![]() Join Date: Feb 2011 Location: Miami, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 114
Groans: 46
(Thread Starter) | Not Ranked : 0 score I'l start. abiezerf Year - 2012 Miles - 19,000 Mods - Intake, Short Shift Plate, Test Pipe, Internals Tune - 25% e85 tune Description - Slipping in 4th and 5th gear around 4K RPMs kidlifecrisis Year - 2012 Miles - 17,500 Mods - intake, catted dp, catback, internals Tune - 93 octane tuned by the freek Description - Slipped in 4th and above at about 3500 rpm for a few weeks in Nov and Dec SomeGuy Year - 2010 Miles - 43,000 km (26,000 miles) Mods - fully bolted Tune - Self Tuned on 94 (approx. 320-330wtq) Description - Slipping from 3-4k rpm range in various gears printman Year - 2012 Miles - 18,000 Mods - test pipe, internals Tune - e85 blend Description - slipped once last week in 4th around 4500 rpms doing a log specvspeedfreak Year - 2011 Miles - 31,000 Mods - 3.5 intake, 3 port, test pipe, internals, cpe TMIC gutted stock DP, egr delete, TB bypass Tune - 50/50 E85 tune Description - Slipping in 4th and 5th mainly from 4-5K rpms tornado842 Year - 2013 Miles - 11,000 Mods - fully bolted/BNR S3 Tune - ? Description - Slipped in every gear for a few days after trying out my new hoosier slicks. Phoenix Year - 2011 Miles - 51,000 Mods - internals, intake Tune - 18 psi tune Description - Run through 6th, the pedal worked normally, but the clutch would not disingage, was still not able to get it into first with the engine on CWP_MS3 Year - 2012 Miles - 29K Mods - Bolted Tune - E85 Description - started slipping when cold in 4th and 5th. Adamizme Miles - 38K Mods - CS SRI/TIP, CS Racepipe, CS TMIC, CS CAB, NGK plugs, Internals Tune - 93 Freek Description - Slipped badly for a few days in 3rd+. A few days of mild driving and then tested again to find it was no longer slipping. 5doorsoffury Year - 2012 Miles - 22,000 Mods - in sig (intake +mani) test pipe e85 etune Tune - Finkle!!!!!!! e85 Description - Slipping in 5th
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted Last edited by abiezerf; 01-14-2014 at 10:14 AM. |
| The Following 9 Users Say Thank You to abiezerf For This Useful Post: | 5doorsoffury (01-14-2014), ABolewski (01-15-2014), adamizme (01-13-2014), Cevaes_64 (03-04-2014), CWP_MS3 (01-13-2014), kidlifecrisis (01-13-2014), redneck4Christ (01-13-2014), Roddiy (04-05-2014), someguy (01-10-2014) |
![]() Join Date: May 2012 Location: Austin TX
Rep Power: 342 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 343
| Not Ranked : 0 score 2012, 17.5k miles, intake, catted dp, catback, internals, 93 octane tuned by the freek. Slipped in 4th and above at about 3500 rpm for a few weeks in Nov and Dec, been driving like a sane person since and have done several 4th gear pulls since without issue. Might be okay now? Not really sure |
![]() Join Date: Jan 2012 Location: Mesa, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 620
| Not Ranked : 0 score Damn, such low miles! |
![]() Join Date: Sep 2011 Location: Canada
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 213
| Not Ranked : 0 score SomeGuy - 2010 - 43,000km - 3-4k rpm range in various gears - Mods in sig but basically fully bolted. Also from my thread on the topic including logs of it happening:
__________________ - 2010 Mazdaspeed 3 Black Mica - - Cobb AP - Self Tuned - cpe HPFP - cpe DP - CS 3" SRI - cpe TMIC - Forge BPV v2 - Grimmspeed EBCS - Denso ITV22 - - SouthBend Stage 3 Daily Clutch - cpe RMM - CS TMM Insert - TWM SB - CS SSP & SW - CS RSB & Mid Chassis Brace - - CS Brake Pads - Michelin Pilot Super Sport - CS Boost Tubes - CS Fog, DRL and Interior LEDs - Horns - Grounds - 20% Tint - | |
![]() Join Date: Jul 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 301
![]() Join Date: Feb 2012 Location: Gibsonville, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 100
| Not Ranked : 0 score 18,000 mi. mods in sig had it slip once last week in 4th around 4500 rpms doing a log. I went WTF but hasn't done it since so who knows if clutch is really going bad or just a fluke. Been reading the clutch install how to's just in case might go ahead and order the ACT 6 puck when tax money comes in so I have it if it really is going bad.
