 Old 06-22-2010, 06:19 AM   #1
Dino's Avatar
Posts: 56   (View Stats)
Dino has a spectacular aura aboutDino has a spectacular aura about
Default What oil are you using?
What oil are you running? Getting ready to come back to the States and move to North Dakota. When I was there before I ran 5w30 in my truck for the cooler temps. What would be a good oil to use up in the tundra?
Dino is offline   Reply With Quote
 Old 06-22-2010, 07:15 AM   #2
Aetherfury's Avatar
Posts: 1,227   (View Stats)
Aetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the worldAetherfury is the leader of the world
12,500 miles on mine and I use Valvoline Synthetic 5w40 and we have some serious weather swings in northern virginia.
hobbit-monster likes this.
I drive a white car with a HUGE spoiler
Cobb Accessport Stage 1 + Cobb SF Intake
Aetherfury is offline   Reply With Quote
 Old 06-22-2010, 08:04 AM   #3
cesaros's Avatar
Posts: 1,261   (View Stats)
cesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the worldcesaros is the leader of the world
Groans: 106
Groaned at 53 Times in 41 Posts
Penzoil Platinum 5w30..i live in Wyoming where last week it was 40degrees and a couple flurries, and this week it's 95 degrees and sunny...I win with weather changes.
cesaros is offline   Reply With Quote
The Following User Says Thank You to cesaros For This Useful Post:
Aetherfury (06-22-2010)
 Old 06-22-2010, 10:58 AM   #4
Todd98SE's Avatar
Posts: 1,077   (View Stats)
Just switched from Amsoil Euro 5W-40 to a mix of Pennzoil Ultra 5W-30 (2qts.) and 10W-30 (4qts.). I wish Pennzoil made a 10W-40. I'd like to run that in the summer and their 5W-40 in the winter. I'm in the east county of San Diego so we see 100+ temps. during summer. Both seem like good oils. I'm going to have this oil sent to blackstone for analysis when it's time to change.
MS3VFD81 likes this.
www.MOTOIQ.com
Beater Titan
Todd98SE is offline   Reply With Quote
 Old 06-26-2010, 01:58 PM   #5
maz94protege's Avatar
Posts: 25   (View Stats)
maz94protege is a jewel in the roughmaz94protege is a jewel in the roughmaz94protege is a jewel in the roughmaz94protege is a jewel in the rough
Neutral  :  -1 score
Non-Turbo MZR 2.0l , second oil change, using conventional 5w20 (book recommended) currently at 4,300 miles at around 10k ill switch to semi-synthetic at by 15k ill be fully synthetic.
Quakerstate Oil, Fram 3x Extra Guard Oil Filter
maz94protege is offline   Reply With Quote
The Following User Says Thank You to maz94protege For This Useful Post:
2gr84u (03-24-2012)
 Old 06-26-2010, 04:43 PM   #6
laxplayermjd's Avatar
Posts: 779   (View Stats)
laxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the worldlaxplayermjd is the leader of the world
Neutral  :  -1 score
i was buying w.e 5w30 synthetic they had on sale. now im trying the valvoline 300k engine gaurantee with thier 5w30 syn
2007 Speed 6 Liquid Platinum Metallic, DIY Duplicolor Graphite Wheel Paint, Clutchmasters FX100, Stock again with 91 ots tune
laxplayermjd is offline   Reply With Quote
 Old 06-26-2010, 04:51 PM   #7
CCC
CCC's Avatar
Posts: 830   (View Stats)
CCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the worldCCC is the leader of the world
Groans: 214
Groaned at 15 Times in 13 Posts
OP- Please don't use this weight oil for your speed. Not sure why he is even posting about 2L mazda 3s on here anyhow.
2013 Evo X - Stock (for now)
2010 Speed 3 - Sold
CCC is offline   Reply With Quote
 Old 06-26-2010, 05:03 PM   #8
Monotonous ONE's Avatar
Posts: 3,733   (View Stats)
Groans: 819
i just got my shit changed.
Im using Pennzoil Ultra 5w-30 w/ fram 6x filter
 Old 06-28-2010, 08:14 AM   #9
neverone99's Avatar
Posts: 46   (View Stats)
neverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant futureneverone99 has a brilliant future
Mobil 1 5w30 and OEM filter. Pennzoil Plat or Ultra is highly recommended because of its resistance to chemical shearing. Don't forget the aluminum crush washer on the drain plug. You can get them from your dealer or online. PM me if you want links.
neverone99 is offline   Reply With Quote
 Old 06-29-2010, 09:03 PM   #10
indianaryan's Avatar
Posts: 496   (View Stats)
indianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the worldindianaryan is the leader of the world
Groans: 39
I've heard that Penzzoil Plat is recommended for our engines. Is it better than Mobil 1?
indianaryan is offline   Reply With Quote
 Old 06-29-2010, 11:17 PM   #11
Tucson's First GenPu
AZRushki's Avatar
Posts: 234   (View Stats)
AZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the worldAZRushki is the leader of the world
Any advice for what to use in Tucson AZ heat conditions?
