3 (06-05-2012), rfinkle2 (06-04-2012)
 Old 06-04-2012, 12:20 PM   #25
You mind posting the link for everyone? I've never seen it (obviously), so I wouldn't know what to search for.
2010 Speed 3
 Old 06-04-2012, 12:23 PM   #26
dantes5823's Avatar
I'll Try and find it.
http://www.mazdaspeedforum.org/forum/forum/f567/e85-e85-mix-ignition-timing-database-100743/
The Following User Says Thank You to dantes5823 For This Useful Post:
 Old 06-04-2012, 12:29 PM   #27
Considering I've already been declined for warranty because I've already been to a dealership, and Mazda has the files and pictures on me (and most likely VIN), do you think that would still matter to take it to another dealership after being stocked out and playing out my story a little better?
2010 Speed 3
 Old 06-04-2012, 12:37 PM   #28
atvfreek's Avatar
If you had your car at a dealership already and a repair order was written, then you are screwed. But if you only talked to them over the phone. Then the next dealership will have no clue.
2010 Speed3-PTE5858
510hp420tq
11.321@129.93
DarkPasseng3r (06-05-2012)
 Old 06-04-2012, 12:39 PM   #29
dantes5823's Avatar
The E85 and E85 Mix *Ignition Timing* Database
 Old 06-04-2012, 12:45 PM   #30
More important than the link is that Phate and DJ suggested that because of the effective octane of e85 in direct injection, you can't tune from feedback of the knock sensor because you may actually pass MBT without any knock.
I'll link to the thread and tbh, to be VERY safe, would use an additional margin of safety beyond what is listed as known good ignition values for e85.
I.e. I would stay a few degrees below those posted in the e85 mbt thread for safety.
I'm really sorry to hear this man. I hope you don't take my post as rubbing it in. I just hope that when you get things back together, you have the info available to you.
Edit: Dante posted the same link above...
dantes5823 (06-04-2012), DarkPasseng3r (06-05-2012)
 Old 06-04-2012, 12:58 PM   #31
dantes5823's Avatar
Yea that's pretty much what i did. More so at lower rpm. I think I went like 1 or 2 lower everywhere else. I was in the middle of a revision with timing 1 or 2 over those numbers when Rob pm'd me. And like expected I wasn't getting any knock.
 Old 06-05-2012, 09:44 AM   #32
The woes of being misinformed. Thanks for the help guys. On the bright side, all I'll need is to build a short block and I'll have a second motor. I just bought the '11 motor yesterday, and will be dropping it in sometimes this week. Gonna rebuild the old motor as bulletproof as budget allows and maybe find me an rx7 or miata and do something different.
2010 Speed 3
Mid chassis brace dimensions supertubesocks Mazdaspeed3/6 General Discussion 1 04-01-2012 10:19 AM
Chassis and Suspension Q's SpeedSixxx MazdaSpeed 3/6 - Suspension & Brakes 26 03-30-2012 03:25 PM
Chassis Thud in Reverse???? John F 2010 MS3 - Troubleshoot/Diagnostics 14 01-20-2010 06:18 PM
Page generated in 0.49867 seconds with 36 queries
