  • 1 Post By Tokay444
 Old 02-08-2010, 02:00 PM   #1
thenewzolt's Avatar
Posts: 73   (View Stats)
thenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud ofthenewzolt has much to be proud of
Default Torque damper
Does anyone know if the torque damper for the last gen will fit the 2010s? It looks like it should. I tried emailing Weapon R but they never responded..
Weapon R Engine Torque Damper for 07-08 Mazdaspeed3, JSC Speed
thenewzolt is offline   Reply With Quote
 Old 02-23-2013, 04:44 AM   #2
axel1's Avatar
Posts: 12   (View Stats)
axel1 will become famous soon enough
wondering the same, I am looking at the Ingalls
axel1 is offline   Reply With Quote
 Old 02-23-2013, 07:59 AM   #3
08.5MS3's Avatar
Posts: 3,840   (View Stats)
Groans: 89
Just get a motor mount. As far as fitment, I do not believe it will work.
 Old 02-24-2013, 06:27 AM   #4
GreyGhost's Avatar
Posts: 315   (View Stats)
GreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the worldGreyGhost is the leader of the world
+1 I was looking at the Ingalls too...would love to hear confirmation either way
2013 Mazdaspeed 3:
Performance: Autotech Internals // COBB AP // COBB TIP // Cobb Intake & Air Box // COBB FMIC // UR Catted DP V1 // UR CBE // UR Testpipe // Go Fast Bits BPV // Stratified ECBS 2-Port Mode // NGK One Step Colder Plugs // JBR Coolant Bypass Kit // Rotella T6 5w-40 // CP-e Stage RMM // Cp-e PMM // CS Shifrer Plate // Sure Shift Anchors // Redline Plus Hood Struts
VD: 304hp / 333tq Stage 2 91 Octane Freek Tune
GreyGhost is offline   Reply With Quote
 Old 02-24-2013, 06:55 AM   #5
08.5MS3's Avatar
Groans: 89
Lots of cabin noise and vibration. Seriously, just buy a motor mount.
 Old 02-24-2013, 07:00 AM   #6
thatsmrgimp2u's Avatar
Posts: 834   (View Stats)
I actually got mine because of the balance shaft delete. Apparently you don't want an upgraded mount there because it makes vibes really bad. It isn't unbearable.
Fluids
Rotella T6 A lot
Rislone Engine Treatment
Motorcraft XT-M5-QS(trans)
VP Methanol
~Splash of E85~
thatsmrgimp2u is offline   Reply With Quote
 Old 02-24-2013, 08:33 AM   #7
jbr makes fall-a-parts.
Tokay444's Avatar
Posts: 13,163   (View Stats)
Groans: 793
I'd still rock mine even if I was fully mounted.
"Exclusivity" - CP-enis
Demodded.
The Seals
 Old 02-24-2013, 08:37 AM   #8
speed3gen1's Avatar
Posts: 139   (View Stats)
speed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the worldspeed3gen1 is the leader of the world
I've had an ingalls damper on my last car(06cobalt super shitty)lol...but as far as the damper goes I found it was a smart buy and worked very well!! and I'm not sure but if the mounts are the same between the gen1 & 2 then it should work!
tappinyamomma
speed3gen1 is offline   Reply With Quote
 Old 02-24-2013, 08:40 AM   #9
My only concern would be strut location and hood clearance.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-24-2013, 08:41 AM   #10
axel1's Avatar
I actually emailed Ingalls to find out abt a fitment for the 2012 MS3, no response yet, will advise.
I had teh RMM CPE V2 but suffered from a wobbly feeling a low speeds (someone commented that it could be harmonic balancers), the vibes was not an issue but I began to get a wobbly feeling on the front wheels, looked at every possible cause, finally ended up removing the CPE mount and placed in some CS inserts (still get a tad bit shake but its now tolerable).
Now I am looking at trying to stabalise the engine rocking under hard launches, this seems like the only route left.
Anyway will advise should I hear back from them
The Following User Says Thank You to axel1 For This Useful Post:
speed3gen1 (02-24-2013)
 Old 02-24-2013, 08:44 AM   #11
Celestspeed3's Avatar
Posts: 1,136   (View Stats)
One of our local guys had one of these mounted on his car at the passenger side motor mount. I don't recall the brand tobe honest. The install was done properly and the nuts were torqued down as per factory instructions. I'm not sure how or why but a week later he heard a strange knocking sound the nuts on the torque damper were loose so he torqued them down again this time a little higher. The following week he got the same noise driving for work to a coffee shop literally 3mins away. This time he wasn't so lucky. The torque damper had come completely off and the motor dropped in the engine bay. Some emergency roadside assistance later we discovered the passenger motor mount had wedged itself into the timing cover and cracked it. We managed to use a heli coil and some JB weld to get the car running again however a timing cover replacement is needed. To those who have one I would check it periodically to make sure it's okay. To those who are looking at getting one I recommend you save your money and get a full set of mounts.
 Old 02-24-2013, 08:46 AM   #12
speed3gen1's Avatar
you only has rmm? if so the driver side mount helps out! but vibes will occur..I rock a sure rmm ad twm driver side mount on my gen1 and it does the job! eliminated alot of hop!
tappinyamomma
 Old 02-24-2013, 09:00 AM   #13
Tokay444's Avatar
Groans: 793
I've had my ingalls on for 2+years.
