  • 1 Post By TiGraySpeed6
 Old 07-16-2012, 11:52 PM   #1
Default Spark Plug Database - Gen2
This is a compiled database for spark plugs who's heat range is 1 and 2 stages colder than stock. Please add your plugs and we will update this thread.
Mazdaspeed Forums Spark Plug Index Database
Gap size - 0.026 - 0.032 | Preferred gap is between 0.026 to 0.028
Type and Specs on DISI 2.3l Spark Plugs: 14mm; 5/8 hex; 25mm reach; projected tip; resistor plug
Heat Range Conversion Chart
Code:
HKS 25 30 35 40 45 50 52.5 55
DENSO 16 20 22 24 27 31 32 34
NGK 5 6 7 8 9 10 10.5 11
Spark Plug Manf & Part Numbers
  • Denso Iridium
  • itv-20 - Stock heat range
  • itv-22 - 1 stage colder heat range
  • itv-24 - 2 stage colder heat range
  • itv-27 - 3.5 stage colder heat range
  • HKS
  • 50003-M35LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 7 $22.97ea. - 1 Stage Colder Heat Range
  • 50003-M40LF *Mazda MZR Engine* ; Mazda 3, Mazda 6, MX-5 '06 8 $22.97ea. - 2 Stage Colder Heat Range
  • NGK IX Iridium
  • NGK LTR7IX-11 (6510) - 1 Stage Colder Heat Range
  • NGK ILTR6A-8G (3787) - Stock Heat Range
  • Torque Master Spark Plugs
  • SVTP8BR Stock Heat Range
  • SVTP7YR 1 Stage Colder Heat Range
  • Autolite Iridium
  • Autolite Iridiums XP5364 - Stock Heatrange
  • Autolite Iridiums XP5263 - 1 Step Colder
NGK Copper Plugs
LZTR4A-11 (5306)
LZTR5A-13 (4306)
BKR7E
The Following 6 Users Say Thank You to Haltech For This Useful Post:
AndyT (08-31-2012), ASHMS3 (07-17-2012), Jabl3s (03-14-2014), Jebus (01-26-2015), mituc (01-16-2013), Rocker (04-24-2014)
 Old 07-17-2012, 07:15 AM   #2
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
General Specs
14mm Thread Size,
25.4mm (1") Reach,
5/8" (16mm) Hex Size,
Tapered Seat,
Resistor
tightening torque: 8.0 - 10.3 ft/lbf, (10 - 14 N/m, 1.1-1.4 kgf/m)
anti-seize on threads recommended
What's this whole "Heat Range" thing about, and why do I care?
AutoliteSparkplugs.com
>It's believed that the MZR is damn near ready for one step colder from the factory.
>Colder plugs are an integral part of KR management
Pics of screwed up spark plugs, and what they mean
Spark Plug Diagnosis
As a general theory, your ceramic should wear to a nice coffee with lots of cream color. Bright white ceramic means you should try a colder plug. Dark needs hotter. Beyond that, if your plugs ever end up looking like anything in these pics, well, you've got much bigger problems than this post is going to help with...
Just what the heck do those numbers mean anyway?
Reference Charts:
NGK - NGK spark plugs symbol code
Autolite - http://www.autolitesparkplugs.com/im...0numbering.jpg
Denso - Untitled Document
Champion - Untitled Document
Just how long can I expect my fancy new plugs to last?
Both Cobb and Denso have written on the subject. Denso has a generic note that indicates a lifespan of about 30K miles, but Cobb is even more conservative and notes the hell that is a DISI Motor will see the benefits dropping off after only 15K miles:
Per the Cobb MS3-MS6 Service Bulletin v1.03:
"...operating the car with higher than stock boost levels or with the calibrations that are on the AccessPORT, require that a spark plug gap of .026” - .028” (6.6 - 7.1mm) be used on a 1-step colder temperature plug. Denso currently offers this spark plug as part # ITV22 (please be sure to verify each plug is properly gapped before installing them). Our experience has shown that operating your turbo-charged engine at higher than stock boost levels requires that your spark plugs be replaced at around 15,000 mile intervals."