Ya, I got some stuffs in thurr
AZRushki is offline   Reply With Quote
 Old 06-29-2010, 11:33 PM   #12
Mizzle's Avatar
Posts: 2,829   (View Stats)
Groans: 324
I was running Pennzoil Platinum 5w-30 up until switching to Ultra 5w-30. I've had zero issues and my UOA's are phenomenal. Temps ranging from -10F to 95F without issue. I will say, though, that I added a little Marvel's Mystery Oil in the winter just to slick it up for start-up, but it wasn't very much as these synthetics look like running water most of the time anyways.
 Old 06-29-2010, 11:41 PM   #13
I have candy in my van
MATT DAMOND's Avatar
Posts: 1,931   (View Stats)
Groans: 70
Snake Oil
Current Fail:
The Following User Says Thank You to MATT DAMOND For This Useful Post:
nybe0010 (05-17-2013)
 Old 06-30-2010, 01:07 AM   #14
dizzin9's Avatar
Posts: 1,807   (View Stats)
Groans: 77
Pennzoil Ultra... got sucked in to the hype.
 Old 06-30-2010, 06:52 AM   #15
neverone99's Avatar
Pennzoil Platinum seems to handle chemical shear better according to many UOA's on BITOG. I would consider it better for this engine than Mobil 1. Mobil 1 is still good, it's just that PP is a little bit better. Remember that not all engines have this "problem". What performs well in one type of engine may not perform as well in another type.
Chem Shear is when the viscosity of an oil is thinned out because of the introduction of gas in to your oil. This imho is why Mazda recommends 5w30 instead of 5w20 for the 2.3 DISI because many UOA's are showing chem shearing down to a 20 weight. So you put 30 in and end up with 20. Imagine what would happen if you put a 20 weight in...would it chem shear down to 10? Who knows...but I would never try it.
Pennzoil Platinum or Ultra 5w30 or your synthetic of choice. You do want a synthetic, right? Of course you do.
Originally Posted by MATT DAMOND View Post
Snake Oil
I agree. The problem with these oil supplements is that they usually are just a high viscosity mineral oil and a solvent (soap). When you use them you have to use less of your regular oil. Regular oil comes with its own additive package specifically designed for that oil. What happens is you end up with less of the good stuff in your pan. If you substitute 1 quart of regular oil for MMO then you just reduced your additive package by 1/6 and increased the viscosity beyond what Mazda recommends (and warranties?). Is MMO as bad as Lucas? I don't know...perform a VOA and find out. According to the MSDS for MMO it looks like it's about the same however.
MSDS for Marvel Mystery Oil
The Following 2 Users Say Thank You to neverone99 For This Useful Post:
07slsms3 (01-01-2011), indianaryan (06-30-2010)
 Old 06-30-2010, 07:00 AM   #16
ILL3ST
xcoldricex's Avatar
Posts: 2,777   (View Stats)
he's not even asking about what to put in his speed.
 Old 06-30-2010, 08:30 AM   #17
z31maniac's Avatar
Posts: 35   (View Stats)
z31maniac has a spectacular aura about
Groaned at 35 Times in 6 Posts
Interesting place for this question, no?
z31maniac is offline   Reply With Quote
 Old 06-30-2010, 08:33 AM   #18
ILL3ST
xcoldricex's Avatar
yes, not to mention there are a bunch of threads about oil.
 Old 06-30-2010, 08:52 AM   #19
neverone99's Avatar
Pretty sure he was asking what he should use in his 2nd Gen Speed 3 in North Dakota (up in the tundra).
Doesn't matter either way, recommendations are still the same.
The Following User Says Thank You to neverone99 For This Useful Post:
xcoldricex (06-30-2010)
 Old 06-30-2010, 09:03 AM   #20
ILL3ST
xcoldricex's Avatar
hahaha you're right. he was talking about his truck and the tundra and i just linked the two.
if 5w30 worked for the truck in the cold, i don't see why you wouldn't just go with 5w30/5w40 in the speed.
 Old 06-30-2010, 09:38 AM   #21
SPEED3 EDDIE's Avatar
Posts: 113   (View Stats)
SPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond reputeSPEED3 EDDIE has a reputation beyond repute
I'm using 5w40 Castrol Full synthetic. As recommended by Mazda USA.