No issue. Guess I'm lucky.
Makes a little more noise in the winter, but once you realize what it is, it's nce.
Demodded.
The Seals
thatsmrgimp2u (02-24-2013)
 Old 02-24-2013, 09:05 AM   #14
speed3gen1's Avatar
yea sounds like faulty install...unless damper wasn't set correctly; bottomed out and effed shit up!
tappinyamomma
 Old 02-24-2013, 09:08 AM   #15
The guy is local mechanic, I don't think he would have screwed up the install.
 Old 02-24-2013, 09:09 AM   #16
Koke382's Avatar
Posts: 4,361   (View Stats)
i have the ingals and i love it, i had it off for like 2 months and when i put it back on the car just felt better. And it doesnt vibrate as much as people say.
Sent from your Anus
2007 Mazdaspeed 3 GT
18x8.75 XXR 527 225/40/18r
New fucken miata build:
1993 Red Na6
Some suspension modz yo
Coilovers// Other shit
 Old 02-24-2013, 09:10 AM   #17
Tokay444's Avatar
Groans: 793
@Dano; has had his for a while too.
Demodded.
The Seals
 Old 02-24-2013, 09:14 AM   #18
Just sharing my experience and opinion on it. I've only ever seen the one installed on his car. Maybe his was faulty, I don't know and can't confirm. It was over a year and a half ago.
 Old 02-24-2013, 09:15 AM   #19
Tokay444's Avatar
Groans: 793
If it's set to full stiff, it will fuck your couch.
speed3gen1 likes this.
Demodded.
The Seals
Celestspeed3 (02-24-2013), speed3gen1 (02-24-2013)
 Old 02-24-2013, 09:16 AM   #20
That could very well have been a factor, I can't confirm though.
 Old 02-24-2013, 09:24 AM   #21
Tokay444's Avatar
Groans: 793
Which bolts/studs broke?
Demodded.
The Seals
 Old 02-24-2013, 09:27 AM   #22
The nuts that are on the studs passenger side motor mount came loose, the movement of the motor then caused the studs to be pulled right out of the timing cover.
 Old 02-24-2013, 09:28 AM   #23
Tokay444's Avatar
Groans: 793
Weird.
Demodded.
The Seals
 Old 02-24-2013, 02:18 PM   #24
Playaj's Avatar
Posts: 1,232   (View Stats)
Playaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the worldPlayaj is the leader of the world
Groaned at 9 Times in 7 Posts
Sent from your Anus
probabaly gonna install this today, any tricks to make it easier than instructions that I shoud know about?
2009 Black Speed3 - AP, JBR Powerpath stage II Sri, JBR 70 duro tmm, JBR Ssb, JBR Short shift kit, JBR RSB, JBR 5mm spacers, ETS Tmic, TWM big type-R shift knob, RX-8 wheels, CPE Stage 2 rmm, H&R Springs, Bilstein B8's
to be installed :
3 Port EBCS
HTP 3" intake/ MAF/ TIH
Autotech internals
Corksport Pmm
Test pipe
SBC Rear Camber Arms
Playaj is offline   Reply With Quote
 Old 02-24-2013, 02:21 PM   #25
Koke382's Avatar
Originally Posted by Playaj View Post
probabaly gonna install this today, any tricks to make it easier than instructions that I shouod know about?
make sure u have an extention and the washers go bellow the plate that connects to the motor, does that make sence? im buzzed sorry. first time i instaled i put the plate then the washers then the nuts and i had a hard time fixing it lol its a tight spot when u dont do it right
Sent from your Anus
1993 Red Na6
 Old 02-24-2013, 03:18 PM   #26
Swivel joints come in handy.
Fluids
Rotella T6 A lot
VP Methanol
~Splash of E85~
 Old 02-24-2013, 05:38 PM   #27
Trail of Fail
Dano's Avatar
Posts: 9,484   (View Stats)
over 2 years here as well and I would go with this 4th mount option over the uber harsh PMM mod. That was my thinking back then and still holds true today.
I use red thread locker on everything engine mount or suspension related so I have never had any issues with things backing off. You do need the supplied spacers placed between the TC and mount or it will create a "spring" condition which might have lead to the failure.
Without the spacers, the ingals mount will not sit flush with the TC and I can see where the cyclic stress would loosen the nuts/studs up.
Celestspeed3 (02-24-2013), silvapain (02-24-2013), Tokay444 (02-24-2013)
Ingalls Torque Damper for MS3 Addikted To Boost MazdaSpeed 3 - Engine, Transmission & Driveline 16 02-28-2014 06:25 PM
Calling all engine torque damper owners! clos561 MazdaSpeed 3 - Engine, Transmission & Driveline 10 09-30-2009 12:28 PM
MS3 ETD (engine torque damper) clos561 MazdaSpeed 3 - Engine, Transmission & Driveline 14 06-11-2009 08:18 AM
Any feedback on Torque/Engine Damper? Qluber MazdaSpeed 3 - Engine, Transmission & Driveline 24 04-23-2009 02:48 AM
Weapon-R Engine Torque Damper TheDoc MazdaSpeed 3 - Engine, Transmission & Driveline 6 10-28-2008 10:43 AM
Page generated in 0.43980 seconds with 30 queries