Colder Heat Ranges
generally accepted gap, where adjustable, .026 (range .025 to .028)
>Autolite Single Platinum Spark Plug
Part No. AP5263
$2.50
>Autolite Double Platinum Spark Plug
Part No. APP5263
$4.00
>Autolite Xp (Xtreme Performance) Iridium Enhanced Fine Wire Spark Plug
**Cross-references the Denso ITV-22**
Part No. XP5263
$6.50
>NGK IX Iridium
Part No. LTR71X-11
$8.00 ea.
>Denso Iridium Spark Plugs
Part No. ITV22 - one step colder
$11.99 (streetunit price)
Part No. ITV24 - two steps colder
Factory Heat Range
generally accepted gap, where adjustable, .032 (range .028 to .032)
Part No. APP5364
$3.99
>Champion Double Platinum Spark Plug
Part No. 7437
$4.29
>Motorcraft Original Equipment Finewire Single Platinum Spark Plug
Part No. SP432
$4.69
>Motorcraft Original Equipment Finewire Double Platinum Spark Plug
Part No. SP478
$4.69
>Bosch Platinum+2 Spark Plug
Part No. 4315
$4.99
>Bosch Platinum Ir Fusion
Part No. 4515
$5.71
>Bosch Platinum+4 Spark Plug
Part No. 4488
$5.99
>Pulstar Platinum Pulse Plug
Part No. EF1P
$9.99
>ACDelco Professional Platinum Spark Plug
Part No. 41-814
$6.49
>Champion Iridium
Part No. 9901
$5.74
>NGK Premium Iridium
Part No. ILTR6A8G
$9.94
Part No. XP5364
$6.59
>Pulstar Iridium Pulse Plug
Part No. EF1I
$12.99
>E3 Premium Special Electrode Automotive Spark Plug
**no reports of this plug working worth a crap in the MZR engine**
Part No. E3.66
$5.99
340hp / 371tq
The Following 6 Users Say Thank You to TiGraySpeed6 For This Useful Post:
akagijoe (12-17-2013), AndyT (08-31-2012), Jebus (01-26-2015), mituc (01-16-2013), rfinkle2 (01-16-2013), SPEEDfreak239 (01-27-2013)
 Old 12-07-2012, 02:59 PM   #3
Jo367344's Avatar
Posts: 14   (View Stats)
Jo367344 is a jewel in the roughJo367344 is a jewel in the roughJo367344 is a jewel in the rough
UPDATE
SparK Plug Diagnostic Link change to Spark plug failure analysis
I clicked the old link and it didn't work, so I found the new one by browsing the original site.
Jo367344 is offline   Reply With Quote
The Following 4 Users Say Thank You to Jo367344 For This Useful Post:
mituc (01-16-2013), rfinkle2 (01-16-2013), Rocker (04-24-2014), TiGraySpeed6 (12-07-2012)
 Old 12-13-2012, 06:03 PM   #4
turbo test's Avatar
Posts: 798   (View Stats)
turbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the worldturbo test is the leader of the world
Groaned at 9 Times in 5 Posts
Tapatalk is retarded cant tell if this is a sticky or not. Subbing for near future reference.
Have opinions swayed as to what is the best or preferred spark plugs for our engines?
My speed just rolled over 30k and today i started the car and idle was rough followed by two cel's cylinder 2 misfire and overboost. Has me worried.
