 Old 09-16-2019, 10:26 PM   #1
Jayy_cee27's Avatar
Posts: 2   (View Stats)
Jayy_cee27 is an unknown quantity at this point
Exclamation Starts but doesn’t idle.
Hey guys this is my first post, and I’m hoping I can get some insight. I’ve already done a lot of searching and can’t seem to find a solution, and I’m not sure if this is the right place but here it goes. I own a 2012 ms3 with about 86k. About a week and a half ago it was driving fine, I let it sit for a couple days, and when I went back to start, it would turn over but it’s not holding an idle. I’ve already checked for leaks and replaced the bpv hose. Checked my spark plugs and coil packs, replaced the battery. Replaced the camshaft position censor. Checked my maf sensor(seemed fine). Made sure I was getting fuel. Checked the throttle body. Did a compression test, from bank 1-4 it read 140,140,170,140 (which is in the green but someone said that those numbers might be low) haven’t done a wet compression test yet. As of right now I’m taking shots in the dark and not sure what else to do besides just having it towed to a shop and spending who knows what on shop fees. I’m hoping someone could give me a few solutions. Could this be a small issue that I’m overlooking or could there be an issue with the motor? I spoke to someone at a shop and he was telling me that I would need to do an engine rebuild, or at the minimum replace the head. Currently the car is a cork sport stage 2(turbo back exhaust with high flow cat, intake, hpfp internals, and an off the shelf tune from the Cobb accessport).
Jayy_cee27 is offline   Reply With Quote
 Old 09-17-2019, 09:56 AM   #2
danb's Avatar
Posts: 176   (View Stats)
danb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud ofdanb has much to be proud of
what is your fuel pressure when you do a "key on-engine off" test? Have you checked the pressure relief valve?
2007 speed3 GT. cobb rmm, JbR pmm, Corksport adjustable shifter, twm solid shifter bushings, Sure shift knob, AP3, Autotech, CS turbo, CS occ, HTP 3.5, Depo catless dp, TS Kompact bpv, CS 3port, cpe BlockD, GA V3, DO DVC-30, Cx racing piping, tr1035.. Freektuned
2011 mazda 6
danb is offline   Reply With Quote
 Old 09-17-2019, 10:15 AM   #3
Police - Grammarhead
Vansquish's Avatar
Is it throwing any codes?
 Old 09-17-2019, 10:37 AM   #4
Db09ms3's Avatar
Posts: 536   (View Stats)
Is the alternator charging?
Stockish
 Old 09-17-2019, 10:39 AM   #5
Jeff23spl's Avatar
Posts: 2,235   (View Stats)
i would investigate into fuel pressure and maf signal.
can you play with the throttle to keep it running by its own even if it isn,t ok to drive ?
compression is low but it need to be done while hot before diagnosing a rebuild need. . i won,t say it is perfect but you have plenty of compression to get it running ok. i dont think it is the first issue here.
it could ran for a while without the alternator
1993 Ford Probe KLZE 143dB
1989 GM 6.2 diesel pickup
Wife drive 2010 CX7
...Because French Canadian...
Last edited by Jeff23spl; 09-17-2019 at 10:39 AM. Reason: MSF Database - Automerged Doublepost
 Old 09-17-2019, 10:52 AM   #6
Db09ms3's Avatar
My harness is fubar'd on my alternator so it runs for a few seconds then dies. Something to check.
Stockish
 Old 09-17-2019, 01:38 PM   #7
Jayy_cee27's Avatar
Well we only checked to see if I was getting fuel and return fuel, we don’t have a way to check what the pressure is exactly. And I don’t believe we checked the pressure relief valve. Do you have a write up on how to check these?
When we checked it was throwing p2088 p0113 and p0102
Should I just change the maf sensor?
Last edited by Jayy_cee27; 09-17-2019 at 01:46 PM. Reason: MSF Database - Automerged Doublepost
 Old 09-18-2019, 07:20 AM   #8
MSMS3's Avatar
Posts: 2,826   (View Stats)
P2088 DTC
Check this link. Took me about 60 seconds to locate.
 Old 09-18-2019, 08:25 AM   #9
Jeff23spl's Avatar
you likely not solve it without tools and without investigations. Replacing parts until it works is a long and costly process if you don,t have a spare donor just beside your door...
to check fuel pressure and everything else, you need an obd reader that support specific mazda pids like the high fuel pressure and some others.
a cheap elm327 with torque pro app and the mazdaspeed add on can do it for cheap or probably versatune free with an adapter and a pc computer.
same for the maf, most of the time it is a bad connection, a leak or even dirt on it. sometimes it can be the sensor itself but those car doesn,t seem to like aftermarket ones and it needs to be a turbocharged version. ms3,ms6,cx7-t
Wife drive 2010 CX7
 Old 09-18-2019, 08:33 AM   #10
Jeff23spl's Avatar
ok i see, but that harness also pick up the crank sensor and some more on the other side...
Wife drive 2010 CX7
 Old 12-14-2019, 04:08 PM   #11
Ms3Silver's Avatar
Posts: 6   (View Stats)
Ms3Silver is an unknown quantity at this point
Sorry to revive a semi old thread. I'm having the same or similar issue. Engine starts but dies almost immediately. I've checked just about everything OP has in the post.
One thing that I've noticed from my AP is that in the ON position, I'm getting readings of 2000-2150psi. I'm thinking it's my RV not doing its job correctly, I'd just like some more opinions on that before I pull the trigger on a new one.
Ms3Silver is offline   Reply With Quote
Rough idle, doesn't want to start after fill up, runs rich, vacuum leak, backfires UnamusedPunk Mazdaspeed3/6 General Discussion 14 12-28-2017 07:39 AM
My 2008 Speed 3 will not hold an idle and rides rough at low rpm and low idle Dgms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 17 11-23-2016 03:42 PM
(2013 MS3) Rough idle and occasional slow starts? shiftyone 2010 MS3 - Troubleshoot/Diagnostics 33 09-12-2016 04:45 PM
Long cold starts, intermittent rough idle Giojettson 2010 MS3 - Troubleshoot/Diagnostics 3 12-07-2015 09:10 PM
Valves cleaned, car starts, dies after rough idle. Thoughts? slixx 2010 MS3 - Troubleshoot/Diagnostics 5 05-28-2013 05:00 PM
Page generated in 0.30684 seconds with 26 queries
