 Old 11-26-2019, 08:23 AM   #1
luklyz's Avatar
Posts: 3   (View Stats)
luklyz is an unknown quantity at this point
Default Injector Seals and Filters
Hi,
I'm in the process of fighting P0300 in my Mazda. The existing injector filters are failing, and I'm looking to replace them. Any recommendation of what can be used from ebay?
Also, anyone is using the GB REMANUFACTURING seals between the injector and the head?
I read a few posts about using GB seals between injector and rail but what about injector and the head?
Thank you,
luklyz is offline   Reply With Quote
 Old 11-26-2019, 08:32 AM   #2
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
if you search just few minutes here, you will find many threads about injectors seal especially the ones between head and injectors...
Some use toyota but the brass sleeve model is a lot better
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
 Old 11-26-2019, 10:42 AM   #3
luklyz's Avatar
Thank you for your comments.
I did search the forum, and I'm aware that you can use Toyota seals or CS sleeves. I'm using Toyota right now, but I was wondering if anyone used GB from the Rockauto kit.
Also, what about injector filters. Injectors that I have they have crappy OEM, and they failed — looking to install SS microfilters from eBay. I was wondering if anyone can recommend something or a quality seller.
 Old 11-26-2019, 11:20 AM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
GB rockauto seal kit seems to be holding up for one member that I'm aware of. As for the injector screens, you might be best off taking it to an injector specialist and having them flow tested. My local shop replaces the screens with stainless steel mesh.
Stockish
Db09ms3 is online now   Reply With Quote
Injector seals - need to replace injector/fuel line O-rings? TheRealDefman 2010 MS3 - Engine, Transmission & Driveline 3 03-02-2014 09:35 PM
Page generated in 0.24123 seconds with 22 queries
