  • 1 Post By Quazz236
  • 1 Post By sharksinspace
 Old 06-26-2019, 02:44 PM   #1
markiespeed3's Avatar
Posts: 2   (View Stats)
markiespeed3 is an unknown quantity at this point
Default Thud when shifting
Hello everyone, new to the forums here. Just got a 2013 MS3 and I didn’t notice before but it has quite a thud to it when shifting gears. It won’t do it if I pause between shifting but anything above 3k rpm seems to thud like I’m shifting early? There’s also usually a thud when I let engage as well. I am hoping it’s just a simple motor mount issue but I’m not too familiar. Anybody have experience w this? Thanks!
markiespeed3 is offline   Reply With Quote
 Old 06-26-2019, 06:43 PM   #2
Quazz236's Avatar
Posts: 16   (View Stats)
Quazz236 will become famous soon enough
Sounds like a rear mount. Had the same thing not long ago when my stock mount went. Metal thud sound when shifting or right when the clutch engages unless you go out of your way to shift super smooth and baby the clutch. Replaced it with the JBR mount and all good.
markiespeed3 likes this.
Quazz236 is offline   Reply With Quote
The Following User Says Thank You to Quazz236 For This Useful Post:
markiespeed3 (06-27-2019)
 Old 06-26-2019, 08:12 PM   #3
sharksinspace's Avatar
Posts: 766   (View Stats)
Groans: 126
Where's it sound like the thud is coming from? Engine bay? Transmission? Further back? Check your rear and passenger motor mounts, hopefully it'll just be one of those rather than some sort of clutch/trans issue. PMM is especially easy to diagnose...locate it on the passenger (obviously) side of the bay and if there's a gross colored fluid or residue covering anything in that area then you've found your problem.
Genpoo stuff
 Old 06-27-2019, 09:36 AM   #4
I’m hoping that would be the ideal situation. I am not 100 percent sure but what you’re saying sounds pretty spot on. I’ll have to check once I get off work today. It’s like almost a thud by my feet unless I baby it like you said.
Steering Wheel Thud Noise Socal Ms3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 5 11-06-2012 12:40 PM
Loud thud over bumps wtf lol MazdaSpeed 3/6 - Suspension & Brakes 17 10-01-2012 08:26 PM
All-Wheel-Drive thud help blackstang54 MazdaSpeed 6 - Engine, Transmission & Driveline 29 10-23-2011 10:22 PM
Chassis Thud in Reverse???? John F 2010 MS3 - Troubleshoot/Diagnostics 14 01-20-2010 06:18 PM
Rear Mount Thud popecruz Mazdaspeed3/6 General Discussion 7 07-15-2008 05:38 PM
Page generated in 0.25970 seconds with 22 queries
