 Old 12-28-2009, 03:52 PM   #1
ILoveSpeed's Avatar
Posts: 114   (View Stats)
ILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond reputeILoveSpeed has a reputation beyond repute
Groaned at 24 Times in 4 Posts
Default Ultimate Racing CBE
Ok, I'll admit that I'm a noob at this point in my modding career and I have a very basic question about the Ultimate Racing CBE and any other aftermarket CBE for that matter that may come out. What are the main benefits to installing this? Besides a throatier exhaust note potentially? There are no real power gains to be had from my knowledge unless you add the DP/TP with it, right? Let me know what I'm missing gearheads!
ILoveSpeed is offline   Reply With Quote
 Old 12-28-2009, 05:08 PM   #2
xxspeed3's Avatar
Posts: 380   (View Stats)
xxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond reputexxspeed3 has a reputation beyond repute
Groaned at 6 Times in 3 Posts
looks better sounds better! completes the package of having a TBE.
youll only net maybe 5whrp or so, but like i said ^^^^^^^
Last edited by xxspeed3; 12-28-2009 at 05:08 PM. Reason: MSF Database - Automerged Doublepost
xxspeed3 is offline   Reply With Quote
 Old 12-28-2009, 05:15 PM   #3
ILoveSpeed's Avatar
So maybe CBE with DP? DP would give some pretty good gains from what I've seen but damn that's expensive.
 Old 12-28-2009, 05:18 PM   #4
skeeter149's Avatar
Posts: 3,742   (View Stats)
Groans: 91
i have a cbe on my gen 1. better looks, maybe. better sound yes. power wise= not much if anything. I think maybe i spool 1 rpm sooner. but for me it made the car mine and custom. i love looking at my exhaust and wouldnt change it. but a dp will kill the cbe in power and not to mention the dp with cat is the same price~ as cbe. give or take 100 and who you get. if you plan to do exhaust eventually do it. but if you just want raw cheap power dp and leave stock alone.
 Old 12-28-2009, 05:23 PM   #5
felt's Avatar
Posts: 1,504   (View Stats)
Groans: 1,364
Unless you're a dyno, 5hp isn't noticeable and not worth $500.
Exhaust note is worth $500 though.
felt is offline   Reply With Quote
The Following 3 Users Say Thank You to felt For This Useful Post:
Dre (12-28-2009), PiKA West (12-29-2009), redblur (12-31-2009)
The Following User Says NO Thank You to felt For This Un-useful Post:
 Old 12-28-2009, 05:32 PM   #6
ILoveSpeed's Avatar
Damn, I sure would like both. My mods would be complete or just about engine wise. SRI, DP, CBE would be plenty then I could focus on an aftermarket front fender and LED tail lights.
 Old 12-28-2009, 06:46 PM   #7
KR....i haz it
Blackspeed's Avatar
Posts: 2,845   (View Stats)
Blackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the worldBlackspeed is the leader of the world
Groans: 166
The DP/RP will still change the sound. get that and leave the stock cbe, like said above.
Cobb SRI | Cobb Turbo Inlet | Cobb AP |ETS TMIC 3.25" | CS Inserts |
CS Test Pipe | NGK IV22 | Blitz TT | MSD DH | TWM full replacement | PTP cdfp
While the other forum is GREAT for technical/mechanical information and how to, that place is filled with single-minded (if you aren't driving fast, you're doing it wrong), arrogant, and professional douchebags.
Blackspeed is offline   Reply With Quote
The Following 2 Users Say Thank You to Blackspeed For This Useful Post:
Dre (12-29-2009), PiKA West (12-29-2009)
 Old 12-28-2009, 07:07 PM   #8
ILoveSpeed's Avatar
Would a DP with a SRI require any type of tune? No CEL lights either right?
 Old 12-28-2009, 11:08 PM   #9
xezerax's Avatar
Posts: 116   (View Stats)
xezerax is a name known to allxezerax is a name known to allxezerax is a name known to allxezerax is a name known to allxezerax is a name known to allxezerax is a name known to all
No cat in the DP will cause a cel, so it depends what DP you go with. And depending on your location and how cold it gets by you in the winter the combo of a DP and SRI can cause fuel cut/load cut without a tune.
xezerax is offline   Reply With Quote
The Following User Says Thank You to xezerax For This Useful Post:
Dre (12-29-2009)
 Old 12-29-2009, 10:14 AM   #10
scoobz's Avatar
Posts: 20   (View Stats)
scoobz will become famous soon enoughscoobz will become famous soon enough
if u run a catless dp and have a defouler will it still throw a code?
scoobz is offline   Reply With Quote
 Old 12-29-2009, 10:18 AM   #11
2007speed3's Avatar
Posts: 1,486   (View Stats)
2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world2007speed3 is the leader of the world
Groans: 70
I did,
its a 50/50 chance.
feeling lucky?
2007speed3 is offline   Reply With Quote
 Old 12-29-2009, 10:19 AM   #12
scoobz's Avatar
yea sure why not lol! i was just wondering cuz im gettn ready to order tbe frm ur
 Old 12-29-2009, 11:04 AM   #13
ILoveSpeed's Avatar
I'm freaking screwed then because I live in CO. damn cold here in the winter. maybe i'll just get the UR CBE for now and go DP later
 Old 12-29-2009, 12:09 PM   #14
Dre
Dre's Avatar
Posts: 1,651   (View Stats)
Dre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the worldDre is the leader of the world
Groans: 48
Groaned at 16 Times in 14 Posts
id go with the DP/RP and leave the factory CBE..
"Pain? I ain't got time for pain.. Only pain I got time for is the pain i put on fools who don't know what time it is."
