 Old 01-13-2020, 12:58 PM   #1
billiejoe's Avatar
Posts: 2   (View Stats)
billiejoe is an unknown quantity at this point
Default Engine noise, near right wheel,
Hello
I have Mazda 3 MPS 2 gen, motor was build one years ago. I drove few thousands kilometers and recently heard strange noise. I used for build CP pistons, Manley rods, delete dualmass, balance shafts, install FMIC, custom intake, hybrid turbo.
Please watch:
https://vimeo.com/384597910?utm_sour...campaign=28749
When the engine is cold after minute I hear tick noise next to right wheel. Under scoop all sounds normal, only there.
After 5 minutes, when the engine work, noise disappears.
When the engine is hot, after few kilometers tick noisy is softly.
In my opinion:
- it can't be piston slap because under scoop is silent
- injector seals was change
- chain belt also, because install new timming kit when the motor was build, I can't hear noises next to engine cover
- if it rod or main bearings noise will be louder when engine is hot, not like cold
- gearbox and ACT clutch noise is different and it hear only driver side
- alternator is regenerated with new tensioner
- A/C clutch doesn't change sound when it on/off
- under the car, applying the stethoscope to the oil pan, I can't hear anything
What do you think about it? What I should check?
ps. Sorry about my avarage English
billiejoe is online now   Reply With Quote
FR wheel noise JMPS3 Gen2 MS3 General Discussion 1 07-08-2019 10:46 AM
Throttle noise/ engine noise under28world 2010 MS3 - Engine, Transmission & Driveline 9 05-04-2015 06:25 PM
bearing noise vs wheel noise? drag0nfire Mazdaspeed3/6 General Discussion 14 06-20-2012 07:32 PM
Engine Block Heater, Sticking Gas Pedal, Clunking Noise on F-150 Truck, Ford Explorer Engine Dies at Idle: Mike Allen's Haltech Automotive News 0 03-13-2009 03:30 PM
Wheel hop noise? Speedn3 MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-02-2008 04:34 PM
Page generated in 0.27355 seconds with 22 queries
