  • 1 Post By HEAVY__G
 Old 06-29-2015, 08:08 AM   #1
HEAVY__G's Avatar
Posts: 34   (View Stats)
HEAVY__G is a name known to allHEAVY__G is a name known to allHEAVY__G is a name known to allHEAVY__G is a name known to allHEAVY__G is a name known to allHEAVY__G is a name known to all
Default 2010 MS3 / K04 / E30 Stratified Tune
I had a chance to get on an actual dyno finally and figured I would share my results with you all. I have what seems to be a very common build so those with similar mod lists and fueling should be somewhere in this ballpark. The VDyno I received from Alex at the end of the tuning process for the E30 mix indicated I would be somewhere in the 305 whp range, so take that as you will.
Hokie D likes this.
2010 MAZDASPEED 3
CS TD05H-18G TURBO | JBR 3" SRI | JBR EBCS | COBB AP V3 | CP-E TMIC | COBB TBE | AUTOTECH INTERNALS | TURBOSMART DUAL PORT | BOSCH 3 BAR MAP W/ JBR PNP HARNESS | NGK 6510 | JBR TRILOGY 88/80 | JBR SSP/BUSHINGS | KONI YELLOW | H&R SPRINGS | XXR 522 18X8.5 +48 | MICHELIN PILOT SUPER SPORTS 235/40/18 | RALLY ARMOR FLAPS | TRS MORIMOTO 35W 5000K | CORKSPORT INTERIOR LED | JBR OCC | COBB RSB | JBR EGR DELETE | STRATIFIED GUARDIAN ANGEL | FREEKTUNED
HEAVY__G is offline   Reply With Quote
The Following 6 Users Say Thank You to HEAVY__G For This Useful Post:
Code Monkey (06-29-2015), davychronic (07-02-2015), Gr8Speed (06-29-2015), JgamB (06-29-2015), speed23 (06-29-2015), thepatient77 (06-29-2015)
 Old 06-29-2015, 09:01 AM   #2
thepatient77's Avatar
Posts: 162   (View Stats)
thepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond reputethepatient77 has a reputation beyond repute
Good looking numbers man!
thepatient77 is offline   Reply With Quote
The Following User Says Thank You to thepatient77 For This Useful Post:
HEAVY__G (07-02-2015)
 Old 07-02-2015, 09:11 AM   #3
davychronic's Avatar
Posts: 1,155   (View Stats)
davychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the worlddavychronic is the leader of the world
Is this on a one of their ots maps?
Sent from my SAMSUNG-SM-N910A using Tapatalk
06 MS6 GT Titanium Gray II Metallic
davychronic is offline   Reply With Quote
 Old 07-02-2015, 09:35 AM   #4
HEAVY__G's Avatar
No, sir. This is using a full blown custom tune that Alex @ Stratified did for me.
2010 MAZDASPEED 3
The Following User Says Thank You to HEAVY__G For This Useful Post:
speedfreak44 (07-03-2015)
 Old 07-02-2015, 09:37 AM   #5
Those are good numbers, I am also on e30 and not far behind that on ms6. Are you able to get e30 straight from the pump as well?
The Following User Says Thank You to davychronic For This Useful Post:
 Old 07-02-2015, 09:44 AM   #6
HEAVY__G's Avatar
Thanks, I was pretty happy with what it put down. I was with a couple friends of mine who are in the N54 BMW 335 scene who had organized a dyno day and, although I was out-gunned by many of those guys, everyone seemed fairly impressed with what my little station wagon was capable of.
No pre-mixed E30 here (I didn't realize that was even a thing!) but calculations are pretty easy using a fuel tester and this app I downloaded.
2010 MAZDASPEED 3
 Old 07-02-2015, 09:49 AM   #7
Over here in corn country, main reason I switched to e. Hard time finding premium gas, way easier to find premix e. I feel like if everyone payed attention to all the studies the government did on e and contacted their congressperson to get a decent rfs bill then this could be everywhere. I am a corn farmer and i hate all the anti-ethanol bullshit big oil pushes
 Old 07-02-2015, 09:58 AM   #8
tegxsi's Avatar
Posts: 1,281   (View Stats)
Groans: 87
You have it easy... many of us need to swipe card, pump, swipe card, and pump.
Even more annoying if E85 and petrol are separate pumps.
2018 Audi RS3
2007 Acura TSX 6MT
 Old 07-02-2015, 10:03 AM   #9
HEAVY__G's Avatar
Can you really rely on the E30 to be accurately mixed? Any experience with variation in the mix? I know here during the winter months the "E85" is more like E65 when you test it because of the winter blend.
You should have seen my gf's face the first time she came with me to get gas. Calculate E85 needed, swipe card, pump. Move car 20 ft to other pump, swipe card, pump. She was appalled that I went through that much effort to get gas. BECAUSE RACE CAR
2010 MAZDASPEED 3
 Old 07-02-2015, 10:09 AM   #10
This could happen nationwide if we het enough people asking for it. We need a better rfs bill. Price of corn was cut in half from 2 years ago thanks to the dipshits in DC.
Haha yea what a pita. My ltft's are never over +-3% so the fuel is consistant. I run way more timing than the stage 3 map so although i have no clue the oct rating, i can run 19* up top no knock. Still get 26-27 mpgs also. When i head down to Texas next month i will get to feel the mixing pain for a week, glad its only a week.
Last edited by davychronic; 07-02-2015 at 10:09 AM. Reason: MSF Database - Automerged Doublepost
 Old 07-03-2015, 06:32 AM   #11
tmillner's Avatar
Posts: 621   (View Stats)
tmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the worldtmillner is the leader of the world
Where are you going in Texas?
UR TBE/JBR RMM/UNKNOWN HPFP INTERNALS/COBB V2 AP/CS SRI + TIH/CXRACING FMIC
tmillner is offline   Reply With Quote
 Old 07-03-2015, 11:29 AM   #12
Dallas area, Lake Lewisville to be specific. Its where i grew up originally.
 Old 07-03-2015, 11:45 AM   #13
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Very good numbers. @Lex; @Mike@Stratified; do you guys think any more power could be had with a 3" ID vs oem sized intake on this setup?
The line up:
 Old 07-06-2015, 04:08 AM   #14
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
A little but not much, maybe 5hp.
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
First Stratified S-OTS+ Tune Jadcock 2010 MS3 - ECU Computer Tuning 45 07-09-2014 08:57 AM
Stratified Tune phahengpro MazdaSpeed 3/6 - ECU Computer Tuning 42 03-07-2014 03:29 PM
Stratified tune done. MS309 Stratified Automotive Controls 57 08-04-2012 05:39 PM
Stratified (Lex) Tune! (330/393 VD) psychophyr Stratified Automotive Controls 11 02-23-2012 04:39 PM
Page generated in 0.33856 seconds with 27 queries
