 Old 05-29-2011, 10:12 AM   #1
forbidden doughnut's Avatar
Posts: 41   (View Stats)
forbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of lightforbidden doughnut is a glorious beacon of light
Default 15K mile tune up done...have questions.
I just did a tune up on the car (as title states).
Installed K&N drop in, SU boost tubes, Denso ITV20 plugs.
I noticed the car runs a lot smoother and power delivery seems more linear.
I gapped the plugs to .028...the ones I took out were at about.024...out of spec from the factory. Is that typical?
I noticed a very light coating of oil on the inside of the OE boost tubes. Is this normal or do I have things breaking already?
Also, the Boost drop @ WOT seems more pronounced starting at about 5800 RPMS. Is this normal for the car or is it pulling timing or losing FP? I don't have a device to let me see exactly what the FP or timing is looking like but if that is normal I am not going to worry about it at the moment.
Also...as I get closer to out of warranty what is the most efficient way to decrease the boost drop @ WOT @ high RPMs?
Thanks.
forbidden doughnut is offline   Reply With Quote
 Old 05-29-2011, 10:19 AM   #2
BlueDmnSpeed's Avatar
Posts: 1,129   (View Stats)
BlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the worldBlueDmnSpeed is the leader of the world
Groaned at 32 Times in 11 Posts
the fix for the oil in the boost tubes is an Oil Catch Cans. our cars like to put a little bit of oil through the intake tract. a matt damonds oil catch can will prevent that. also donate and then invest in a cobb ap so you can monitor your fuel trims, knock, etc..
RichTuned
Ultimate Racing DP V2 flange\35W 6000k DDM HID's\HKS SSQV3 VTA\GTX2867R\Tanabe STB\HTP 3.5" intake\PTP HPFP\UR FMIC\Ultimate Racing turbo-back exhaust\JBR RSB\JBR 80Duro Trilogy mounts\Cobb AP v3\Stage 2\22.5PSI \Sonic Tuning Coilovers\TWM full replacement shifter and SSP\PnP Intake Manifold/CP-e EWG Exhaust Manifold/Tial 44mm EWG
11/10/2012 NATOR DC DYNO day 304Whp/356 FT lbs Tqe Uncorrected
4/13/2013 Mega NATOR Meat Dyno Day 300WHP/ 344ft lbs/wtqe Corrected
BlueDmnSpeed is offline   Reply With Quote
The Following 3 Users Say Thank You to BlueDmnSpeed For This Useful Post:
forbidden doughnut (05-29-2011), JS + MS3 (05-29-2011), Raider (05-29-2011)
 Old 05-29-2011, 11:48 AM   #3
Fuck sushi rolls
rodrigo's Avatar
Posts: 18,719   (View Stats)
Groans: 356
if i didnt see your join date i would say troll.
cuz all the q s u asked are about as nubbish as they get.
unsubbed
 Old 05-29-2011, 11:50 AM   #4
unsubbed
you forgot to remind me to donate
 Old 07-08-2011, 07:47 PM   #5
tddvrrn's Avatar
Posts: 2,571   (View Stats)
Groans: 103
hey there. most tunes drop boost toward redline to protect the turbo.. i don't know if the stock tune does, but if you read a bit, you'll find that most tunes are designed to taper boost off at around 6k rpm. do some more research if you like, but i think it's normal. the best way to keep more boost high up is a tune with a tuning device, either ht, cobb ap or standback.
edit: why the fuck did this reply get groaned? because it was an accurate answer to a noob question? yanahdi, lick my choad!
The Following 2 Users Say Thank You to tddvrrn For This Useful Post:
forbidden doughnut (07-27-2011), Yanahdi (07-27-2011)
 Old 07-27-2011, 11:02 AM   #6
Thanks for the helpful response. My car certainly has an access port in its future, it sounds like that will help.
 Old 07-27-2011, 11:10 AM   #7
Yanahdi's Avatar
Posts: 198   (View Stats)
Yanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the worldYanahdi is the leader of the world
Wierd. Not sure how that happened. Must've missed and hit groan when I meant to hit thanks, phone browsing FTL. I'll fix it.
Yanahdi is offline   Reply With Quote
 Old 07-27-2011, 01:03 PM   #8
tddvrrn's Avatar
Groans: 103
thanks. i was less upset and more curious as to why i was groaned... love the avatar btw. sikhs going deep!
 Old 07-27-2011, 07:30 PM   #9
Yanahdi's Avatar
Thanks, I'm not even Indian but I like the Sikh style.
Questions about HT tune Speeed3 MazdaSpeed 3/6 - ECU Computer Tuning 5 12-11-2010 02:39 PM
Anyone fine tune there shifter and tune out a second gear grind? stevessvt MazdaSpeed 3 - Engine, Transmission & Driveline 15 10-21-2009 12:06 AM
couple quick questions before i tune my car Wenis Prinkle
Cobb ATR Support
9 08-09-2009 12:11 PM
Page generated in 0.29124 seconds with 24 queries
