 Old 05-15-2014, 06:05 PM   #1
iammike's Avatar
Posts: 1,415   (View Stats)
Default Tip/Trick: Installing CP-E TMM - Removing the stud from the transmission.
Installed the CP-E TMM today and had quite the fight with removing the stud from the transmission. The "double nut" trick wasn't even close to doing the job no matter how tightly I torqued them together. PB was applied liberally, I tried applying heat, I even tried a set of channel locks.
1. If you want to do this right, save yourself the drama and buy a stud removal tool.
2. If you're me and you've been at this for over 30 minutes in your apartment parking lot, take a 7/16 socket, place it on top of the stud and whack it a few times with a hammer. Insert socket wrench and POP, came right loose.
Downside, I don't think that socket is ever coming back off the stud.
Mike
The Following User Says Thank You to iammike For This Useful Post:
aromig (09-21-2014)
Stripped Transmission Stud? SubyGF 2010 MS3 - Engine, Transmission & Driveline 13 08-12-2016 09:12 AM
Need Help - transmission stud stripped albone MazdaSpeed 3 - Engine, Transmission & Driveline 5 02-22-2012 02:16 PM
How To Repair Car Rust, Removing Flywheel on GMC Jimmy, Transmission Problem on Dodge Grand Caravan, Idle Air Sensor on Haltech Automotive News 0 12-18-2008 01:10 PM
Removing Engine Valve Cover, Belt-Driven Transmission, Battery Sulphation, Replacing Dashboard Lights, Buying Tires For Haltech Automotive News 0 06-10-2008 02:12 AM
Page generated in 0.26490 seconds with 21 queries
