 Old 07-14-2015, 03:43 PM   #1
iammike's Avatar
Posts: 1,415   (View Stats)
Default Coolant Temp
This is probably a really dumb question and my searching leads me to believe this is ok...but I want to confirm.
I see similar situations regularly...but I will describe today's.
It was between 90-95 degrees during my drive home today. At around 60-65MPH the car was hovering between 199 and 205 degrees. When I got on a side road and slowed down to 40-45MPH, the temp then stayed around 198-202. When I got home, I just let the car idle for 3 or 4 minutes in the parking lot and it stayed around 198. AC was on the entire time and I do have a FMIC....Cobb's to be precise.
Now, my thoughts would be that temps at 60+MPH would be lower and would hopefully be close to the typical 190ish. Do others normally see a sustained temp of up to 205 while on a highway? Additionally, I expected the temps to rise noticeably when I parked...but they didn't.
Coolant level is good, has been burped to ensure no air, and has about 43k miles on it.
I think I'm ok but want to be sure before I drop in the CorkSport turbo and start getting tuned and junk.
Mike
 Old 07-14-2015, 04:51 PM   #2
nekret's Avatar
Posts: 421   (View Stats)
I usually see 180-190 when running about in the summer with the occasional 200... sounds pretty normal.
Drivetrain
Chassis
Rice
 Old 07-14-2015, 11:24 PM   #3
Bob-o's Avatar
Posts: 1,312   (View Stats)
I run at 217 when in traffic
I too have a COBB fmic
EWG GTX3071 | PERM 3.5" intake | COBB FMIC | CP-e injector seals | UR downpipe | CS testpipe | HKS catback | KW V1's | Blahblahblah
 Old 07-14-2015, 11:36 PM   #4
NCZ13's Avatar
Posts: 1,268   (View Stats)
Normal. wouldnt sweat it.
2008 Cosmic Blue Mazdaspeed3
1986 Mazda RX7
 Old 07-15-2015, 05:24 AM   #5
mize13's Avatar
Posts: 786   (View Stats)
mize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the worldmize13 is the leader of the world
Hot temps + FMIC core in front of radiator heating up and impeding air flow. You're fine.
For reference, I typically see 180 on the highway in the summer and 190 on the highway in the winter.
2013 Liquid Silver Metallic MS3
GTX2867 ; Cobb AP v3 ; Cobb Turboback Exhaust ; Cobb EBCS ; Swift Springs ; Koni Yellows ; SPC Camber Arms ; Aquamist HFS-4 WMI ; Relentless Customs PNP IM ; ETS TMIC ; HTP Full 3.5" Intake ; HTP Battery Tray ; CS BPV ; CS Mid-Chassis Brace ; CS TMM Insert ; AT Internals ; JBR 88 Duro RMM ; DM PMM ; JBR OCC ; JBR IM & TB TIGs ; JBR EGR Blockoff Plate ; JBR 0.125 RSB & Tru-Torsion RSB Billet Brackets ; NGK Step Colder Plugs ; Bosch 3 Bar Map ; Block8head Dual Gauge Vent Pod ; Dual Aeroforce Interceptors ; Stoptech SS Brake Lines & Centric Blanks ; EBC Yellowstuff ; MOOG Endlinks
TunedbyNishan
mize13 is offline   Reply With Quote
 Old 08-17-2015, 09:13 PM   #6
patABQ's Avatar
Posts: 164   (View Stats)
patABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond reputepatABQ has a reputation beyond repute
You actually need over 200 occasionally to "burn off" volatiles out of the oil. I have seen over 220 on hot days at altitude. Normal
Silver 2012 MS3 , 2007 Corvette Z06 , 2008 Hayabusa
MS3 Mods
Sure PMM, DMM, REM (all TORQ S3 Street in Stealth Black), Sure Sway Bar, JBR Sort Shifter
Cobb - AP V3 SRI, TIH, 3-port Boost Controller, SS 3” DP
Corksport TMIC
CP-E full HPFP with warranty
All Freektuned with two tunes, one for 15psi and another at 20psi
patABQ is offline   Reply With Quote
 Old 09-06-2015, 12:13 PM   #7
suparobg's Avatar
Posts: 181   (View Stats)
suparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond reputesuparobg has a reputation beyond repute
I regularly get 185-190 on highway driving but when stuck in traffic goes up to 217 -220
I don't have a FMIC
JBR TRU 3" aluminum intake// Autotech Internals// COBB AP// ETS TMIC // UR downpipe//UR Test pipe// NGK One step colder plugs//JBR Double Adjustable Short Shifter with solid bushings // COBB RMM//JBR PSMM//Corksport Transmission Mount Insert// coolant bypass // JBR TB and intake manifold gasket// EGR block off JBR // Cooling Mist Stage 2 methanol system// //UR CBE straight pipe// Custom tune by Mike at Stratified both 91 and 94 octane + 91 with meth
CS carbon fibre hood scoop and carbon fibre rear spoiler.//CS ECU relocation battery box// CS hood struts//
suparobg is offline   Reply With Quote
 Old 09-06-2015, 12:48 PM   #8
iammike's Avatar
I don't have a FMIC
I have never, not once, seen 217 even with my FMIC. How old is your MS3? Does it need new coolant?
Mike
 Old 09-06-2015, 01:12 PM   #9
suparobg's Avatar
2011 with 95000 km's
I could have been mistaken maybe it was only 212 or so I have a bad memory
coolant change wouldn't be a bad idea.
 Old 09-06-2015, 03:13 PM   #10
iammike's Avatar
You have 16k more miles than me so about 26k more km's. Then again, while I haven't had a full fluid change, with the turbo upgrade about 50% of my fluid was drained and replaced with new.
Mike
 Old 09-06-2015, 12:23 PM   #11
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
fans come on at 217
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
 Old 09-07-2015, 04:24 PM   #12
capblueberry's Avatar
Posts: 134   (View Stats)
capblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud ofcapblueberry has much to be proud of
Cruising around Torque tells me I hang around 185 or so
capblueberry is offline   Reply With Quote
 Old 09-07-2015, 05:11 PM   #13
maisonvi's Avatar
Posts: 3,490   (View Stats)
Groans: 75
My new engine hits 187-190 while crusing on the highway, but if I get stuck in traffic it goes up to 217 when the fans turn on. Stays there till I get moving solidly again.
Never had an issue on my last engine. I am built and run a tr1035 ic core. I'm hoping ducting helps, but I wonder if it's something more. The rad has 100k Miles on it
Coolant temp issues dubunderpar MazdaSpeed 3/6 - Troubleshoot/Diagnostics 25 01-26-2016 07:55 PM
Coolant temp, thermostat hahaitzskippy CX-7 > Issues & Troubleshooting 8 06-28-2014 05:54 AM
Cobb AP as a coolant temp gauge? stockae92 Gen2 MS3 General Discussion 4 11-04-2011 12:08 AM
CX-7 coolant temp high... bzwyatt CX-7 > Issues & Troubleshooting 8 06-14-2011 04:42 AM
Page generated in 0.34433 seconds with 29 queries