SPEED3 EDDIE is offline   Reply With Quote
 Old 07-08-2010, 09:30 AM   #22
treyclash's Avatar
Posts: 592   (View Stats)
treyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond reputetreyclash has a reputation beyond repute
Groaned at 321 Times in 98 Posts
how man quarts are you using exactly? i got the 2010 speed 3. i am about to do my first oil change on it and have decided to go with the penzoil plat 5w30. is it the same process as a NA car or do i have to do something special due to the turbo? also autozone should know what kind of filter i need right? what would yall recomend for a filter with the penzoil? be specific please.
2010 Mazdaspeed 3 Liquid Silver.
Performance: -K&N SRI. -CP TP. -Forge BPV.
Interior: -DashDaq.
Exterior: -Rally Armor Mud Flaps. - Xenon 35w 6000.
treyclash is offline   Reply With Quote
 Old 07-08-2010, 10:16 AM   #23
JS + MS3's Avatar
Posts: 1,794   (View Stats)
JS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the worldJS + MS3 is the leader of the world
Groaned at 72 Times in 51 Posts
I'm in Socal area, which oil should I get? and which filter?
I know this question has been beaten to death.. but it will be great if someone can help me out with this.
Is there anyway I can order everything through online? My speed3 just hit 6000.. and am looking to change it out this weekend! So, please help!
2010 Mazdaspeed3
Cobb AP - CP-E SRI - Ultimate Racing TP - CP-E RMM 75D - JBR RSB - JBR SSP - Autotech HPFP Internal - Denso ITV22 - Advan RZ 18x8 (Conti ExtremeContact DW 235/40/18)
JS + MS3 is offline   Reply With Quote
 Old 07-08-2010, 10:33 AM   #24
Groans: 39
Mazdaspeed 3/6 UOA Results
This is a good thread to refer to. It looks like the consensus is Pennzoil Platinum 5w30 or 5w40. I would run 5w40 since you live in a warm climate. I'm not sure if the filter is all that important. I've been using Fram XG3614 (10x protection), but I could probably get away with the 6x protection or maybe even the 3x protection.
As far as how much to add, I've found that there's quite a bit of oil that can't be drained. I put 5 qts in, run the engine for a bit, check the oil level in a couple minutes, and add a little until the oil is close to the max fill line. Don't overfill! If you put in 6 qts, it's going to be too full because there will be maybe about 1/2 qt. leftover that won't drain.
Also, 6,000 is quite a long time to run on the same oil. I know the manual says every 7,500 miles, but UOA's will tell you this is too long. My dealer recommends to change it every 3,500 miles because of the turbo. Other people on this forum have been able to go 4,000+ without any issues on their UOA's. I would send your used oil in to have it tested to get an idea of how often you should be replacing it based on your driving habits and weather conditions.
2010 Silver Mazdaspeed3
The Following User Says Thank You to indianaryan For This Useful Post:
neverone99 (07-08-2010)
 Old 07-08-2010, 10:47 AM   #25
JS + MS3's Avatar
Great. Thanks.
So, what I should purchase are 6 quarts of Pennzoil Platinum 5w40 and Fram XG3614, right?
Yeah, I should have done my oil change sooner, but all my friends were telling me to just do it after 5000 miles... maybe not.
Anyway, thanks!
EDIT:
Amazon.com: Fram XG3614 Extended Guard Passenger Car Spin-On Oil Filter (Pack of 2): AutomotiveAmazon.com: Fram XG3614 Extended Guard Passenger Car Spin-On Oil Filter (Pack of 2): Automotive
this is the fram xg3614 right?
2010 Mazdaspeed3
 Old 07-08-2010, 10:51 AM   #26
Groans: 39
That should do it. The TG3614 should be good enough (6X protection), but it doesn't hurt to go with the XG3614. If you can't find 5w40, you should be fine with 5w30. I'm running 5w30 because the winters suck here in Missouri.
 Old 07-08-2010, 10:53 AM   #27
JS + MS3's Avatar
Thanks alot! Ordering them right now.
2010 Mazdaspeed3
 Old 07-08-2010, 11:02 AM   #28
Groans: 39
No problem. I'm not an expert by any means, so you might see if anyone else has any suggestions too.
 Old 07-08-2010, 11:04 AM   #29
JS + MS3's Avatar
You've already convinced me back on post $24.
Thanks! can't wait to change them out and be happy with it!
2010 Mazdaspeed3
 Old 07-08-2010, 12:03 PM   #30
Slow*Jim's Avatar
Posts: 210   (View Stats)
Slow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond reputeSlow*Jim has a reputation beyond repute
Groans: 30
<= Did my 1st oil change at 1k, although the oil looked clean unlike some other people have reported. Got it changed with standard Pennzoil, I'll switch to Platinum when I get a job
Black '10 15,800mi FOR SALE 20k!!! | Corksport SRI/TIP | Corksport Racepipe
http://www.mazdaspeedforum.org/forum/forum/f430/2010-speed3-15-800-miles-101327/
Slow*Jim is offline   Reply With Quote
 Old 07-08-2010, 01:06 PM   #31
neverone99's Avatar
Don't forget the aluminum crush washer for your drain plug. You can get them here. Looks like they have a good deal on OEM filters as well (which I prefer).
