Like Tree17Likes
 Old 01-10-2014, 03:29 PM   #1
abiezerf's Avatar
Posts: 725   (View Stats)
abiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the worldabiezerf is the leader of the world
Groans: 46
Default Clutch failure tracking thread
Alright, with all these talks about clutch failures, I think it is a good idea to document who exactly it is happening to so we can find a pattern. Please post up your model year, mileage, any mods you might have, and what you are experiencing so we can try to see if there is any pattern. I'll update the OP as people post.
I'l start.
abiezerf
Year - 2012
Miles - 19,000
Mods - Intake, Short Shift Plate, Test Pipe, Internals
Tune - 25% e85 tune
Description - Slipping in 4th and 5th gear around 4K RPMs
kidlifecrisis
Year - 2012
Miles - 17,500
Mods - intake, catted dp, catback, internals
Tune - 93 octane tuned by the freek
Description - Slipped in 4th and above at about 3500 rpm for a few weeks in Nov and Dec
SomeGuy
Year - 2010
Miles - 43,000 km (26,000 miles)
Mods - fully bolted
Tune - Self Tuned on 94 (approx. 320-330wtq)
Description - Slipping from 3-4k rpm range in various gears
printman
Year - 2012
Miles - 18,000
Mods - test pipe, internals
Tune - e85 blend
Description - slipped once last week in 4th around 4500 rpms doing a log
specvspeedfreak
Year - 2011
Miles - 31,000
Mods - 3.5 intake, 3 port, test pipe, internals, cpe TMIC gutted stock DP, egr delete, TB bypass
Tune - 50/50 E85 tune
Description - Slipping in 4th and 5th mainly from 4-5K rpms
tornado842
Year - 2013
Miles - 11,000
Mods - fully bolted/BNR S3
Tune - ?
Description - Slipped in every gear for a few days after trying out my new hoosier slicks.
Phoenix
Year - 2011
Miles - 51,000
Mods - internals, intake
Tune - 18 psi tune
Description - Run through 6th, the pedal worked normally, but the clutch would not disingage, was still not able to get it into first with the engine on
CWP_MS3
Year - 2012
Miles - 29K
Mods - Bolted
Tune - E85
Description - started slipping when cold in 4th and 5th.
Adamizme
Miles - 38K
Mods - CS SRI/TIP, CS Racepipe, CS TMIC, CS CAB, NGK plugs, Internals
Tune - 93 Freek
Description - Slipped badly for a few days in 3rd+. A few days of mild driving and then tested again to find it was no longer slipping.
5doorsoffury
Year - 2012
Miles - 22,000
Mods - in sig (intake +mani) test pipe e85 etune
Tune - Finkle!!!!!!! e85
Description - Slipping in 5th
Current Build:
Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly
JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune
PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs
Sold:
2008.5 Black Mica GenWon - Fully Bolted
abiezerf is offline   Reply With Quote
The Following 9 Users Say Thank You to abiezerf For This Useful Post:
5doorsoffury (01-14-2014), ABolewski (01-15-2014), adamizme (01-13-2014), Cevaes_64 (03-04-2014), CWP_MS3 (01-13-2014), kidlifecrisis (01-13-2014), redneck4Christ (01-13-2014), Roddiy (04-05-2014), someguy (01-10-2014)
Am I joining the clutch failure group? someguy 2010 MS3 - Engine, Transmission & Driveline 6 01-08-2014 07:54 AM
Speed 3 clutch failure - low miles Mazdamatt222 MazdaSpeed 3 - Engine, Transmission & Driveline 17 04-06-2013 05:35 PM
Clutch Failure/clutchmaster review laxplayermjd MazdaSpeed 3 - Engine, Transmission & Driveline 22 06-14-2012 03:19 PM
Clutch Failure at 5K ASHMS3 2010 MS3 - Engine, Transmission & Driveline 27 12-19-2011 11:02 AM
***Official VVT acuator failure thread/database*** Raider MazdaSpeed 3/6 - Troubleshoot/Diagnostics 1 09-26-2011 05:58 PM
Page generated in 0.67033 seconds with 41 queries
