 Old 01-05-2012, 01:18 AM   #1
infeKteDx's Avatar
Posts: 385   (View Stats)
infeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the worldinfeKteDx is the leader of the world
Groaned at 46 Times in 20 Posts
Default Downpipes, which did you go with?
Just like it says, did you guys go with just the upper downpipe, or did you get something like the ATP setup:
ATP 3" Long Downpipe - Mazdaspeed3—|—MazdaSpeed3 Exhaust—|—MazdaSpeed 3—|—Mazdaspeed Parts - Mazda Speed Store
Which do you find easier to deal with?
I ask because I want to get rid of both cats, but is it necessary to get rid of the lower downpipe as well?
I don't think I'm understanding the way this exhaust works lol. Is the upper / lower downpipe BOTH cats? or does the secondary cat come later?
infeKteDx is offline   Reply With Quote
 Old 01-05-2012, 01:33 AM   #2
Postulio4joo's Avatar
Posts: 284   (View Stats)
Postulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the worldPostulio4joo is the leader of the world
Groaned at 14 Times in 6 Posts
The 2nd cat is removed with a test pipe. The DP i believe contains the primary. I had a ATP test pipe until i recently purchased a CNT full pipe. No cats in CA is the way to roll.
Postulio4joo is offline   Reply With Quote
 Old 01-05-2012, 01:49 AM   #3
infeKteDx's Avatar
so does it go like this:
upper restrictive DP -- lower DP (with first catt) -- secondary catt -- catt back exhaust?
 Old 01-05-2012, 05:03 AM   #4
Jake5713's Avatar
Posts: 1,775   (View Stats)
no
the first cat is in the downpipe
the second cat is in the test pipe section
both are restrictive
then catback
basically the same exact thing as this
The Following User Says Thank You to Jake5713 For This Useful Post:
MS3inDC (01-05-2012)
 Old 01-05-2012, 06:01 AM   #5
MS3inDC's Avatar
Posts: 3,070   (View Stats)
MS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the worldMS3inDC is the leader of the world
Groaned at 56 Times in 37 Posts
Full-Race two-piece vband dp...?
If you want flexibility, get the shorty dp and a tp. You can add a resonator/high-flow cat if you want, or leave it castless.
If your not going to mess with it again get the long dp. You can have a high-flow cat welded in if you want pre-install. But it's harder to swap out if you plan on a lot of switching... well, harder if you have no lift or air tools
cobb ap v3 // RICHTUNE // autotech fpi // sp63 afc // cp-e nano // htp tip // nator dc fmic // nator dc PnP intake mani // hks ssqv *vta* // cs dp // su tp
jbr rmm(88duro) // jbr pmm(80duro) // cpe tm(75duro) // act 6-puck // act streetlite fw // jbr egr delete // md occ // sure ssb // nator dc sts // jbr hw shift knob
ebc red // rx-8s wrapped in conti dws 235/40s (winter) evo Xs wrapped in conti dw 235/40s (summer) www.sonictuning.com
311 whp - 345 lb/ft : Dynojet @ Moore Automotive *93 pump [4/13/13 MNM]
12.94 @ 109.00 @ Capitol Raceway *18' ASL [11/07/14]
I would wear a pink unicorn shirt, and still call someone a faggot. Since when did MSFers begin to give fucks?...
MS3inDC is offline   Reply With Quote
 Old 01-05-2012, 06:10 AM   #6
Sid3wayS's Avatar
Posts: 6,790   (View Stats)
Groans: 97
You would understand if you search and read.
Here: http://www.mazdaspeedforum.org/forum/foru...-thread-99627/
TEAM LUXURY
The Following User Says Thank You to Sid3wayS For This Useful Post:
SLOWHATCH (01-05-2012)
Downpipes Matx MazdaSpeed 6 - Engine, Transmission & Driveline 8 06-13-2010 07:38 PM
Downpipes, which one should I get? julioroman 2010 MS3 - Turbo Induction 16 05-13-2010 04:21 PM
Downpipes dkspeed MazdaSpeed 3 - Engine, Transmission & Driveline 50 02-26-2010 06:25 PM
downpipes pvms3g MazdaSpeed 3 - Engine, Transmission & Driveline 12 05-21-2009 01:04 PM
CPE downpipes phailerider Custom Performance Engineering (cp-e.com) 27 11-25-2008 10:58 AM
Page generated in 0.27113 seconds with 25 queries
