Like Tree3Likes
 Old 11-04-2010, 12:57 PM   #1
akbrazil's Avatar
Posts: 287   (View Stats)
akbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond reputeakbrazil has a reputation beyond repute
Default Check Engine Light (P2098)
Over the weekend I got a check engine light – took out the trusty scanner and it pulled a P2098 (Post Catalyst Fuel Trim System too Lean Bank 1). My mods are high flow catted down pipe, test pipe, complete cold air kit and bigger intercooler. All mods were done back in Dec of 2009. I put over 9000 miles since the mods (Currently have 16K miles). Anybody with a similar problem and what did you do to fix?? When I erase codes, it comes back after one day worth of driving (roughly 30 miles).
MODS: BNR STAGE 3 Turbo - CP-E Turbo Inlet - CP-E Cold Air Intake - Forge BPV - Street Unit Silicone Inlet & Outlet Hoses - UR Catted Down Pipe - UR Test Pipe - ETS Top Mount Intercooler - COBB AP (WOT-Tune) - KMD Internals - Grimmspeed EBC - HAWK HPS Front Pads - JB dog bone rear mount - NGK (1 step colder plugs) - DDM HID (Headlights & Fogs)
akbrazil is offline   Reply With Quote
 Old 11-04-2010, 04:22 PM   #2
6SpeedTA95's Avatar
Posts: 384   (View Stats)
6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world6SpeedTA95 is the leader of the world
Groaned at 7 Times in 5 Posts
Reset it and see if it comes back, I'm wondering if perhaps its CAI related...or one of your other airflow mods. I am surprised your just now getting it, makes me concerned about a possible injector problem
6SpeedTA95 is offline   Reply With Quote
 Old 11-05-2010, 08:58 AM   #3
akbrazil's Avatar
Ok...so update: I got the light again after a second reset and only driving a short distance before the light pops up again. What do guys think it is?? Anybody with a similar problem?? I haven't changed anything...added anything since Dec of 2009.
 Old 11-05-2010, 12:03 PM   #4
6SpeedTA95's Avatar
You said you did have these mods last winter? When it gets colder, air gets denser and the ECU will compensate by upping fuel pressures. Is it only at idle? You only have one code?
 Old 11-06-2010, 05:35 PM   #5
akbrazil's Avatar
only one code and yes I had all these mods since last winter so I don't see why the weather would affect it now but not before. What do you guys think??? Where should I look..?? I check the exhuast to see if the O2 where ok...they both look brand new...no exhaust leaks, the wires look fine...I also checked the intake track and everything looks good....every time I erase the code it comes back with only a few miles driven....
 Old 11-06-2010, 05:38 PM   #6
98zjdave's Avatar
Posts: 473   (View Stats)
98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world98zjdave is the leader of the world
Groans: 36
My buddies car is doing the same thing. He has a downpipe on it, mazdaspeed cai, bpv, and exhaust. If he figures his out Ill let you know..
2007 MazdaSpeed 3 Cosmic Blue SOLD!
cpe sri, cpe tip, greddy cbe, cobb dp, ts dp bov, hypertech tuner
2012 Ford Mustang 6 speed SOLD! :*(
magnaflow axleback, jlt intake, bama tuned, 13.7 @ 105
2011 Mazdaspeed 3 w/tech , sure sri
98zjdave is offline   Reply With Quote
 Old 11-06-2010, 08:28 PM   #7
FY"IED"N
dMuze's Avatar
Posts: 506   (View Stats)
dMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the worlddMuze is the leader of the world
i just added my cat back to my dp/tp...its in the 40s here now and im getting the same code. my best guess...engine is easier to breath, runs slightly leaner...cold weather means slightly leaner. my DD says my stock afr now is 13.5 rather then 14.7...with i tune this should get rid of the code.