__________________ [SIGPIC] [/SIGPIC] 2012 Black Mica W/Tech Cobb AP AutoTech Internals JBR 88DM RMMJBR Heavy Knob JBR 3" WP JBR Rear camber arms UR TP Ford MOFO Tranny juice Rotella T6 Self Tune - (Work in Process) NGK Step 1 colder 5/7 corn fed |
![]() Join Date: May 2011 Location: Chicago Illinois
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 508
| Not Ranked : 0 score so far seems like only 2010 and 12
__________________ 2013 Velocity red Mazdaspeed 3 tech. BT 2011 Velocity red Mazdaspeed 3-SOLD. FreeKtuned fitty fitty |
![]() Join Date: Oct 2008 Location: Carson, CA
Rep Power: 977 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 168
| Not Ranked : 0 score lol 2011 close to 31K miles. 50/50 E85 tune. 3.5 intake, 3 port, test pipe, internals, cpe TMIC gutted stock DP, egr delete, TB bypass. Slipping in 4th and 5th mainly from 4-5K rpms but need to get logs to verify.
__________________ *COBB: AP, shifter weight *BITWISE: Harness, 3bar BNR: S3v2 *CP-e: Stage 2 RMM ,TMIC *JBR: RSB, EGR delete, WP *GRIMMSPEED: EBCS *TWM: Full Shifter *KDM: HPFP internals *DENSO:ITV22 *FORD: syn trans fluid *OBX: TBE *BILSTEIN: B8 Sport *SWIFT: Spec-R springs *GTSPEC: 4point ladder brace, rear subframe brace *NITTO: NT-05 * Whiteline: BSK *MOOG: F/R endlinks* SPC: Adj. camber arms *MORIMOTO: 5K HID elite |
![]() Join Date: Apr 2012 Location: port orchard, w.a
Rep Power: 501 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 655
| Not Ranked : 0 score Wow such low miles. I would check to make sure no oil or anything is getting on the clutch. I have an 08 with 60k fully bolted and i have never slippec
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned |
![]() Join Date: Dec 2009 Location: camas valley
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,720
Groans: 40
| Not Ranked : 0 score lost mine about 60k shit clutch
__________________ BT T3 .5557 @25 psi 10. 6:1 peformance3 pistons, manley rods arp 625+ rod bolts, arp L19 head studs, Ap, 4'' inlet rr mani 4'' custom inlet, ,2.5'' ic piping, treadstone intercooler tr10 , turbosmart bov , tail 44mm wg, cobb electronic boost control 1 3/4 screamer p, odyssey batt, cs racepipe, custom 3'' dp 80mm cat back 80mm, egr del, vcts del, and port matched,sure tig's, running 100% meth 2000 cc, ATC 6 puck sl fw 472 hp 461tq virtual dyno and ran out of fuel! nishan said theirs a easy 550 in the setup if i had the fuel but meh... 54,000 miles big turbo! stock block at 104000 2 bent rods current miles 113000 and runs perfect! no hiccups! tuned by nishan |
| Not Ranked : 0 score Why do u feel the need to tell me that lol i wanted a big turbo with tax refund not a new clutch :/ Plus 60k wouldnt be too bad when u think about it i am putting down 100 more tq then stock
__________________ COBB ACCESSPORT//TURBOXS CATLESS DP+RACEPIPE//3 BAR MAP//3.5" HTP INTAKE//NGK 1 STEP COLDER PLUGS//HKS CATBACK//AUTOTECH INTERNALS//COBB FMIC V2.0//HKS BOV BLACK EDITION IN VTA//RPF1 17x9//pilot super sport 245/45/17//ACT 6 PUCK//M.D OCC VTA//TOKAY SEALS//BNR S4//Hypnotic tuned Last edited by blackms3_71; 01-10-2014 at 09:15 PM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Aug 2012 Location: San Mateo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,022
| Not Ranked : 0 score I have 9300 miles on mine and there have been several times that I thought the clutch was slipping... upon investigating and plugging a few logged instances into VD and datazap I found that it wasn't clutch slip it was wheelspin. You can see that there is a a direct correlation between rpm and vehicle speed and you can see the bump where I break loose. I've done this both in 3rd and 4th gear and there was never the typical tire "screetch" people often expect when you break loose... the only indication was a sudden rise in rpms and no increase in speed. Anyhow, not saying that you folks aren't experiencing blown clutches just that you should be absolutely certain before you start to panic.
