![]() Join Date: May 2015 Location: Greensboro, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2
Groaned at 19 Times in 6 Posts
__________________ 2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT |
| The Following 5 Users Say NO Thank You to Mmahan3510 For This Un-useful Post: | faeker (06-08-2016), g00s3y (05-23-2016), MD1032 (05-23-2016), rymanmazda (06-08-2016), Vansquish (05-23-2016) |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| No fucking way. At most you're around 300whp on the stock turbo with that amount of boost.
![]() Join Date: Apr 2009 Location: Wooster, OH
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 210
| Not Ranked : 0 score AP vdyno are very inaccurate and unreliable. many threads on it available for reading. I believe virtual dyno is a little more accurate than the cobb ap dynometer....but still not as good as an actual dyno
__________________ 07 SPEED 6 W/ GEN PU MOTOR SWAP/BNR S3/ K27 OIL FEED LINE/CUSTOM OIL DRAIN LINE/COBB INJECTOR SEALS/COBB XLE/CX RACING FMIC/CORKSPORT POWER SERIES 3" EXHAUST (CATLESS)/M2 3" DOWNPIPE (CATLESS)/COBB AP V3/GRIMMSPEED EBCS/JBR 3.5" WIDE PATH INTAKE/XS POWER V3 TURBO MANIFOLD/PNP INTAKE MANIFOLD/AUTOTECH INTERNALS/3 BAR MAP SENSOR/VTCS DELETE/KOZMIC MOTORSPORTS EGR DELETE/JBR BSD & BAFFLE TRAY/JBR OCC/NGK PLUGS/SURE TORQUE R6 RMM/AWR TRANSMISSION & PASSENGER MOUNTS/SURE JUGGERNAUGHT REAR DIFF MOUNT/CORKSPORT REAR DIFF MOUNT/FIDANZA FLYWHEEL W/ LUK CLUTCH/TWM SHORT SHIFTER/SURE COUNTER SHIFT/SURE SHORTCUT/H&R LOWERING SPRINGS/KONI YELLOWS/ WHITELINE RSB/ AWR END LINKS FRONT&REAR/ CORKSPORT FRONT & REAR STRUT BARS/SPC FRONT CAMBER BALL JOINTS/BRAIDED STEEL BRAKE & CLUTCH LINES/FIBER IMAGES VENTED HOOD/CORKSPORT FRONT PLATE RELOCATE/PC VALVE COVER/TRUNK MOUNTED RED TOP/INTERIOR MODS K04 93 FREEKTUNED 271 AWHP/296TQ K04 E85 FREEKTUNED 309 AWHP/360TQ BNR S3 93 FREEKTUNED 336 AWHP/360TQ BNR S3 E85 FREEKTUNED 375 AWHP/376TQ |
(Thread Starter) | Not Ranked : 0 score on my 93 tune on vdyno it said 282whp and 320wtq, this also seemed accurate. but im gonna be hitting a dynojet in the next few weeks to get some real life numbers. i just wanted to hear some feedback on how off these vdynos really are lol
![]() Join Date: Apr 2013 Location: Somersworth, NH
Rep Power: 878 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5,570
| Not Ranked : 0 score Inb4 Brentune!
__________________ 2012 NASA Spaceship Gray MS3 BNR S3 - JBR Tru 3.0" - CP-E TMIC - Corksport catless DP - Corksport catted race pipe - Forge V2 - Autotech internals + AP v3 - Swift springs - Enkei RPF1 17x9 + 45 (5mm JBR spacers in the front) - Freektune 320/346 |
| The Following User Says Thank You to KiwiFlavor For This Useful Post: | Vansquish (05-23-2016) |
(Thread Starter) | Not Ranked : 0 score just plugged it in to virtual dyno and its saying 309hp and 354tq, that sounds much more like what this thing should actually be putting down
(Thread Starter) | Not Ranked : 0 score this is the virtual one, so all can see
(Thread Starter) | Not Ranked : 0 score and here is the log to go with that
![]() Join Date: Jul 2013 Location: Westchester, IL
Rep Power: 4924 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 14,635
| Not Ranked : 0 score Lol, were you on a roller coaster for that log?