2010 Silver MS3 Tech Pkg 307whp, 340ft/lbs tq
CS SRI/TIP, UR Turbo Back, UR FMIC, TS Dual Port BOV, DENSO ITV22 Plugs, AP EcuTek ProTune, DO STG 2 Prog Kit 100% Meth, JBR SSP w/ Bushings, CS Springs, JBR camber arms, Koni yellows, 80D PMM/88D RMM/88D TMM, MD OCC, CP-E HPFP, Ford Motorcraft tranny fluid, DashDaq, Kenwood 12"sub, Kicker 400w amp, DDM 35W 6k lows/3k fogs, CS LED kit, 20% tint.
dMuze is offline   Reply With Quote
 Old 11-06-2010, 09:17 PM   #8
mo4130's Avatar
Posts: 118   (View Stats)
mo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant futuremo4130 has a brilliant future
Groaned at 13 Times in 4 Posts
Youre not upping fuel pressures you are adding more fuel to bring your trims inline to keep your afrs good. If the comp has to add more then 25% I think then it will throw a code.
Is that 13.5 at wot? If it is that's bad.
09 mgm sp3 Cp-e hpfp, jbrone sstp, heavy weight knob, gutted midpipe, ets tmic, trz rmm, ht tune, cobb sir/tip. rx wheels with some fat meats
mo4130 is offline   Reply With Quote
 Old 11-06-2010, 10:27 PM   #9
FY"IED"N
dMuze's Avatar
nope im still in the 10s at wot...at part throttle, normal driving though im down around 13.5 when stock exhaust was at 14.7
 Old 11-07-2010, 05:32 PM   #10
smitty5788's Avatar
Posts: 1,065   (View Stats)
smitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the worldsmitty5788 is the leader of the world
Groans: 215
Same problem here, I spent a couple hours trying to track it down. I am also getting a P0137 O2 sensor circuit low voltage. I have replaced the sensor with no results. Wiring looks fine between the sensor and ecu. I dont know which is causing the problem but my bet is that one of the codes is causing the other.
If I find anything out or someone else does post up your solution.
I can post a log if anyone thinks it will help. I have one I can post with FRP, STFT, LTFT, Boost, and abs. load. I can get some more with AFR tonight or tomorrow. Anything else I should log that would help to figure this out?
2011 DGM STI Sedan - Fully Bolted FP Green Setup
368WHP / 335WTQ
SOLD: Black Mica 2010 MS3 - Tech Package -CPE Catless DP - CS CBE - SURE Aeros - SURE Sidewinder - TS BPV - CPE HPFP - JBarone Shifter Bushings - TRZ RMM - MD OCC - Progress RSB - DashDAQ - 18x8.5 +45 Rays Gram Light 57F - 235/40 Potenza RE760
smitty5788 is offline   Reply With Quote
The Following User Says Thank You to smitty5788 For This Useful Post:
dMuze (11-10-2010)
 Old 11-07-2010, 09:41 PM   #11
smitty5788's Avatar
Groans: 215
Here are 2 logs from tonight you can see that my AFR is in the high 13 while cruising and in the 10s at WOT.
The codes Im getting are P2096 and P0137
368WHP / 335WTQ
The Following 2 Users Say Thank You to smitty5788 For This Useful Post:
dMuze (11-10-2010), Zai_MS3 (03-30-2011)
 Old 11-07-2010, 11:13 AM   #12
YokiMazoku's Avatar
Posts: 320   (View Stats)
YokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the worldYokiMazoku is the leader of the world
If you have some kinda monitoring device that would help alot......we need a LOG
Boobs.....because you can't motorboat a personality.
YokiMazoku is offline   Reply With Quote
 Old 11-07-2010, 03:38 PM   #13
edspeed3's Avatar
Posts: 67   (View Stats)
edspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of lightedspeed3 is a glorious beacon of light
Groaned at 20 Times in 5 Posts
its most likely the DP. when you installed the DP did you add a defouler?
