 Old 06-13-2019, 04:37 PM   #1
intrigueturbo's Avatar
Posts: 53   (View Stats)
intrigueturbo is a jewel in the roughintrigueturbo is a jewel in the roughintrigueturbo is a jewel in the roughintrigueturbo is a jewel in the rough
Default EGR problem with no CEL?
Sometimes my 2012 doesn't start as strongly as others. Cranks for a bit, starts very weak, but then eventually runs normally. Sounds like an EGR problem from what I've read but I've never gotten the P0401 code. Could it still be an EGR problem without it throwing a CEL?
Cobb AP // Stratified Stage 2 Flash Tune // CP-E Nano SRI // Corksport TMIC // AutoTech HPFP Internals // CP-E RMM
intrigueturbo is offline   Reply With Quote
 Old 06-13-2019, 08:16 PM   #2
Police - Grammarhead
Vansquish's Avatar
Have you tested the battery?
 Old 06-13-2019, 08:54 PM   #3
Yeah the battery is almost brand new and I replaced the plugs recently also. I've had the problem off and on for a couple years at this point. Car has never actually not started and it's never given me a CEL for it.
When I first started noticing it I cleaned the MAF sensor, changed plugs, replaced the battery, none of it helped. It has been happening more and more over the last couple years.
Problem after problem: Running rich & Fuel cuts wherewuat 2010 MS3 - Troubleshoot/Diagnostics 30 01-30-2014 02:13 PM
HID Problem I think MazdaSpeedBoi 2010 MS3 - Troubleshoot/Diagnostics 3 01-18-2014 10:35 PM
having a problem with my bov akagrrrr MazdaSpeed 3/6 - Troubleshoot/Diagnostics 13 03-09-2010 05:03 PM
ATP DP problem dgoed82 MazdaSpeed 3/6 - Turbo Induction 9 11-25-2009 08:17 PM
Page generated in 0.24406 seconds with 21 queries
