 Old 09-12-2015, 12:49 PM   #1
wydoc's Avatar
Posts: 73   (View Stats)
wydoc is just really nicewydoc is just really nicewydoc is just really nicewydoc is just really nicewydoc is just really nice
Default 25% E mix VD and logs
Car mods - AT internals, JBR 3.5in, CNT catless DP, res del/cat del stock exhaust, jbr 88rmm, nothing else really power wise.
On the VD if i change it to Dynojet like some people have been saying lately it reads 340+ 380+ at every soothing level. I am not convinced though.
How does the log look?
wydoc is offline   Reply With Quote
 Old 09-12-2015, 04:00 PM   #2
speedfreak44's Avatar
Posts: 1,391   (View Stats)
Reads 320/350?
The line up:
 Old 09-12-2015, 04:18 PM   #3
wydoc's Avatar
Reads 320/350?
323/360 with cf 1.01 and my weight added on, didn't check the sae box. Changing to dynojet it shoots up to 348/390. The road was definitely flat as well. Seems like my vd is reading way too high tbh i just wanted to make sure logs looked fine to others.
It was a nice cool 65-68ish outside.
 Old 09-12-2015, 05:48 PM   #4
sheston's Avatar
Posts: 1,847   (View Stats)
Looks good. Timing advance is fairly aggressive if you didn't tune for it on a dyno.
I would look into fixing those fuel pressure dips. Probably not real, but search for related threads and they say you can possibly clean the fuel pressure sender contacts.....
 Old 09-12-2015, 06:48 PM   #5
My shit must be fucked. I spike 21 on my map around 3500 and taper off around 4000...seems like you hold boost a little better.
The line up:
 Old 09-12-2015, 07:00 PM   #6
wydoc's Avatar
idk mines an 11 with 57k on it so yours is newer than mine so i doubt its too bad haha
 Old 09-12-2015, 07:04 PM   #7
Doesn't mean my shit isn't brokeded lol. I fucking wish I had a station with E near me ��
The line up:
 Old 09-12-2015, 07:19 PM   #8
wydoc's Avatar
Lol I get high VD numbers and think mine is broke for being too high of numbers...
and its prolly 3.5" v 3" intake plus the E as far as boost goes. Indiana has a lot of E
 Old 09-12-2015, 07:35 PM   #9
It probably is 100% the E considering you can run good timing...and I probably could push my k04 slightly more if realllly needed. Congrats on the tuning. Self tuned?
The line up:
 Old 09-12-2015, 07:43 PM   #10
wydoc's Avatar
Edited a PurpleDrank tune that was reading 309 340ish on the 1.01 setting so I can't take credit.
 Old 09-12-2015, 08:30 PM   #11
sheston's Avatar
@speedfreak44; Can you get Meth? That stuff works better than E in the tank. I run 2 gallons per tank, and can't knock :-)
 Old 09-12-2015, 08:33 PM   #12
I can always order meth in but it costs more than E doesn't it? Also, any fuel pump issues with that shit? #threadjack ....sorry
The line up:
 Old 09-13-2015, 07:44 PM   #13
sheston's Avatar
Just to help thread jack - I get Meth for a little less than $4 a gallon, but use less than half the E I used to. Comes out ahead. I haven't had any issues in the year and a half I've been running it :-)
First Logs Need Help With Logs/E-Tune Volcomstone7 2010 MS3 - ECU Computer Tuning 25 04-23-2013 08:57 AM
First logs & 1/4 mile logs N2o 2010 MS3 - ECU Computer Tuning 19 09-20-2012 07:05 PM
Maf Cal logs 2k4_8 2010 MS3 - ECU Computer Tuning 5 02-24-2012 05:18 AM
First AP logs, How do I look?? dadderllama MazdaSpeed 3/6 - ECU Computer Tuning 10 10-07-2011 07:11 AM
Please take a look at my first ever logs kunfu
Cobb Access Port/Maps
2 03-15-2011 07:09 PM
Page generated in 0.30698 seconds with 23 queries