2010 Silver Speed3 /w Tech
JbR SSP / shift bushings
e4p shift knob
CP-E 75dm RMM
DDM 55w 5k HIDs
resonator delete
Cobb SRI
Block8head defrost vent pod / Prosport 52mm electric boost gauge
Tanabe NF210 Springs
HKS SSQV V1 BPV
JbR Rear Sway Bar
edspeed3 is offline   Reply With Quote
 Old 11-07-2010, 05:23 PM   #14
shelbygoat's Avatar
Posts: 103   (View Stats)
shelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond reputeshelbygoat has a reputation beyond repute
Groaned at 5 Times in 2 Posts
how do you reset it?
might have something to do with the light coming back on, or maybe not
shelbygoat is offline   Reply With Quote
 Old 11-08-2010, 05:07 AM   #15
drudedon's Avatar
Posts: 40   (View Stats)
drudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud ofdrudedon has much to be proud of
have you checked all your vaccum hoses? is your dp pipe catted?
drudedon is offline   Reply With Quote
 Old 11-08-2010, 05:40 AM   #16
smitty5788's Avatar
Groans: 215
Went over everything yesterday, The only potential issue I found was a small split in the Recirc. hose where it attached to the BPV, It didnt look like it was cracked all the way through but I ordered a new one from Corksport to see if It helps but I dont think it was leaking through there.
My DP is Catless
368WHP / 335WTQ
 Old 11-08-2010, 06:05 AM   #17
smitty5788's Avatar
Groans: 215
For you other guys with this problem, how does UR have the Bung for the rear O2 sensor setup? Is it extended at all and can you post a pic or is it just a straight extension like in the pic on their site?
368WHP / 335WTQ
 Old 11-08-2010, 09:08 AM   #18
smitty5788's Avatar
Groans: 215
Found this on NASIOC, anyone have any ideas on how to test the harness between the sensor plug and the ECU?
"This is a code 92096 for "post catalyst fuel trim system too lean Bank 1) It is related to the rear most O/2 sensor. I have seen this in my travels with 05MY imprezas and legacys. And it has almost always been a poor conection in the wiring harness. that rear 0/2 has a jumper harness between it and the main harrness. and that is where the problem has been found. not to say you dont have a faulty sensor, or maybe you actually do have a lean condition......who would think it? Anyway, its an 05 so get it to the dealer and let them fix it."
368WHP / 335WTQ
 Old 11-08-2010, 11:51 AM   #19
YokiMazoku's Avatar
Ok do this......Go to the store buy a pack of cigarettes *which ever you like doesnt matter* dirve the car up on ramps light your cigarette enjoy it for a minute now crawl under the car inhale some of the cigarette dont blow it out just open ur mouth let it come out by the exhaust connections see if it gets blown away by a leak do this to all the connections. If no leak take your MAF sensor out clean it with MAF cleaner reset the ECU.
I believe the last person i saw with this code had a bad MAF sensor GL man!
 Old 11-08-2010, 11:54 AM   #20
smitty5788's Avatar
Groans: 215
I cleaned the MAF, Im 99% sure there are no leaks other than the one I found back under where the stock muffler is but Ill look at it again.
368WHP / 335WTQ
dMuze (11-10-2010)
 Old 11-08-2010, 01:33 PM   #21
FY"IED"N
dMuze's Avatar
rear o2 sensor sits on an angle into the pipe. i looked inside the bung before the installation and there was a super tiny hole at the bottom of the bung going into the dp. i dont think they bottom sensor is getting a strong enough temp reading which may be why its throwing a low voltage code. im getting tuned next month by john. that should clear them all.
 Old 11-08-2010, 02:08 PM   #22
smitty5788's Avatar
Groans: 215
I never looked inside the extension of the CPE pipe, maybe ill just go get a new bung welded in and see if that changes anything, it cant hurt.
If not John will be here Monday and hopefully everything can get cleared up then
368WHP / 335WTQ
 Old 11-08-2010, 09:54 PM   #23
smitty5788's Avatar
Groans: 215
For anyone interested, i think Silverdemon and I figured this out, Ill post my results if it works.