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 Last edited by jseams; 01-10-2014 at 09:53 PM. |
| The Following 3 Users Say Thank You to jseams For This Useful Post: |
| Not Ranked : 0 score Breaking loose feels so much different than clutch slip...the tires don't always make noise, depends on road surface and heat and such. Mine if you look at the logs, rpm/speed don't stay constant.
However, I disagree that it always feels different; there are always threads popping up where people are asking "wheelspin or clutchslip"... I know, I'm guilty of this myself. lol
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 | |
| Not Ranked : 0 score Now I'm really confused. It didn't slip or spin? like it has before. Maybe I was just crazy... I don't know lol some logs Not sure what happened in datalog 3.. Edit: think it was a bump now that I think about it datalog5.csv datalog2.csv datalog3.csv
![]() Join Date: Aug 2012 Location: Plano, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 27
| Not Ranked : 0 score 2013 11K miles. Slipped in every gear for a few days after trying out my new hoosier slicks. 334hp 377tq. After driving it softly for a few weeks it is no longer slipping. I had a 07 speed 3 for 40k miles without ever having the clutch slip. I have the new clutch/flywheel sitting in my garage waiting for this one to die.
__________________ 2013 Speed3- Autotech HPFP-FORGE BPV- JBR 3.5 Intake - JBR FMIC -CorkSport Catback - GTX3076 *"Other stuff" 1995 Chevy 6.5 k2500- 18PSI - still slow |
![]() Join Date: Jul 2011 Location: Plantation, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 6,748
Groans: 97
__________________ TEAM LUXURY Last edited by Sid3wayS; 01-13-2014 at 11:40 AM. |
| The Following User Says Thank You to Sid3wayS For This Useful Post: | mtosofsky (01-11-2014) |
| Hide Yo Kids-No really, Hide them! ![]() Join Date: Oct 2011 Location: PMITA Jail until 12/2015
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,515
Groans: 77
| Not Ranked : 0 score There were a few cases local here. A 2011 fully bolted w slipping around 30k 2012 w 3076 and 15k 2012 fully bolted, 7k |
| The Following User Says Thank You to Voltron For This Useful Post: | blackms3_71 (01-11-2014) |
![]() | | #19 | ![]() |
| Not Ranked : 0 score Is there a correlation between all of these cases?
![]() | | #20 | ![]() |
| Not Ranked : 0 score Yeah big power lol
| The Following 2 Users Say Thank You to blackms3_71 For This Useful Post: | J'sSpeed3 (04-02-2014), killer-ms3 (01-13-2014) |
![]() | | #21 | ![]() |
Groans: 46
(Thread Starter) | Not Ranked : 0 score Lol I'll update the op in a few but modded cars seem to be the correlation. Oddly enough, I, too, did some more fourth and fifth gear pulls today and I did not slip. Not even once. I was going to adjust my SSP to the middle setting but now I think I'll leave it as is. Sent from my XT1056 using Tapatalk
__________________ Current Build: Liquid Silver Metallic Pu - JBR Shifter Bushings, Cobb AP, JBR Chome Molly JBR SSP, ProSport Premium Boost Gauge, 25% e85 Tune PTP HPFP Internals, CorkSport Intake/TIP, Cobb Sport Springs Sold: 2008.5 Black Mica GenWon - Fully Bolted |
![]() | | #22 | ![]() |
![]() Join Date: May 2013 Location: Fort Worth, TX
Rep Power: 0 ![]() Thanks: 1
| Not Ranked : 0 score 6800mi all stock. Just had my 2013 towed to the dealer. The pedal went to the floor while shifting normally. They let me look into the inspection hole and it was full of shredded clutch material. They will be submitting it to Madza. |
![]() | | #23 | ![]() |
| Not Ranked : 0 score Damn, that's a failure...not quite what this thread is about but madness. At least yours is almost guaranteed to be covered.
