![]() Join Date: Mar 2014 Location: Brighton, MI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1
(Thread Starter) | Not Ranked : 0 score Ok guys I've searched and searched and I have read all the previous posts about this but I'm running out of ideas, ok I jnstalled, tmic, race pipe, internals, boost tubes, and bpv. So here is my issue, when I hit the throttle I get this an I don't know how else to describe it other than like a cable stretching sound? It happens only when in gear and between 2-4 rpm in gears 1-3 not high gears at same rpm.. At first I thought my autotechs, which I do hear a louder rattle, but that is normal, this sound when I put on gas happens and it takes me till high rpms till I can't hear it anymore... I tightened all tubes and intercooler could this possibly be the race pipe or anything else that I'm not thinking of? I pulled out pump and no scoring and all of HPFP looks great and holds pressure any other ideas?? I have literally searched to no end and got nothin
__________________ 2012 Mazdaspeed3, "Silky Johnson" * Corksport 80 RMM * JBR 80 PMM * JBR 88 TMM * Cobb V3 Acessport * Autotech HPFP * Corksport TIP/CAI * JBR Boost Tubes * UR Race Pipe * SU TMIC * Forge V1 BPV * JBR EGR Delete * Corksport Carbon Fiber Hood Scoop * Corksport Single outlet CBE * NGK One step Colder * Rear Wiper Delete * Stickers to add to the RICE * PURPLEDRANK Tune * * Environmentally Friendly allll Organic * Winter Vehicle 2004 Ford V8 Explorer "Boss Hogg" * Kenwood in-dash dvd * 2 Kicker 12" CVR Comp" * Apline 1000w Mono amp* |
![]() Join Date: Dec 2008 Location: FLORIDA
Rep Power: 1419 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,235
| Not Ranked : 0 score How do your logs looks? Does this happen every time?
__________________ 2008 Mazdaspeed3 GT GTX2867r ![]() |
(Thread Starter) | Not Ranked : 0 score logs look great, and yes it happens every time
![]() Join Date: Dec 2011 Location: Warwick, RI
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,517
Groaned at 15 Times in 8 Posts
| Not Ranked : 0 score At low rpm and driving slow, when I start applying pressure to the accelerator I hear what I think is the same noise, i would describe it as a door creaking. I have always dismissed it and I'm pretty sure I have seen it discussed here. I think I started hearing after installing my ets tmic I hate tapatalk 4.11
__________________ 2010 blue with tech, cobb sri+tip+dp+cbe, ets tmic, grimmspd ebcs, autotek hpfp, jbr boosttoobs+rmm+roundknob+bushings, turbosmart bpv, swift springs, APv3 FreekTuned retrofitted headlights: morimoto 5k HIDs with XB35 ballasts, in mini D2S projectors. VLED triton 5k switchback DRL/turn signals ♡°☆(ಠೆಒಠಿ)☆°♡ |
__________________ 2012 Mazdaspeed3, "Silky Johnson" * Corksport 80 RMM * JBR 80 PMM * JBR 88 TMM * Cobb V3 Acessport * Autotech HPFP * Corksport TIP/CAI * JBR Boost Tubes * UR Race Pipe * SU TMIC * Forge V1 BPV * JBR EGR Delete * Corksport Carbon Fiber Hood Scoop * Corksport Single outlet CBE * NGK One step Colder * Rear Wiper Delete * Stickers to add to the RICE * PURPLEDRANK Tune * * Environmentally Friendly allll Organic * Winter Vehicle 2004 Ford V8 Explorer "Boss Hogg" * Kenwood in-dash dvd * 2 Kicker 12" CVR Comp" * Apline 1000w Mono amp* | |
| Not Ranked : 0 score It's it not just throttle tip in HPFP rattle? My Autotech internals have always had a noise "rattle" at throttle tip in. I've been running them for 2-3 years now with no ill consequences.
| Not Ranked : 0 score I did hpfp and tmic at the same time ... Attributed all additional to noise since then to either one or the other I hate tapatalk 4.11
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score A video of the noise may be more helpful. We all describe sounds differently.
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
(Thread Starter) | Not Ranked : 0 score I tried taking a good video but it's super hard to hear when driving I know the fuel pump rattles but I was curious if the TMIC could also be culprit
![]() Join Date: Jun 2011
| Not Ranked : 0 score I had this exact same noise.. The dealer told me it was my corksport inserts that collected dirt. They cleaned it and the noise went away, and then it just started to happen again a few months later |
| Weird noise under light throttle | csmaan12 | Gen2 MS3 General Discussion | 2 | 06-17-2014 08:21 AM |
| Noise but only under very slight throttle?? | chattown3 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 9 | 06-14-2012 06:56 PM |
| Throttle body/plate noise. | WillyH | 2010 MS3 - Engine, Transmission & Driveline | 17 | 02-23-2012 07:53 PM |
| nasty pop noise on throttle blips | cpolly69 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 13 | 01-23-2012 11:06 AM |
| Partial Throttle Goose noise from Big Turbo's? | RichB | MazdaSpeed 3/6 - Turbo Induction | 1 | 10-19-2011 08:48 AM |
