Like Tree17Likes
 Old 01-10-2014, 03:29 PM   #1
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
Default Clutch failure tracking thread
Alright, with all these talks about clutch failures, I think it is a good idea to document who exactly it is happening to so we can find a pattern. Please post up your model year, mileage, any mods you might have, and what you are experiencing so we can try to see if there is any pattern. I'll update the OP as people post.
I'l start.
abiezerf
Year - 2012
Miles - 19,000
Mods - Intake, Short Shift Plate, Test Pipe, Internals
Tune - 25% e85 tune
Description - Slipping in 4th and 5th gear around 4K RPMs
kidlifecrisis
Year - 2012
Miles - 17,500
Mods - intake, catted dp, catback, internals
Tune - 93 octane tuned by the freek
Description - Slipped in 4th and above at about 3500 rpm for a few weeks in Nov and Dec
SomeGuy
Year - 2010
Miles - 43,000 km (26,000 miles)
Mods - fully bolted
Tune - Self Tuned on 94 (approx. 320-330wtq)
Description - Slipping from 3-4k rpm range in various gears
printman
Year - 2012
Miles - 18,000
Mods - test pipe, internals
Tune - e85 blend
Description - slipped once last week in 4th around 4500 rpms doing a log
specvspeedfreak
Year - 2011
Miles - 31,000
Mods - 3.5 intake, 3 port, test pipe, internals, cpe TMIC gutted stock DP, egr delete, TB bypass
Tune - 50/50 E85 tune
Description - Slipping in 4th and 5th mainly from 4-5K rpms
tornado842
Year - 2013
Miles - 11,000
Mods - fully bolted/BNR S3
Tune - ?
Description - Slipped in every gear for a few days after trying out my new hoosier slicks.
Phoenix
Year - 2011
Miles - 51,000
Mods - internals, intake
Tune - 18 psi tune
Description - Run through 6th, the pedal worked normally, but the clutch would not disingage, was still not able to get it into first with the engine on
CWP_MS3
Year - 2012
Miles - 29K
Mods - Bolted
Tune - E85
Description - started slipping when cold in 4th and 5th.
Adamizme
Miles - 38K
Mods - CS SRI/TIP, CS Racepipe, CS TMIC, CS CAB, NGK plugs, Internals
Tune - 93 Freek
Description - Slipped badly for a few days in 3rd+. A few days of mild driving and then tested again to find it was no longer slipping.
5doorsoffury
Year - 2012
Miles - 22,000
Mods - in sig (intake +mani) test pipe e85 etune
Tune - Finkle!!!!!!! e85
Description - Slipping in 5th
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
The Following 9 Users Say Thank You to abiezerf For This Useful Post:
5doorsoffury (01-14-2014), ABolewski (01-15-2014), adamizme (01-13-2014), Cevaes_64 (03-04-2014), CWP_MS3 (01-13-2014), kidlifecrisis (01-13-2014), redneck4Christ (01-13-2014), Roddiy (04-05-2014), someguy (01-10-2014)
 Old 01-10-2014, 04:19 PM   #2
kidlifecrisis's Avatar
Posts: 672   (View Stats)
kidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the worldkidlifecrisis is the leader of the world
2012, 17.5k miles, intake, catted dp, catback, internals, 93 octane tuned by the freek.
Slipped in 4th and above at about 3500 rpm for a few weeks in Nov and Dec, been driving like a sane person since and have done several 4th gear pulls since without issue. Might be okay now? Not really sure
kidlifecrisis is offline   Reply With Quote
 Old 01-10-2014, 04:31 PM   #3
doctavus's Avatar
Posts: 1,728   (View Stats)
Damn, such low miles!
 Old 01-10-2014, 04:35 PM   #4
someguy's Avatar
Posts: 914   (View Stats)
SomeGuy - 2010 - 43,000km - 3-4k rpm range in various gears - Mods in sig but basically fully bolted.
Also from my thread on the topic including logs of it happening:
5th and 6th gear acting up today, second time it's happened. First time was in 4th gear and the road might have been a bit slippery so I wrote it off even though it seemed weird. This time today though it was doing it relatively consistently and was able to grab a couple logs:
http://someforum.net/datalogs/datalog172.csv
http://someforum.net/datalogs/datalog174.csv
 Old 01-10-2014, 04:57 PM   #5
Erick13Speed3's Avatar
Posts: 353   (View Stats)
Erick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the worldErick13Speed3 is the leader of the world
Damn, you got me worried now. I just hit 5200 on my way back home today, I am stock for now so I should be fine
Erick13Speed3 is offline   Reply With Quote
 Old 01-10-2014, 05:04 PM   #6
Printman's Avatar
Posts: 300   (View Stats)
Printman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the worldPrintman is the leader of the world
18,000 mi. mods in sig had it slip once last week in 4th around 4500 rpms doing a log. I went WTF but hasn't done it since so who knows if clutch is really going bad or just a fluke.