If you look at the following logs that I took on my drive home today, the O2 sensor is reading 0 volts while I'm cruising on the highway. When I'm sitting at idle in traffic it jumps up to 0.9 volts like it should. The theory is, like dMuze said above that the sensor isn't getting enough hot exhaust over it with the extension on there especially at higher speeds. I also noticed that when I let off the gas and coast in gear the sensor reads 0 but as soon as I stop an let it idle it jumps to 0.9 in a second or two as the extension is able to fill with exhaust.
Im going to go have another bung welded in for the O2 sensor and let it just stick into the pipe, Id rather have a Cat Inefficiency CEL then one that messes with my AFR and Trims.
368WHP / 335WTQ
The Following 3 Users Say Thank You to smitty5788 For This Useful Post:
chaser27 (03-16-2014), dMuze (11-10-2010), SilverDemon (11-09-2010)
 Old 11-09-2010, 05:16 AM   #24
FY"IED"N
dMuze's Avatar
let me know how this works out. if that fixes things im going to drill into the bung making the tiny hole at the bottom bigger.
 Old 11-09-2010, 10:13 AM   #25
FY"IED"N
dMuze's Avatar
Update...i emailed UR about the CEL's...they said the intent of the diagonal bung and small punch hole was to avoid a cel, but my car may be more sensitive...at any rate it looks like im getting it back on the lift fri or sat to drill out the rest of that hole so the exhaust gas can freely pass by the sensor...that way i can get a proper tune next month.
 Old 11-09-2010, 02:53 PM   #26
SilverDemon's Avatar
Posts: 3,034   (View Stats)
Here are a few of the data logs that I took for a comparison. I am running the version 1 turboXS down pipe (catless) and their mid pipe. The TXS set up does not have the offset bung, it only utilizes a longer bung, somewhat like a built in anti-fouler. The only code I have ever gotten was a P0421 on cold mornings.
First screen shot is idling down the driveway, the second is just cruising, and the third is a WOT pull through 5th.
- Douglas Adams
- Mark Twain
READ THIS----
2nd Amendment
The Following 2 Users Say Thank You to SilverDemon For This Useful Post:
dMuze (11-10-2010), smitty5788 (11-09-2010)
 Old 11-09-2010, 04:19 PM   #27
akbrazil's Avatar
I don't believe my downpipe has a tiny hole for the o2 as it is the highflow version from UR. You guys which received the cel light....did it come on after you installed your mods or during the weather change??? Like I mention in the first post, I have had my mods installed for 11 months and only now that I receive a cel light for the first time.
 Old 11-09-2010, 04:28 PM   #28
smitty5788's Avatar
Groans: 215
Mine was right after the install. I have an appointment Thursday to get the rear O2 bung changed and from the looks of it that should fix it.
368WHP / 335WTQ
 Old 11-09-2010, 04:38 PM   #29
FY"IED"N
dMuze's Avatar
same. mine came on the day after the install. i also have a high flow cat. the reason they put such a small hole and mounted the bung on an angle in attempt to avoid a cel. now if my code was a cat inefficiency code, that would mean the exhaust gas read on the rear o2 was too hot...prob the same temp as the fwd sensor...with a low voltage or slow response code, not enough exhaust gasses are passing over the sensor. the lean code arrived once i added my cat back, and temps got below 50
 Old 11-09-2010, 06:22 PM   #30
FY"IED"N
dMuze's Avatar
just ran 3 logs...what program do i need to see them as graphs on my computer? they show up in excel as data
 Old 11-09-2010, 06:49 PM   #31
smitty5788's Avatar
Groans: 215
Im using Logworks for mine, not excel
368WHP / 335WTQ
dMuze (11-10-2010)
 Old 11-09-2010, 07:00 PM   #32
FY"IED"N
dMuze's Avatar
i just downloaded the logworks software, do you hook your logger right up to the computer or just the sd card?