 Old 07-09-2010, 11:48 AM   #32
skawt01's Avatar
Posts: 228   (View Stats)
skawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the worldskawt01 is the leader of the world
Groaned at 24 Times in 3 Posts
This might sound weird, but when I changed my oil the first time there was no crush washer present. It didn't fall onto the drain bin, and it wasn't stuck to the drain nut either, and no leaks to date. Our Subaru doesn't have a washer either. Anyone else have a "washerless" oil drain plug out there??
skawt01 is offline   Reply With Quote
 Old 07-16-2010, 10:50 PM   #33
Mizzle's Avatar
Groans: 324
Shame to see you put in conventional on a car that calls for synthetic to save $15... when you're changing your stock oil 4,000+ miles earlier than necessary.
:edit:
Also, Purolator Pure One or an Amsoil filter.
Fram sucks.
The Following User Says NO Thank You to Mizzle For This Un-useful Post:
 Old 07-17-2010, 05:47 AM   #34
Amazon's Avatar
Posts: 2,679   (View Stats)
Amazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the worldAmazon is the leader of the world
Groans: 214
Groaned at 114 Times in 83 Posts
Why does my Speed3 come stock from the factory with a Honda drain bolt and a Toyota oil filter? lol
Amazon is offline   Reply With Quote
 Old 07-17-2010, 07:49 AM   #35
HutcHJC's Avatar
Posts: 248   (View Stats)
HutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the worldHutcHJC is the leader of the world
Didn't notice the Toyota filter, I'll have to check later. I know the dipstick says FoMoCo, which makes sense.
HutcH
2010 Black Mica MazdaSpeed3 - jbarone stage 2 ssp w/ weighted shift knob - cp-e 60D rmm - 15% Tint + AIR Blue 80 - DDM 55w 5000k HIDs (waiting to install) - CorkSport SRI+TIP (on order) - EBC RedStuff Brake Pads (on order)
HutcHJC is offline   Reply With Quote
 Old 07-20-2010, 03:59 PM   #36
bart1313's Avatar
Posts: 30   (View Stats)
bart1313 has a little shameless behaviour in the past
Groaned at 12 Times in 3 Posts
Just did my first oil change. This is the easiest car ever to change the oil! I did the change at 1K. Does anyone know why the dealer (who will do free oil changes) say every 3,750 miles, while the manual and the mymazda.com pages say every 7,500 miles? I was planning to do it on my own (mobil 1) every 3,500.
Does anyone know the reasoning behind the difference?
Thanks,
Bart
bart1313 is offline   Reply With Quote
 Old 07-20-2010, 04:34 PM   #37
cesaros's Avatar
Groans: 106
Thanks,
Bart
it doesn't matter. just do it on your schedule...3500 is better than 7500.
:edit:
Fram sucks.
conventional or synthetic...what difference is it to you?
he changed his oil...thats better than waiting till the recommended 5000miles.
Last edited by cesaros; 07-20-2010 at 04:35 PM. Reason: MSF Database - Automerged Doublepost
 Old 07-20-2010, 07:21 PM   #38
neverone99's Avatar
:edit:
Fram sucks.
Pretty sure that Mazda doesn't require synthetic in any of their vehicles (If I'm wrong someone correct me). I believe it is because of the rx8...but I do run synth in my car. Oh and Fram does suck...they run in bypass all the time from what I have read.
Thanks,
Bart
I would run the Mobil1 to 4k and then send a sample to Blackstone and have the experts tell you how long to run your oil.
 Old 07-20-2010, 08:33 PM   #39
Slow*Jim's Avatar
Groans: 30
:edit:
Fram sucks.
Lol, It's a Mazda not a BMW. It'll be fine.
The Following User Says NO Thank You to Slow*Jim For This Un-useful Post:
 Old 07-25-2010, 10:12 PM   #40
Mizzle's Avatar
Groans: 324
Explain to me how the make affects the quality of fluid recommended to run it...
At any rate, Fram is proven garbage. I may be wrong on the synth requirement, but it's proven our engines are in love with Pennzoil Platinum so why you'd be cheap is beyond me. It's a small investment to keep the $25,000 piece of equipment you just bought running smoothly.
The Following User Says Thank You to Mizzle For This Useful Post:
igve2shtz (08-23-2015)
Page generated in 0.61088 seconds with 42 queries