Been reading the clutch install how to's just in case might go ahead and order the ACT 6 puck when tax money comes in so I have it if it really is going bad.
[SIGPIC]
[/SIGPIC]
2012 Black Mica W/Tech
Cobb AP
AutoTech Internals
JBR 88DM RMM
JBR Heavy Knob
JBR 3" WP
JBR Rear camber arms
UR TP
Ford MOFO Tranny juice
Rotella T6
Self Tune - (Work in Process)
NGK Step 1 colder
5/7 corn fed
Printman is offline   Reply With Quote
 Old 01-10-2014, 05:10 PM   #7
2011speed's Avatar
Posts: 1,497   (View Stats)
so far seems like only 2010 and 12
FreeKtuned
fitty fitty
 Old 01-10-2014, 05:55 PM   #8
specvspeedfreak's Avatar
Posts: 2,371   (View Stats)
lol
2011 close to 31K miles. 50/50 E85 tune. 3.5 intake, 3 port, test pipe, internals, cpe TMIC gutted stock DP, egr delete, TB bypass.
Slipping in 4th and 5th mainly from 4-5K rpms but need to get logs to verify.
 Old 01-10-2014, 07:07 PM   #9
blackms3_71's Avatar
Posts: 2,250   (View Stats)
Wow such low miles. I would check to make sure no oil or anything is getting on the clutch. I have an 08 with 60k fully bolted and i have never slippec
 Old 01-10-2014, 08:58 PM   #10
rigor's Avatar
Posts: 2,399   (View Stats)
Groans: 40
lost mine about 60k shit clutch
at 104000 2 bent rods
tuned by nishan
 Old 01-10-2014, 09:15 PM   #11
Why do u feel the need to tell me that lol i wanted a big turbo with tax refund not a new clutch :/
Plus 60k wouldnt be too bad when u think about it i am putting down 100 more tq then stock
Last edited by blackms3_71; 01-10-2014 at 09:15 PM. Reason: MSF Database - Automerged Doublepost
 Old 01-10-2014, 09:43 PM   #12
jseams's Avatar
Posts: 1,414   (View Stats)
jseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the worldjseams is the leader of the world
I have 9300 miles on mine and there have been several times that I thought the clutch was slipping... upon investigating and plugging a few logged instances into VD and datazap I found that it wasn't clutch slip it was wheelspin. You can see that there is a a direct correlation between rpm and vehicle speed and you can see the bump where I break loose. I've done this both in 3rd and 4th gear and there was never the typical tire "screetch" people often expect when you break loose... the only indication was a sudden rise in rpms and no increase in speed.
Anyhow, not saying that you folks aren't experiencing blown clutches just that you should be absolutely certain before you start to panic.
CRMetallic 2019 Mercedes C43 AMG
SOLD MNBlue 2012 S4 Prestige... a few mods
SOLD IB 2015 3.8 Gencoupe Ultimate
BLOWED UP DIB 2014 Mustang 5.0... a few mods
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
Corksport TMIC//BPV//TIP//BTbs
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
Freektuned 50/50 E85
jseams is offline   Reply With Quote
The Following 3 Users Say Thank You to jseams For This Useful Post:
86AmishMs3 (04-07-2014), kolosok17 (01-17-2014), Mauro_Penguin (01-11-2014)
 Old 01-10-2014, 09:48 PM   #13
someguy's Avatar
Breaking loose feels so much different than clutch slip...the tires don't always make noise, depends on road surface and heat and such. Mine if you look at the logs, rpm/speed don't stay constant.
 Old 01-10-2014, 10:02 PM   #14
jseams's Avatar
Yeah, plotting your log shows you are really slipping. Pretty obvious especially in that second log.
However, I disagree that it always feels different; there are always threads popping up where people are asking "wheelspin or clutchslip"... I know, I'm guilty of this myself. lol
zachman2010 likes this.
SOLD - LS 2012 MS3
Cobb AP//SF//CAB
Autotech HPFP
JBR 88a RMM
Sure M3 TP
OBX CBE
Tanabe NF210's
ADVAN RG-D 18x8 +38
 Old 01-11-2014, 12:57 AM   #15
Now I'm really confused. It didn't slip or spin? like it has before. Maybe I was just crazy... I don't know lol
some logs
Not sure what happened in datalog 3.. Edit: think it was a bump now that I think about it
datalog5.csv
datalog2.csv
datalog3.csv
 Old 01-11-2014, 02:09 AM   #16
tornado842's Avatar
Posts: 166   (View Stats)
tornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond reputetornado842 has a reputation beyond repute
2013 11K miles. Slipped in every gear for a few days after trying out my new hoosier slicks. 334hp 377tq. After driving it softly for a few weeks it is no longer slipping. I had a 07 speed 3 for 40k miles without ever having the clutch slip. I have the new clutch/flywheel sitting in my garage waiting for this one to die.