 Old 11-09-2010, 07:01 PM   #33
smitty5788's Avatar
Groans: 215
just the SD card, then go to file > open file log
368WHP / 335WTQ
dMuze (11-10-2010)
 Old 11-09-2010, 07:25 PM   #34
smitty5788's Avatar
Groans: 215
make sure your log file type is a logworks csv also, you can pick the file type in the log screen on the DD
If you could take some logs like mine or Scott's and we can look at what your o2 voltage is doing. If it looks like mine, I think we can be sure its the extension on the O2 sensor.
368WHP / 335WTQ
dMuze (11-10-2010)
 Old 11-09-2010, 07:31 PM   #35
FY"IED"N
dMuze's Avatar
thats what i did...one idle (warm), one cruising, one wot 1-5. il prob have to redo the logs though since il have to change the format it saves as.
 Old 11-09-2010, 07:39 PM   #36
smitty5788's Avatar
Groans: 215
alright, post them up when you get a chance, hopefully it looks the same.
368WHP / 335WTQ
 Old 11-09-2010, 11:18 PM   #37
Seaton's Avatar
Posts: 233   (View Stats)
Seaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the worldSeaton is the leader of the world
Hey guys, my car also has a DP on it and I get the p2096 code.
It's none of the mentioned brands here, we have tried everything to fix this but it just comes back anywhere from 100 to 400 miles.
We have tried different bung lengths and 3 different positions on the DP all with no luck.
Note that this DP is on atleast 10 gen 1 cars with no problems at all. It only is happening on gen 2 here.
Would love to fix this but I'm not holding my breath.
Seaton is offline   Reply With Quote
 Old 11-10-2010, 05:44 AM   #38
FY"IED"N
dMuze's Avatar
a tune should fix it...im fixing my other codes in order to stabilize my trims and afr's...then the tune should cover the lean code.
 Old 11-10-2010, 07:03 AM   #39
smitty5788's Avatar
Groans: 215
Any other codes with it like a P0137? Have you tried no bung extension at all?
On another note I reset me ECU last night. On the way to work this morning I watched my O2 voltage and made sure to keep enough throttle to keep the sensor voltage about 0.7V. No CEL, AFR is right on and tims are really good. I have no doubt the P0137 is due to the extension and the P0137 is causing the car to dump fuel because it thinks its lean causing the P2096 code.
DMuze, if your logs show the same kind of sensor voltage behavior I think we can be pretty sure this is the problem.
368WHP / 335WTQ
dMuze (11-10-2010)
 Old 11-10-2010, 07:07 AM   #40
FY"IED"N
dMuze's Avatar
Any other codes with it like a P0137? Have you tried no Bung extension at all?
On another note I reset me ECU last night. On the way to work this morning I paid close attention to my O2 voltage and made sure to keep enought throtle to keep the sensor voltage about 0.7V. No CEL, AFR is right on and tims are really good. I have no dount the P0137 is due to the extension and the P0137 is causing the car to dump fuel because it thinks its lean causing the P2096 code.
the car is def dumping fuel...my idle afr will sometimes be 12.7-13.3 then will jump back to 14...also when cruising the first 2-3k rpm range will be in the 12s then come back up. also according to my mgp, it would get as low at 7 during normal driving.
to be sure im monitoring the same shit for the logs... i have boost, afr, spark, stft, ltft, frp, rpm... anything else?
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f427/check-engine-light-p2098-63641/
Who's running a catless DP? This thread Refback 08-02-2011 06:53 PM
Important for all 2010's running catless DP This thread Refback 02-18-2011 09:30 PM
check engine light giordanos4 MazdaSpeed 3/6 - ECU Computer Tuning 11 07-09-2010 02:06 PM
Check engine light (CPE SRI and TIP) Intruder 2010 MS3 - Engine, Transmission & Driveline 38 06-05-2010 12:24 AM
Check Engine Light is on armarine04 MazdaSpeed 3 - Engine, Transmission & Driveline 9 09-21-2009 11:37 AM
Oh No Check Engine Light! thabigo MazdaSpeed 6 - Engine, Transmission & Driveline 8 04-04-2009 01:57 PM
Check engine light??? supergoose MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-20-2008 07:42 AM
Page generated in 0.67052 seconds with 32 queries
