  • 1 Post By danb
 Old 07-05-2019, 10:47 PM   #1
Suhrob's Avatar
Posts: 2   (View Stats)
Suhrob is an unknown quantity at this point
Default Issues with my Speed 3?
Good Evening Everyone!
I am a proud owner of a 2012 MS3 with 83k miles as of a month ago! However, after owning it for a few weeks (loving every moment, even with the problems) it started smoking! I have spent the last 3 days trying to read EVERY post on this forum, and donated to get a VIP as I do not want to ask for help without any contribution to this site!
Here are a couple things I have noticed about the car smoking (WHITE). 1, it smokes during heavy idle and when BAT is above 153 degrees. No smoke during WOT. From the reading I have done on this forum, it sounds like it might be the turbo BUUUUTTT I have throwing codes for my EGR? There are 4 codes, they are as follows: P0401, P0403, P0421 and P2299.
I bought this car from a dealer and am unsure of all of the upgrades, as I am new to this platform and cars in general! But looks like upgrades are, AP, CAI, TMIC, JBR shifter, Coilovers. Possible HPFP? sounds like I won't know unless I open it up? Do you think my smoking is for sure a Turbo, or possible PCV or EGR issues?
Suhrob is offline   Reply With Quote
 Old 07-06-2019, 07:11 AM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
you can clean you egr..
https://cse.google.com/cse?cx=007197...ning&gsc.sort=
you need to open the fuel pump to see if it has aftermarket internals. check youtube for install videos on how to open it
Good luck with the car!
b.hog likes this.
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
2013 speed starting issues kennyg1966 Gen2 MS3 General Discussion 20 09-27-2017 09:00 PM
Few issues with my speed new member ottawaspeed Mazdaspeed3/6 General Discussion 20 10-14-2016 04:38 PM
Wheel Speed Sensor Issues Wagner1162 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 21 04-03-2016 06:50 PM
need help figuring out my issues with my speed 3 Boostedlyfe MazdaSpeed 3/6 - Troubleshoot/Diagnostics 32 08-25-2015 01:25 PM
Speed 6 Lean Issues snailD MazdaSpeed 3/6 - ECU Computer Tuning 0 04-03-2012 11:54 PM
Page generated in 0.24350 seconds with 21 queries