2010 Velocity Red MS3-Eibach PRO-KIT-EVO X Rims-SU RMM-SU solid shifter bushings-CP-e HPFP-CP-e tip-CP-e cai-CP-e hks ssqv bov kit-ddm slim hid kit 35w-5000k-JBR Heavy Shift Knob-JBR RSB-AQ Motorsports catted downpipe-Magnaflow full 3in CBE- SPC camber arms (Stratified tuning) 91/e85 tuned
turbo test is offline   Reply With Quote
 Old 12-13-2012, 06:22 PM   #5
step colder, in order of preference-
Denso ITV22
NGK LTR71X-11
Autolite XP5263
itv22 is the only one that comes gapped @ .028, the others are @ .044
340hp / 371tq
The Following 4 Users Say Thank You to TiGraySpeed6 For This Useful Post:
AdamBomb (06-25-2013), mituc (01-16-2013), rfinkle2 (01-16-2013), Trancem1ssioN (01-30-2016)
 Old 01-16-2013, 07:05 AM   #6
mituc's Avatar
Posts: 3,528   (View Stats)
Groans: 111
Just gaped my 2 spare sets at 0.65mm/0.026ish inch. I'm going to move from ITV22 to LTR71X-11 this spring.
I'd love to have some insight from the knowledgeable people on this forum about how to properly gap these plugs for different boost/power levels. However, I guess that 0.026 should work for pretty much anyone needing just one step colder plugs.
2008 Cosmic Blue Mazda 3MPS
self-Versatuned to 22PSI
 Old 01-16-2013, 07:49 AM   #7
.026-.028 is generically safe for the step colder. Lean more towards the .026 side as boost levels go up.
Stock heat range, combined with lower boost, say 18 & under, can get away with gaps as large as .030 to .032
The only issue with most plugs we can run is that they come with a monster .044(ish) gap, and need to be gapped down to spec. Changing from a 44 to a 26 is a huge ass change, and, while certainly doable, may shorten the best use lifespan of the plug.
Cobb, and experience, indicate that a high boost, well tuned Speed will wear a set of plugs in ~17-20K miles. The angle resulting from such a major gap change may reduce that life to more like 15-17K.
Myself, I run cheap ass (no, not inexpensive, just plain cheap) Autolite XP5263 plugs, and change them every 4th oil change or so. Readily available at your local parts joint over the counter.
340hp / 371tq
 Old 06-12-2013, 06:37 AM   #8
bobspeed3's Avatar
Posts: 3   (View Stats)
bobspeed3 is an unknown quantity at this point
For the folks wondering about copper plugs for our car i'm including what I got in an email conversation from NGK tech support when I asked them about a V-power plug for our car.
The Iridium’s also have copper cores since there is no such thing as a copper plug. The ignition on that vehicle will require a finewire plug as it needs it to retain factory functions such as the wasted spark. Since the Iridium will require less voltage to jump the gap it is better for boost. Most likely will not come out with one.
bobspeed3 is offline   Reply With Quote
 Old 04-18-2014, 04:23 PM   #9
modusoperandi's Avatar
Posts: 309   (View Stats)
modusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond reputemodusoperandi has a reputation beyond repute
Trying to decide if to go a step colder on my car & what to set the gap to. Running a CS 3 inch intake, CS TMIC, AT HPFP internals, & test pipe. Thoughts?
modusoperandi is offline   Reply With Quote
 Old 04-23-2014, 08:36 PM   #10
makjur's Avatar
Posts: 1,313   (View Stats)
makjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the worldmakjur is the leader of the world
Groaned at 15 Times in 8 Posts
I recently ordered NGK 6510's... before I ordered them I did some reading and found 2 theories that make sense
1. Stock turbo = stock temp plugs
2. If your 50+ horsepower, colder plugs help
I decided with option 2, for now, if I dont like them I'll get stock temp
2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned
retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals
♡°☆(ಠೆಒಠಿ)☆°♡
makjur is offline   Reply With Quote
 Old 04-29-2014, 06:07 PM   #11
SKiZZ's Avatar
Posts: 288   (View Stats)
SKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond reputeSKiZZ has a reputation beyond repute
What is the preferred method to gap our plugs?
2013 CWP Mazdaspeed 3
SKiZZ is offline   Reply With Quote
 Old 04-29-2014, 06:14 PM   #12
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Gap gauge.
Some use feeler gauges, but they can damage electrodes pretty easily if misused.
 Old 07-10-2014, 09:10 PM   #13
motoman's Avatar
Posts: 118   (View Stats)
motoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond reputemotoman has a reputation beyond repute
I just swapped in some Autolite XP5364s after 62,000 miles on the original plugs.