![]() | | #24 | ![]() |
| Not Ranked : 0 score It's a silver pu conspiracy! lol
![]() | | #25 | ![]() |
![]() Join Date: Oct 2012 Location: Long Beach, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 255
| Not Ranked : 0 score seems like a pu problem. My stocker started slipping at 96k miles after the bnr.
__________________ Bnr s3/Act 6 puck/sure full 3inch intake/cobb fmic/cobb downpipe/grimmspeed ebc/3 bar map/hks catback/autotech hpfp internals/turbosmart bpv/bc coilovers/jbr trilogy mounts/ngk one step colder plugs/ms6 rims on nt-01 tires. 24 psi E85 freektuned. Freektuned e85 Focus st as the daily. |
| The Following 3 Users Say Thank You to boostdmazda3 For This Useful Post: |
![]() | | #26 | ![]() |
| Not Ranked : 0 score Yeah, they gave me the speech about the clutch being a 'wear item', but also acknowledged that it would be pretty hard to kill a clutch that fast even with the worst abuse. I'm over 40 and never driven anything but a standard. I know how to take care of a clutch. |
![]() | | #27 | ![]() |
Groans: 46
(Thread Starter) | Not Ranked : 0 score Updated the OP, looks like the clutch slipping is a power issue mixed with the weather. Mine stopped slipping now that the weather has heated up. A few others have reported the same.
![]() | | #28 | ![]() |
![]() Join Date: Apr 2011 Location: Anna, TX
| Neutral : +1 score Mine took a dump Friday night. Was making a run through 6th and once I went to exit, the pedal worked normally, but the clutch would not disingage. Had to make it home rev matching and trying not to come to a stop. Waited a couple of hours and was still not able to get it into first with the engine on. I suspect that the clutch was probably slipping just enough to cause a tremendous amount of heat and destroy the diaphram spring in the pressure plate. I have 51k, 2011, internals, Sure 3" Aeros, internals and AP. Boost target is 18 psi. It's being towed to the shop today and will most likely find out tomorrow.
__________________ SURE Full3 Aeros - UR DP - Test pipe - Magnaflow catback - RMM - Autotech internals - AP self tuned - 3 Port EBCS |
![]() | | #29 | ![]() |
| hidin in yo bushes ![]() Join Date: Mar 2012 Location: Soviet Maryland
Rep Power: 6573 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10,956
Groans: 122
| You need to find a better way to organize the OP @abiezerf;. Too difficult to read. I think bolt-ons matter less than whether or not they're custom tuned. Make them all follow the same format and space them or something. Like this maybe: CWP_MS3 Miles - 29K Mods - Bolted Tune - E85 Description - started slipping when cold in 4th and 5th. ^^^ Just a suggestion.
__________________ CP-e S2 RMM // TurbineTech FMM // Ghetto SRI // 3" ATP MAF housing // Ultimate Racing CBE // Ebay Downpipe // Cobb AP // Autotechs // PG TIP // HKS V4 BOV // NGK Iridiums // ACT Street Disc // JBR Trans Mount Rich Tuned 330WHP and 363TQ 10-19-13 Moore Automotive ![]() |
![]() | | #30 | ![]() |
Groans: 46
(Thread Starter) | Not Ranked : 0 score Makes sense. Thanks. Updating now
![]() | | #31 | ![]() |
Groans: 122
| Lol... So far the only consistency I'm seeing is mad power. Most people on that list are E85.
![]() | | #32 | ![]() |
| Not Ranked : 0 score Not me...I'm self tuned on 94, approx in the 320-330 wheel torque range.
![]() | | #33 | ![]() |
| Not Ranked : 0 score I put down 291 whp on the mustang dyno at Powerplant Motorsports in Poughkeepsie, the consensus was that the dyno was pretty spot on with how a dyno jet would have read based on the other speeds that got on the rollers that day |
![]() | | #34 | ![]() |
Groans: 122
| How much torque?
