 Old 12-23-2013, 08:34 PM   #1
someguy's Avatar
Posts: 914   (View Stats)
Default Am I joining the clutch failure group?
5th and 6th gear acting up today, second time it's happened. First time was in 4th gear and the road might have been a bit slippery so I wrote it off even though it seemed weird. This time today though it was doing it relatively consistently and was able to grab a couple logs:
http://someforum.net/datalogs/datalog172.csv
http://someforum.net/datalogs/datalog174.csv
Only 42k on the car but still under warranty so crossing my fingers Mazda will fix it up.
 Old 12-23-2013, 08:51 PM   #2
vtekken's Avatar
Posts: 737   (View Stats)
vtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the worldvtekken is the leader of the world
I'll send you a case of beer if they cover your clutch. ;-)
Maybe your rear main is leaking?
2011 MazdaSpeed 3
RichTuned | Cobb SRI | Cobb TIH | SU TMIC | CS Racepipe | CS Downpipe | CS TMM Insert | KMD 2.1 | CPE Stage 2 RMM | ITV 22's |
Sent using VTEC
vtekken is offline   Reply With Quote
The Following User Says Thank You to vtekken For This Useful Post:
someguy (12-23-2013)
 Old 12-23-2013, 09:07 PM   #3
cthomp's Avatar
Posts: 114   (View Stats)
cthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the worldcthomp is the leader of the world
Clutch disc itself is only covered 12/12 unless failure caused by something else. Good luck
Cobb accessport. Cpe rmm. HTP 3.5 in. Intake. Gtx3076 w/atp ewg hotside, tial 38 w/g, 3 bar map senor, grimmspeed ebcs, A/T internals. TR 8 core w/cx racing pipes. Relentless Customs PNP I/M. M2 downpipe with Ultimate Racing cat back. Swift springs. Some accessories. Freektuned.
cthomp is offline   Reply With Quote
The Following User Says Thank You to cthomp For This Useful Post:
 Old 12-23-2013, 10:17 PM   #4
someguy's Avatar
They did my clutch pedal assembly this summer...mayyybe get lucky? I don't know, going to at least ask and see what they say. I doubt I'll attempt a clutch myself anyway, so they'll likely be the ones replacing whether it's my dollar or theirs.
 Old 01-02-2014, 09:05 AM   #5
someguy's Avatar
Lovely...Mazda found nothing wrong, says everything is fine. I think it happened a time or two while on the drive with them but it was borderline wheel spin (roads weren't good today). I guess since it's not happening consistently I just have to wait it out...or go ahead and replace it anyway.
Frustrating. I'd rather them have said, replace the damn clutch.
 Old 01-07-2014, 09:13 PM   #6
YangerD's Avatar
Posts: 2   (View Stats)
YangerD is an unknown quantity at this point
Well you wouldn't want to replace it only to find out when they take it out that it was still good lol
YangerD is offline   Reply With Quote
 Old 01-08-2014, 07:54 AM   #7
someguy's Avatar
True, although if it was rear main seal or something they'd be able to see that when they go to pull it apart. It's worse knowing that something is wrong and could cause me issues at any moment.
Speed 3 clutch failure - low miles Mazdamatt222 MazdaSpeed 3 - Engine, Transmission & Driveline 17 04-06-2013 05:35 PM
Group 1 to buy 18-store dealership group in Brazil Haltech Automotive News 0 01-24-2013 07:20 PM
Clutch Failure/clutchmaster review laxplayermjd MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-14-2012 03:19 PM
Clutch Failure at 5K ASHMS3 2010 MS3 - Engine, Transmission & Driveline 27 12-19-2011 11:02 AM
Page generated in 0.27201 seconds with 23 queries
