 Old 08-16-2017, 08:42 PM   #1
creationsh's Avatar
Posts: 13   (View Stats)
creationsh is an unknown quantity at this point
Default Engine rebuilt, now throws a p0016.
P0016 - Crankshaft Position - Camshaft Position Correlation (Bank 1 Sensor A)
I had my engine rebuilt by this mechanic and 5 months later and numerious tries, he still couldn't fix the p0016 code. He tried replacing the harmonic balancer, camshaft position sensor, adjust the timing with the proper tools that I supplied to him (he doesn't have his own), finally today he told me another story about the engine mount is triggering the camshaft position sensor because the engine moves around due to the worn out engine mount.
Along the way, he broke 2 sensors, turbo inlet hose, camshaft relector ring.
Now he's telling me to buy a set of motor mounts because he says that it has a design flaw in it. And claims this will fix my crankshaft position error. At this point, I don't know what to say anymore. I need your opinions, advice, experience, anything would help.
creationsh is offline   Reply With Quote
 Old 08-16-2017, 08:45 PM   #2
speed23's Avatar
Posts: 1,480   (View Stats)
Well, I can tell you definitely 100000% its not the motor mount...lol
 Old 08-19-2017, 12:13 AM   #3
creationsh's Avatar
So I went back to the mechanic with a letter of demand, and that I will sue him if he doesn't fix my car. problem solved, but I completely lost my trust in him, and now I fear that he might do something scandalous .
 Old 08-19-2017, 09:56 AM   #4
SaveMelMac's Avatar
Posts: 485   (View Stats)
I think if the guy knew what the problem is and knew how to fix it, he would of done it by now. Take your car some place else.
The Following User Says Thank You to SaveMelMac For This Useful Post:
speed23 (08-19-2017)
breaking in rebuilt engine question Footy1986 MazdaSpeed 6 - Engine, Transmission & Driveline 29 04-29-2018 02:37 PM
Newly Rebuilt Engine Running Poorly C3xauto CX-7 > Engine, Transmission & Driveline 9 08-03-2016 06:28 PM
Overheating of newly rebuilt engine EmPeEs6 MazdaSpeed 3/6 - ECU Computer Tuning 56 08-22-2015 05:07 PM
Advice for purchasing MS6 2006 rebuilt engine kevinrussell15 MazdaSpeed 6 - Engine, Transmission & Driveline 3 01-21-2015 10:58 AM
Engine rebuilt - noise and KR mrQQ Mazdaspeed3/6 General Discussion 54 06-29-2014 05:51 AM
Page generated in 0.24746 seconds with 22 queries