2013 Speed3-
Autotech HPFP-FORGE BPV- JBR 3.5 Intake - JBR FMIC -CorkSport Catback - GTX3076 *"Other stuff"
1995 Chevy 6.5 k2500- 18PSI - still slow
tornado842 is offline   Reply With Quote
 Old 01-11-2014, 06:00 AM   #17
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
@Ms3_Miami;
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
mtosofsky (01-11-2014)
 Old 01-11-2014, 06:13 AM   #18
Voltron's Avatar
Posts: 4,556   (View Stats)
Groans: 77
There were a few cases local here.
A 2011 fully bolted w slipping around 30k
2012 w 3076 and 15k
2012 fully bolted, 7k
The Following User Says Thank You to Voltron For This Useful Post:
blackms3_71 (01-11-2014)
 Old 01-11-2014, 07:50 AM   #19
2011speed's Avatar
Is there a correlation between all of these cases?
FreeKtuned
fitty fitty
 Old 01-11-2014, 09:21 AM   #20
Yeah big power lol
The Following 2 Users Say Thank You to blackms3_71 For This Useful Post:
J'sSpeed3 (04-02-2014), killer-ms3 (01-13-2014)
 Old 01-11-2014, 11:09 AM   #21
abiezerf's Avatar
Groans: 46
Lol I'll update the op in a few but modded cars seem to be the correlation. Oddly enough, I, too, did some more fourth and fifth gear pulls today and I did not slip. Not even once. I was going to adjust my SSP to the middle setting but now I think I'll leave it as is.
Sent from my XT1056 using Tapatalk
Current Build:
Sold:
 Old 01-11-2014, 12:35 PM   #22
pallen's Avatar
Posts: 8   (View Stats)
pallen will become famous soon enough
6800mi all stock. Just had my 2013 towed to the dealer. The pedal went to the floor while shifting normally. They let me look into the inspection hole and it was full of shredded clutch material. They will be submitting it to Madza.
pallen is offline   Reply With Quote
 Old 01-11-2014, 12:47 PM   #23
someguy's Avatar
Damn, that's a failure...not quite what this thread is about but madness. At least yours is almost guaranteed to be covered.
 Old 01-11-2014, 01:23 PM   #24
Originally Posted by abiezerf View Post
Oddly enough, I, too, did some more fourth and fifth gear pulls today and I did not slip. Not even once.Sent from my XT1056 using Tapatalk
It's a silver pu conspiracy! lol
 Old 01-11-2014, 01:36 PM   #25
boostdmazda3's Avatar
Posts: 1,177   (View Stats)
seems like a pu problem. My stocker started slipping at 96k miles after the bnr.
boostdmazda3 is offline   Reply With Quote
The Following 3 Users Say Thank You to boostdmazda3 For This Useful Post:
bertrand_CX_7 (01-13-2014), Big_Burd (04-07-2014), hatchedspeed3 (02-27-2014)
 Old 01-12-2014, 06:10 PM   #26
pallen's Avatar
Yeah, they gave me the speech about the clutch being a 'wear item', but also acknowledged that it would be pretty hard to kill a clutch that fast even with the worst abuse. I'm over 40 and never driven anything but a standard. I know how to take care of a clutch.
 Old 01-13-2014, 07:18 AM   #27
abiezerf's Avatar
Groans: 46
Updated the OP, looks like the clutch slipping is a power issue mixed with the weather. Mine stopped slipping now that the weather has heated up. A few others have reported the same.
Current Build:
Sold:
 Old 01-13-2014, 08:25 AM   #28
Phoenix's Avatar
Posts: 124   (View Stats)
Phoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant futurePhoenix has a brilliant future
Mine took a dump Friday night. Was making a run through 6th and once I went to exit, the pedal worked normally, but the clutch would not disingage. Had to make it home rev matching and trying not to come to a stop. Waited a couple of hours and was still not able to get it into first with the engine on.
I suspect that the clutch was probably slipping just enough to cause a tremendous amount of heat and destroy the diaphram spring in the pressure plate.
I have 51k, 2011, internals, Sure 3" Aeros, internals and AP. Boost target is 18 psi. It's being towed to the shop today and will most likely find out tomorrow.