-TTT
Dre is offline   Reply With Quote
The Following User Says Thank You to Dre For This Useful Post:
 Old 12-29-2009, 02:45 PM   #15
xezerax's Avatar
Im rocking a fouler right now and yes i do have a cel. Fail.
 Old 12-30-2009, 06:27 AM   #16
KR....i haz it
Blackspeed's Avatar
Groans: 166
The difference between a high flow cat and no cat is minimal. a few HP, nothing that you will even feel. Just get the catted DP.
 Old 12-30-2009, 11:34 AM   #17
ILoveSpeed's Avatar
Yea, catted DP is what I will get.
2010 Celestial Blue Speed3, Corksport SRI w/TIH, Ultimate Racing CBE w/Ti. tips, DDM 6k HID Lows, Cobb AP, AutoTech Internals
 Old 12-30-2009, 12:53 PM   #18
felt's Avatar
Groans: 1,364
Catted DP = more money, less hp, possibility of still triggering a CEL
Catless DP = less money, more hp, possibility of triggering a CEL.
To me it boils down to cost....
I would go for Catless...
 Old 01-04-2010, 03:32 PM   #19
scoobz's Avatar
ordered ur catless tbe with ti tips today! will but up picks and video when installed
The Following 2 Users Say Thank You to scoobz For This Useful Post:
Dre (01-05-2010), redblur (01-17-2010)
 Old 01-04-2010, 05:39 PM   #20
redblur's Avatar
Posts: 1,083   (View Stats)
redblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the worldredblur is the leader of the world
Groans: 46
Ditto!
|2010 VRM Speed3|
|CS SRI/TIP/TMIC|UR CBE/TP|CP-E HPFP|COBB AP Stg2 FREAKTune|SU BPV|TRZ MM|ITV22's|
redblur is offline   Reply With Quote
The Following User Says Thank You to redblur For This Useful Post:
Dre (01-05-2010)
 Old 01-05-2010, 07:04 AM   #21
Dre
Dre's Avatar
Groans: 48
Id go tbe, but i think im going to stick with dp/rp and keep the rest stock.. i think itll sound really good that way while keeping the stock look.. i just love the look i get from people when i pull on them MUCH harder than they expected, hahah..
-TTT
 Old 01-05-2010, 07:30 AM   #22
shook02's Avatar
Posts: 720   (View Stats)
shook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the worldshook02 is the leader of the world
Groaned at 20 Times in 10 Posts
damn look at u guys spending money! i wish i had the money for a full tbe. justs so u guys know i heard u should upgrade the fuel pump internals when getting a dp. not required. but safe.
2010 Black Mica speed3]
Cobb SRI, Turbosmart BPV, Jbarone ssp, 6k lows, 20% tint all around, Corksport TP
shook02 is offline   Reply With Quote
 Old 01-05-2010, 07:39 AM   #23
Dre
Dre's Avatar
Groans: 48
yea apparently there are a lot of opinions on when to get upgrade fuel pump internals/HPFP.. i really wish we had something to monitor that shit with...
-TTT
 Old 01-05-2010, 07:41 AM   #24
shook02's Avatar
exactly we have no way of monitoring yet so i would really recommend waiting on installing the dp but hey u guys do what u gotta do!
 Old 01-14-2010, 10:15 AM   #25
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
Hey so, I wonder which CBE is less restrictive. I noticed the UR one seems to have split into two smaller mufflers, and the CP-E one is using a single large muffler (like stock)
Here are pics, opinions on which might be the better design and why? (I know nothing about physics or flow dynamics or any of that crap =)
CP-E CBE
UR CBE
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
 Old 01-14-2010, 10:24 AM   #26
5.000000yeah
ridenfish39's Avatar
Posts: 1,269   (View Stats)
ridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the worldridenfish39 is the leader of the world
Groans: 44
Groaned at 30 Times in 18 Posts
I would get that exhaust in a heartbeat but I am afraid once my car goes back to the dealer they'll void my warranty. I think that twin muffler set up looks sick!
2012 MUSTANG 5.0 // BBK X_PIPE//FLOWMASTER HUSHPOWER //3.73 REAR//SVE DRIFTS//JLT OIL SEPARATOR//BMR LCAS//J+M PANHARD BAR//STEEDA PANHARD BRACE//AIR RAID//BAMA//CAT DELETES// LOUD AS HELL
ridenfish39 is offline   Reply With Quote
 Old 01-14-2010, 10:55 AM   #27
shook02's Avatar
not knocking cp-e at all cuz i love their stuff but UR has definitely won my money when it comes to exhaust parts. They all look great.
 Old 01-14-2010, 11:09 PM   #28
SnoXRacer183's Avatar
Posts: 238   (View Stats)
SnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond reputeSnoXRacer183 has a reputation beyond repute
CP-E CBE
UR CBE
To figure out which was less restrictive you'd really need to put them on a flow bench. In theory the one with the least amount of bends or change in flow direction and most volume would be the least restrictive. (It's been a few years since my Fluid Dynamics classes!)
My guess would be the UR one. Straight through muffler design and minimal bends.
2006 Subaru Impreza 2.5
SnoXRacer183 is offline   Reply With Quote
 Old 01-14-2010, 11:14 PM   #29
felt's Avatar
Groans: 1,364
Yeah the UR one seems like good quality, hot diggity make one for the 1st GEN MS3
Ultimate Racing Catback Exhaust 9900rpm 2010 MS3 - Engine, Transmission & Driveline 47 01-23-2014 04:03 AM
FORD RACING UNVEILS THE NEXT GENERATION OF RACING MUSTANG IN THE NEW BOSS 302R Haltech Automotive News 0 12-28-2009 04:20 AM
Beat the Heat: Florida police battling street racing by... racing?! Haltech Automotive News 3 05-02-2009 06:58 PM
Page generated in 0.46123 seconds with 33 queries
