![]() Join Date: Dec 2015
Rep Power: 0 ![]() Thanks: 2
(Thread Starter) | Not Ranked : 0 score I drive 2013 Speed3 with the Tech package. For the past week when I try to start the car it's acting as though the clutch pedal isn't pushed in although it is. If I manually go down to my clutch pedal and press the clutch switch and press the start button the car starts. It appears as though the clutch is traveling 9/10 of the way but isn't traveling that last 1/10th of the way to fully engage the clutch pedal switch. I made sure the switch is fastened into its bracket correctly. Any ideas would be greatly appreciated. I don't know if we can adjust our clutch pedals or not or why this would happen. I haven't noticed any issues when driving. The clutch doesn't seem to be slipping or anything like that. Thank you in advance for the help. |
Groans: 60
| Not Ranked : 0 score Is the rubber bumper still on the pedal? They get brittle and break off and the switch is now 1/4" too short. Google pedal bump stop.
| Clutch not engaging while running | qMazdaspeed3p | MazdaSpeed 3 - Engine, Transmission & Driveline | 25 | 04-07-2018 05:38 PM |
| Cracked clutch pedal bracket caused pedal to crack firewall which pierced my master cylinder | Marcus | Mazdaspeed3/6 General Discussion | 0 | 10-17-2015 06:14 AM |
| Clutch Not Engaging | Cheapspeed | MazdaSpeed 3 - Engine, Transmission & Driveline | 8 | 10-05-2015 02:41 PM |
| Oem clutch/Fidanza Flywheel, Causing sticky clutch pedal? | Douggievee | MazdaSpeed 6 - Engine, Transmission & Driveline | 14 | 05-14-2015 10:44 AM |
| MS6 clutch pedal | Turbosuby | Mazdaspeed3/6 General Discussion | 10 | 04-16-2013 08:25 PM |