![]() | | #35 | ![]() |
| Not Ranked : 0 score 303 |
![]() | | #36 | ![]() |
![]() Join Date: Sep 2011 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 402
| Not Ranked : 0 score Subbed... mine slipped badly on Christmas eve in 5th gear. For a few days after that, it was slipping in 3rd+. It hasn't slipped at all for a couple weeks now. Mods in sig. 38k miles. Tuned for 93 by Freek. Adamizme Miles - 38K Mods - CS SRI/TIP, CS Racepipe, CS TMIC, CS CAB, NGK plugs, Internals Tune - 93 Freek Description - Slipped badly for a few days in 3rd+. A few days of mild driving and then tested again to find it was no longer slipping.
__________________ 2012 Mazdaspeed 3 w/ tech package CS LED Kit & Fogs - *painted* CF hood - VG Sharkfin antenna - CS TMM insert - DM PMM - CPe S2 RMM - Cobb AP - JBR True 3" intake - Autotech FP Internals - JBR RSB - CS Racepipe - CS SSB - JBR Short Shifter - CS SSP & weight - Motocraft tranny fluid - CS TMIC - NGK plugs - modified CS Cold Air Box - JBR EGR delete - CS OCC - DO WMI kit w/ d05 - DM TB spacer - CS BPV - KW v1 Coilovers - Whiteline adjustable endlinks - SPC camber arms - tons of GTSpec braces - Whiteline bump steer kit - Wilwood 6 pot front calipers w/ Wilwood slotted rotors - mz5 rear slotted rotors & brackets - front & rear SS brake lines - Freek tune Last edited by adamizme; 01-13-2014 at 01:27 PM. Reason: Added info in correct format |
![]() | | #37 | ![]() |
Groans: 122
| Guys post up accordingly so he can just cut and paste it to the OP. If you want to add more to it in your post, then do so, but make it easy for him to keep the OP up.
![]() | | #38 | ![]() |
| Not Ranked : 0 score SomeGuy Year - 2010 Miles - 43,000 km (26,000 miles) Mods - fully bolted Tune - Self Tuned on 94 (approx. 320-330wtq) Description - Slipping from 3-4k rpm range in various gears
![]() | | #39 | ![]() |
Groans: 46
(Thread Starter) | Not Ranked : 0 score Updated the OP some more. I guess the Pu's don't like cold and torque.
![]() | | #40 | ![]() |
![]() Join Date: Feb 2012 Location: Li ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,290
Groans: 74
| Not Ranked : 0 score 5doorsoffury mods in sig. 2012 PU .Slipped in 5th after at about 22k roughly 13 k on e85. Has not slipped under stock power (that i can see with out logging). ugg sry heres the cut and paste 5doorsoffury Year - 2012 Miles - 22000 miles Mods - in sig (intake +mani) test pipe e85 etune Tune - Finkle!!!!!!! e85 Description - Slipping in 5th
__________________ MECP 2012 BM PTE 5858 Vband .82ar // Tial EWG // CPE Mani // 3" Turboback // JBR Under route hot pipe // MD ST mani+spacer with PI // Siemens 60lb Injectors // Splitsecond inj controller // JBR 88 duro RMM/TMM // MD PMM // TWM Full replacement shifter // JBR CC // Autotech FP Internals // SP63 SB/Manley rods SP63 pro pistons // Treadstone FMIC TR824 // FoMoCo Tranny Jizz // South Bend Clutch Stage 3 enduro// GFB Respons // FJ 4" intake // WMI 100% VPM1 // Air Lift 1000 in rear // N2MB WOT BOX Rfinkle tune in progress The Brooklyn beater: 2005 1.8 Auto Sentra |
| Display Modes | |
| Am I joining the clutch failure group? | someguy | 2010 MS3 - Engine, Transmission & Driveline | 6 | 01-08-2014 07:54 AM |
| Speed 3 clutch failure - low miles | Mazdamatt222 | MazdaSpeed 3 - Engine, Transmission & Driveline | 17 | 04-06-2013 05:35 PM |
| Clutch Failure/clutchmaster review | laxplayermjd | MazdaSpeed 3 - Engine, Transmission & Driveline | 22 | 06-14-2012 03:19 PM |
| Clutch Failure at 5K | ASHMS3 | 2010 MS3 - Engine, Transmission & Driveline | 27 | 12-19-2011 11:02 AM |
| ***Official VVT acuator failure thread/database*** | Raider | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 1 | 09-26-2011 05:58 PM |