I noticed the originals are FoMoCo with the part number of ILTR5A-13G, which is an NGK. However, this plug isn't listed above and when I query this part in the plug databases it shows as not for the 2010 MS3, but it is for the regular 3. Any thoughts on this?
Black Mica 2010 Mazdaspeed 3
motoman is offline   Reply With Quote
 Old 07-11-2014, 09:02 AM   #14
motoman's Avatar
Originally Posted by Agent_Orange View Post
Gap gauge.
With this type of gauge you can only get approximate. The only way to get a precise gap is to use a feeler gauge. For example, notice the gap on this gauge is 0.025 and 0.030. Yet a lot of folks on here talk about 0.026, 0.027, 0.028 gaps, etc. You can't do that without feelers. The only thing you can do with the pictured gauge is get somewhere between 0.025 and 0.030.
The Following User Says Thank You to motoman For This Useful Post:
MS3Dreamz (10-10-2014)
 Old 10-06-2014, 01:37 PM   #15
aromig's Avatar
Posts: 289   (View Stats)
Noticed the gap listed at the very start of the o.p. is off. It states 0.26 - 0.32, when it should be a 0.026 - 0.032 gap. Any chance this could be updated?
Sent from my GS3 running PAC ROM
 Old 10-10-2014, 06:27 PM   #16
MS3Dreamz's Avatar
Posts: 66   (View Stats)
MS3Dreamz is a glorious beacon of lightMS3Dreamz is a glorious beacon of lightMS3Dreamz is a glorious beacon of lightMS3Dreamz is a glorious beacon of lightMS3Dreamz is a glorious beacon of light
Groaned at 28 Times in 6 Posts
Going to switch to NGK!!
MS3Dreamz is offline   Reply With Quote
 Old 10-12-2014, 09:53 AM   #17
MS6_life's Avatar
Posts: 6   (View Stats)
MS6_life is an unknown quantity at this point
Default Spark plug gap issue?
Hello all,
Yesterday I just replaced my spark plugs on my 2007 MS6. Prior to replacement the car was misfiring pretty bad and overall running terribly. The engine would surge and the car ran inconsistent.
After replacing the plugs it is like driving a brand new vehicle! With that being said I left the gap at 0.4 and every once in a while I still feel a bad misfire or even a mini engine sure. Could this be due to the gapping? I have Denso ITV22 and it appears most of you say to gap it at 0.28, could this be why my engine still surges?
Thanks so much!
MS6_life is offline   Reply With Quote
 Old 10-12-2014, 10:23 AM   #18
dale_gribble's Avatar
Posts: 4,720   (View Stats)
You mean .04 and .028? Gap em to around .030 or little lower for stock/lightly modded.
MINI H1 6.0 - CAR LED TAILS
dvswimer (04-18-2018)
 Old 10-12-2014, 10:31 AM   #19
Hoyoman's Avatar
Posts: 302   (View Stats)
Hoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the worldHoyoman is the leader of the world
Groans: 43
Groaned at 6 Times in 3 Posts
I'm still on stock plugs with all the mods in my sig o.o
2012 black mica MS3 ; 3.5 HTP/ Catless DP/ AT HPFP/ APV2/ FMIC/ GFB BOv/ 3" CBE/ RMM/ XXR 530(18x9 +33)/ NT05 245/40/18/ 3bar map/ 3 port EBCS/ bnrs3/ DO stg2 dvc30/ REAR swaybar/ EBC Yellow/ CS Inj seals/ PNP IM/ Manley H-Beam/ Manley platinum piston 87.5/ soon...... PI+ BNRs6+ 44mm TIAL+ ACT 6 puck
E35 meth d012 26psi 420/451 self tuned/built
Hoyoman is offline   Reply With Quote
 Old 10-12-2014, 08:16 PM   #20
MS3Dreamz's Avatar
Your coils still good?