SURE Full3 Aeros - UR DP - Test pipe - Magnaflow catback - RMM - Autotech internals - AP self tuned - 3 Port EBCS
Phoenix is offline   Reply With Quote
 Old 01-13-2014, 09:07 AM   #29
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
You need to find a better way to organize the OP @abiezerf;. Too difficult to read. I think bolt-ons matter less than whether or not they're custom tuned. Make them all follow the same format and space them or something. Like this maybe:
CWP_MS3
Miles - 29K
Mods - Bolted
Tune - E85
^^^ Just a suggestion.
Rich Tuned
330WHP and 363TQ
10-19-13 Moore Automotive
 Old 01-13-2014, 09:47 AM   #30
abiezerf's Avatar
Groans: 46
Makes sense. Thanks. Updating now
Current Build:
Sold:
 Old 01-13-2014, 10:11 AM   #31
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Lol... So far the only consistency I'm seeing is mad power. Most people on that list are E85.
Rich Tuned
330WHP and 363TQ
 Old 01-13-2014, 10:29 AM   #32
someguy's Avatar
Not me...I'm self tuned on 94, approx in the 320-330 wheel torque range.
 Old 01-13-2014, 10:35 AM   #33
I put down 291 whp on the mustang dyno at Powerplant Motorsports in Poughkeepsie, the consensus was that the dyno was pretty spot on with how a dyno jet would have read based on the other speeds that got on the rollers that day
 Old 01-13-2014, 10:46 AM   #34
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
How much torque?
Rich Tuned
330WHP and 363TQ
 Old 01-13-2014, 12:00 PM   #35
 Old 01-13-2014, 12:15 PM   #36
adamizme's Avatar
Posts: 183   (View Stats)
adamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the worldadamizme is the leader of the world
Subbed... mine slipped badly on Christmas eve in 5th gear. For a few days after that, it was slipping in 3rd+. It hasn't slipped at all for a couple weeks now. Mods in sig. 38k miles. Tuned for 93 by Freek.
Adamizme
Miles - 38K
Tune - 93 Freek
2012 Mazdaspeed 3 w/ tech package
CS LED Kit & Fogs - *painted* CF hood - VG Sharkfin antenna - CS TMM insert - DM PMM - CPe S2 RMM - Cobb AP - JBR True 3" intake - Autotech FP Internals - JBR RSB - CS Racepipe - CS SSB - JBR Short Shifter - CS SSP & weight - Motocraft tranny fluid - CS TMIC - NGK plugs - modified CS Cold Air Box - JBR EGR delete - CS OCC - DO WMI kit w/ d05 - DM TB spacer - CS BPV - KW v1 Coilovers - Whiteline adjustable endlinks - SPC camber arms - tons of GTSpec braces - Whiteline bump steer kit - Wilwood 6 pot front calipers w/ Wilwood slotted rotors - mz5 rear slotted rotors & brackets - front & rear SS brake lines - Freek tune
Last edited by adamizme; 01-13-2014 at 01:27 PM. Reason: Added info in correct format
adamizme is offline   Reply With Quote
 Old 01-13-2014, 12:47 PM   #37
hidin in yo bushes
CWP_MS3's Avatar
Groans: 122
Guys post up accordingly so he can just cut and paste it to the OP. If you want to add more to it in your post, then do so, but make it easy for him to keep the OP up.
Rich Tuned
330WHP and 363TQ
 Old 01-13-2014, 01:03 PM   #38
someguy's Avatar
SomeGuy
Year - 2010
Mods - fully bolted
 Old 01-13-2014, 02:17 PM   #39
abiezerf's Avatar
Groans: 46
Updated the OP some more. I guess the Pu's don't like cold and torque.
Current Build:
Sold:
 Old 01-13-2014, 03:59 PM   #40
5doorsoffury's Avatar
Posts: 1,123   (View Stats)
Groans: 74
5doorsoffury mods in sig. 2012 PU .Slipped in 5th after at about 22k roughly 13 k on e85. Has not slipped under stock power (that i can see with out logging).
ugg sry heres the cut and paste
5doorsoffury
Year - 2012
Miles - 22000 miles
MECP
2012 BM
Rfinkle tune in progress
Am I joining the clutch failure group? someguy 2010 MS3 - Engine, Transmission & Driveline 6 01-08-2014 07:54 AM
Speed 3 clutch failure - low miles Mazdamatt222 MazdaSpeed 3 - Engine, Transmission & Driveline 17 04-06-2013 05:35 PM
Clutch Failure/clutchmaster review laxplayermjd MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-14-2012 03:19 PM
Clutch Failure at 5K ASHMS3 2010 MS3 - Engine, Transmission & Driveline 27 12-19-2011 11:02 AM
***Official VVT acuator failure thread/database*** Raider MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 09-26-2011 05:58 PM
Page generated in 0.58785 seconds with 40 queries
