Engine noise, near right wheel, Hello I have Mazda 3 MPS 2 gen, motor was build one years ago. I drove few thousands kilometers and recently heard strange noise. I used for build CP pistons, Manley rods, delete dualmass, balance shafts, install FMIC, custom intake, hybrid turbo. Please watch: https://vimeo.com/384597910?utm_sour...campaign=28749 When the engine is cold after minute I hear tick noise next to right wheel. Under scoop all sounds normal, only there. After 5 minutes, when the engine work, noise disappears. When the engine is hot, after few kilometers tick noisy is softly. In my opinion: - it can't be piston slap because under scoop is silent - injector seals was change - chain belt also, because install new timming kit when the motor was build, I can't hear noises next to engine cover - if it rod or main bearings noise will be louder when engine is hot, not like cold - gearbox and ACT clutch noise is different and it hear only driver side - alternator is regenerated with new tensioner - A/C clutch doesn't change sound when it on/off - under the car, applying the stethoscope to the oil pan, I can't hear anything What do you think about it? What I should check? ps. Sorry about my avarage English |
Link does not work for me. Maybe it is the idler pulley on the serpentine belt. It’s common to replace it at the same time as the tensioner. |
Please download: https://megawrzuta.pl/download/af4f6...3f3d64774.html It's movie, this type will be better than only audio. You should click "Pobierz" |
Remove the serpentine belt and start it up w/o belt. See if the sound persists. |
Quote:
Might be better to remove the belt and just spin the idler with the engine off and see if it rattles or wobbles. It’s a cheap part. If it’s never been replaced, it’s probably long overdue. |
Quote:
| All times are GMT -7. The time now is 04:43 AM. |
