![]() Join Date: Jun 2009
| Not Ranked : 0 score
Might be better to remove the belt and just spin the idler with the engine off and see if it rattles or wobbles. It’s a cheap part. If it’s never been replaced, it’s probably long overdue.
| FR wheel noise | JMPS3 | Gen2 MS3 General Discussion | 1 | 07-08-2019 10:46 AM |
| Throttle noise/ engine noise | under28world | 2010 MS3 - Engine, Transmission & Driveline | 9 | 05-04-2015 06:25 PM |
| bearing noise vs wheel noise? | drag0nfire | Mazdaspeed3/6 General Discussion | 14 | 06-20-2012 07:32 PM |
| Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's | Haltech | Automotive News | 0 | 03-13-2009 03:30 PM |
| Wheel hop noise? | Speedn3 | MazdaSpeed 3 - Engine, Transmission & Driveline | 6 | 10-02-2008 04:34 PM |