 Old 10-12-2014, 11:16 PM   #21
Hoyoman's Avatar
Groans: 43
Should be okay but will use step colder plugs soon and will post on here again if anything crazy comes up with stock plugs
The Following 2 Users Say Thank You to Hoyoman For This Useful Post:
Awal (04-22-2015), MS3Dreamz (10-12-2014)
 Old 04-22-2015, 02:48 AM   #22
Awal's Avatar
Posts: 645   (View Stats)
Awal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the worldAwal is the leader of the world
Hoyo have you changed the plugs yet? anything to report?
All Go, No Show
2013 LSM W/ Tech
CORKSPORTFull Race RMM CORKSPORTPMM CORKSPORTTMM CORKSPORTTMIC(temporarily uninstalled for Warranty BS) CORKSPORTECU RELOCATION BATTERY BOX(temporarily uninstalled for Warranty BS) CORKSPORTSSP CORKSPORTSHIFTER BUSHINGS CORKSPORT3.5" POWER SERIES SRI/TIP(temporarily uninstalled for Warranty BS) CORKSPORTBPV(temporarily uninstalled for Warranty BS) CORKSPORTRSB @ Full Stiff CORKSPORTMid Chassis Brace CORKSPORTHood Struts + decals for 20whp CORKSPORTLicense Plate Frames
COBBAP v3 w/ Window Mount
AUTOTECHHPFP INTERNALS
ToBeInstalled:
CORKSPORTFull Catless TBE, Rear Trunk Brace, Adjustable FELs, Cold Air Box (modified for 3.5")
dbaDBA42962S Front and Rear Rotors
StopTechRear Braided SS brake lines
JBROCC & VTA OCC kit, EGR BO, Boost Tubes
Cooling MistWMI kit
StratifiedCustom Tune (as soon as TBE is on)
On Deck
wilwoodFastbrakes DP4front Caliper kit (w/ bp-10 pads and braided SS fr lines)
Hawk PerformanceHB478F.605 or HB478Z.605 rear pads
BilsteinB16s
Awal is offline   Reply With Quote
 Old 11-23-2016, 11:57 PM   #23
Dedlyvirus's Avatar
Posts: 35   (View Stats)
Dedlyvirus will become famous soon enoughDedlyvirus will become famous soon enough
Has anyone ever had any issues with the NGK 6510s not threading in right? I picked up a set, and it almost felt like the threading was different, so I stopped because I didn't want to screw up the threading.
Dedlyvirus is offline   Reply With Quote
 Old 09-27-2017, 05:09 PM   #24
season_of_ages's Avatar
Posts: 290   (View Stats)
season_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond reputeseason_of_ages has a reputation beyond repute
I'm curious, why are the NGK BKR7E listed? Looking at the specs on NGK's website, their reach is a quarter inch shorter than standard. I'd love a V-power copper plug but wouldn't this cause issues? Or can we gap the plug to make up for the length distance? Is that how it works?
Sent from my LG-H918 using Tapatalk
season_of_ages is offline   Reply With Quote
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f427/spark-plug-database-gen2-119130/
Mk 2 spark plugs ? Mazda MPS Owners Club This thread Refback 01-17-2015 05:50 AM
What have you done to your Ecoboosted vehicle today? This thread Refback 06-02-2014 08:23 AM
? View topic - PFB's 2008 Mazda 6 MPS This thread Refback 10-08-2013 08:04 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3/6 - ECU Computer Tuning 74 08-02-2019 08:18 AM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 6 - Engine, Transmission & Driveline 41 05-05-2016 08:49 AM
Spark Plug Database - Gen2 Haltech 2010 MS3 - ECU Computer Tuning 3 02-27-2016 04:53 PM
Spark Plug Database - Colder Than Stock ( Stage 1&2 ) Haltech MazdaSpeed 3 - Engine, Transmission & Driveline 205 09-22-2015 06:52 PM
best spark plug? soulefx 2010 MS3 - Engine, Transmission & Driveline 12 12-22-2009 10:35 PM
Page generated in 0.48230 seconds with 38 queries
