 Old 12-14-2013, 09:54 AM   #1
Xlude's Avatar
Posts: 57   (View Stats)
Xlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud ofXlude has much to be proud of
Default blue smoke
I need some input. I own a 2012 speed3. I bought it new last year. It has 10, 000 miles now and only mods are Sure intake and Corksport OCC. To day and once a couple of weeks ago CT had a temps of below 25 degrees. I started the car and let it warm up a little bit and the I drove off. Once I did a big cloud of blue exhaust smoke came pouring out. It just kept coming out for about 6miles where I meant my destination. By then the coolant temp got up to 160. When I got out of the car there was slight sour smell from the back end.
When I came back to the car 10 minutes later to go home I left again the the blue smoke kept coming out again. Not as much was coming out as the cars coolant temp got up to 180-190. Now like I said this has happened before when it was 25 degrees and 2day when it was 17 out. After the day that it was below 25, I hadn't had any problems and no blue smoke until 2day. I was thinking blown turbo but it doesn't do it every day. Only when it is extremely cold out. Above 30 and the car is fine.
Also I do hear a gurgling sound from the Sure intake. I can't tell if the sound is coming from the OCC because it is connected to it or from the turbo inlet.
I just wanted to know some opinions or if anyone has experienced this issue. I don't see any problems with boost or with fuel pressure. I monitor them both with a gauge that I have in the car.
Xlude is offline   Reply With Quote
 Old 12-17-2013, 09:28 AM   #2
Xlude's Avatar
It happeded again today. So much blue smoke that it was blinding people behind me. It stops onec the car was warmed up to max for about 5 minutes. Then it went away. Also when I WOT I got a cel for P0123 code. I believe to too lean if I am correct. It also below 20degrees.
 Old 12-17-2013, 09:32 AM   #3
bladerunner10121's Avatar
Posts: 83   (View Stats)
bladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the worldbladerunner10121 is the leader of the world
Have you checked your OCC to see if its full?
bladerunner10121 is offline   Reply With Quote
 Old 12-17-2013, 10:12 AM   #4
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
Because Sure products.
The Following 2 Users Say Thank You to Voltron For This Useful Post:
Kyle Undefined (12-17-2013), SpeedLife (12-17-2013)
 Old 12-17-2013, 10:17 AM   #5
PPD369Speed3's Avatar
Posts: 785   (View Stats)
PPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the worldPPD369Speed3 is the leader of the world
Groaned at 97 Times in 19 Posts
Inb4ventedblock
You are pouring out blue smoke and you think it is a smart idea to go WOT???
Sounds like your turbo seals shit the bed. Please, for the sake of your engine, never got WOT when you suspect a problem....
Stock out and go to the dealer.
Sent from my HTC One using Tapatalk 2
2011 Speed3
BNR S3 / HTP 3" Intake / Grimspeed EBCS / AT Internals / Cobb AP / UR Catless TBE / ETS TMIC / Forge V1 BPV / JBR 88 Duro RMM / Eibach Pro kit / SPC Camber Arms
Freektune in progress
Last edited by PPD369Speed3; 12-17-2013 at 10:17 AM. Reason: MSF Database - Automerged Doublepost
PPD369Speed3 is offline   Reply With Quote
 Old 12-17-2013, 10:17 AM   #6
Resident Baus
duappleganger's Avatar
Posts: 504   (View Stats)
duappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the worldduappleganger is the leader of the world
Groans: 34
Groaned at 56 Times in 18 Posts
Blue smoke?....
Teh car is magick
2011 Black Mica MS3
FREEKTUNE (On hold 'til EWG) ATP GTX3071R IWG (soon to be EWG) Full Race exhaust manifold CP-e whale peen + 3.25 in. intake
COBB EBCS + Downpipe + BPV + AP Stage 2 Corksport CBE + Brake Pads Ultimate FMIC NGK Iridium IX @ .28 DDM HID 6000k
Autotech CDFP Internals JBarone EGR delete, TB + IM gaskets, SSP + Shift Anchors, 88D RMM, 70D passenger + tranny mount, RSB, and OCC
HTP battery box TSW Nurburgrings 18x8.5 MBR w/ Michelin Pilot Super Sports 235x40x18 +45 Goodridge SS Brake Lines
Installation TBD: H&R springs + Koni yellow shocks + struts
duappleganger is offline   Reply With Quote
 Old 12-17-2013, 10:25 AM   #7
Skierdood's Avatar
Posts: 3,847   (View Stats)
Skierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the worldSkierdood is the leader of the world
Rub your muffler and see if a genie appears. That's my best guess.
But no you are burning oil. Stock out and use your warranty.
2007 True Red MS3
AP V2 • CPE Xcel Nano • COBB TIP • UR TP • Autotech Internals • CS RMM Inserts • FD Wheels • Freek Tuned 3/9 E85 315whp/352wtq •
Skierdood is offline   Reply With Quote
White (not blue) exhaust smoke kwsmithphoto MazdaSpeed 3 - Engine, Transmission & Driveline 14 05-25-2015 06:00 PM
heavy blue exhaust smoke cnupoxem CX-7 > Issues & Troubleshooting 17 12-15-2012 09:05 PM
Blue smoke under acceleration Dsmer4ever Mazdaspeed3/6 General Discussion 7 04-17-2011 04:22 PM
Blue Smoke johnnyspeed6 MazdaSpeed 6 - Engine, Transmission & Driveline 9 03-04-2010 08:31 PM
Blue Exhaust Smoke JCMS07 MazdaSpeed 3 - Engine, Transmission & Driveline 16 12-02-2008 11:56 PM
Page generated in 0.27408 seconds with 25 queries
