 Old 02-24-2013, 09:33 AM   #1
TheRealDefman's Avatar
Posts: 532   (View Stats)
TheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the world
Default Injector seals - need to replace injector/fuel line O-rings?
Reviewing the cp-e directions for the SAFEseals and they advise replacing the blue injector O-ring and the high pressure fuel line O-ring. I've read a bunch of threads about replacing injector seals and don't recall seeing anyone else mentioning this.
Necessary?
(Since cp-e doesn't post a link to the install PDF on their site that I can find, Google "mzr high pressure fuel line o-ring" and you'll find it.)
2012 Black Mica with Tech package.
Chock full of goodies and Dizzy tuned
TheRealDefman is offline   Reply With Quote
 Old 03-02-2014, 09:19 PM   #2
mrinjector516's Avatar
Posts: 11   (View Stats)
mrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond reputemrinjector516 has a reputation beyond repute
Neutral  :  -1 score
Default Injector "O" ring replacement.
Yes always a good idea when replacing Injectors.Cheap Insurance too,against volatile fuel leaking at high pressures onto potentially hot engine parts and having to spend another four hours ? having to do it right,the second time.
mrinjector516 is offline   Reply With Quote
 Old 03-02-2014, 09:28 PM   #3
LatinKraze's Avatar
Posts: 804   (View Stats)
Recommended but I didn't
2016 CX-5 GT AWD
 Old 03-02-2014, 09:35 PM   #4
alphasaur's Avatar
Posts: 2,847   (View Stats)
Groans: 235
Make sure you lube them shits.
/Turbo ep3 BWAAAAA PSH
/speed 3- bye
/lol nator.
The Following User Says Thank You to alphasaur For This Useful Post:
LatinKraze (03-02-2014)
Cp-e injector seals - fuel pump internals - etc kpsoerensen MazdaSpeed 3 - Engine, Transmission & Driveline 4 01-22-2012 10:08 PM
Fuel Injector Seals starscream MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 3 06-07-2011 06:27 AM
fuel injector seals kachow22 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 4 06-15-2009 08:28 PM
Page generated in 0.24265 seconds with 23 queries