__________________ 2013 MS3 Black Mica SLUGGISH RUGGISH BONE SLUNTWORKS SPEEDSHOP |
| The Following 4 Users Say Thank You to WetzMS3 For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score i was wondering the same thing haha seems quite a bit wavy for my liking
| Not Ranked : 0 score ![]() Flat, smooth roads are your friend.
| The Following 2 Users Say Thank You to WetzMS3 For This Useful Post: | KiwiFlavor (05-23-2016), Vansquish (05-23-2016) |
| Not Ranked : 0 score ya, thought you said you were on a "flat straight road"?
(Thread Starter) | Not Ranked : 0 score this same entrance ramp/highway flat i have used for the past few weeks of tuning. i thought it was flat....apparently i have been corrected and need to find a truly flat road somewhere! all in all i am not believing those high AP dyno numbers, and would like to assume that the virtual dyno numbers are much more accurate until i can get on a dynojet
__________________ 2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT Last edited by Mmahan3510; 05-23-2016 at 07:55 AM. Reason: MSF Database - Automerged Doublepost |
![]() Join Date: Feb 2014 Location: TEXAS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,527
Groans: 64
| Not Ranked : 0 score Wishful thinking lol. I hope I make those numbers when I go with a bigger turbo.
__________________ ~2013 BLACK MS3~ COBB: (APV3//Exhaust Hangers) CS: (TMIC//RP//Leather Knob//Battery Box//Interior LEDs) JBR: (3" SRI//80 Threesome//SSP//SSB//TB TIG//Coolant Bypass//Rice Flaps, EGR delete, OCC) Magnaflow CBE//GFB BOV//FREEKY DEEKY OTS+ 》》》SUPPORT YOUR MSF VENDORS《《《 |
| Not Ranked : 0 score Don't Speed3's trend more accurately with the correction factor set to CF1.01 rather than the default dynojet numbers? Also set the smoothing to 3 and be sure you've got weight set accurately- including your weight & any tools/speaker boxes etc. under Occ. Weight.
| The Following 2 Users Say Thank You to TiGraySpeed6 For This Useful Post: | mxlplx71 (06-08-2016), NavySailorMS3 (06-08-2016) |
(Thread Starter) | Not Ranked : 0 score nothing in the car but myself, i dont know the exact weight of the car, smoothing to 3 makes it look like this
(Thread Starter) | Not Ranked : 0 score just got the correction factor set to 1.01 and now this is what i got...almost seems like this is a little low for mods and e85 tune, or is this just about correct?
Groans: 64
| Not Ranked : 0 score Seems pretty accurate to me, based on other people's results. Pretty good numbers IMO.
| The Following User Says Thank You to Thepedigree13 For This Useful Post: | Vansquish (05-23-2016) |
![]() | | #19 | ![]() |
(Thread Starter) | Not Ranked : 0 score Well thank you and will at purple drank is awesome to work with never even waited 24hours for a revision, customer service was fantastic! Sent from my VIVO XL using Tapatalk
![]() | | #20 | ![]() |
Groans: 143
| Not Ranked : 0 score The problem is that he didn't set all of the throttle position cells to 75% and he's on a load based tune that will pull throttle position at low RPM's. This fucks up vdyno. So much for 360/400. Those numbers look a lot more realistic however, and that's a pretty solid result. That's a relatively conservative tune. You have a little more headroom for power if you bump up wastegate more in the top end and dial in ignition timing on a dyno. Partially depends on how long you want your K04 to last. Haha.
| The Following User Says Thank You to MD1032 For This Useful Post: | Vansquish (05-24-2016) |
![]() | | #21 | ![]() |
Groans: 33
| Not Ranked : 0 score I consistently made 285awhp (320 FWD) on stock size cs intake, catted cpe dp, cpe tmic and 25% E85 with CF 1.01 and smoothing 3. So you should have a little bit more potential with your mods. But you can never trust only 1 VD log, gotta put like 5-10 in there and get a good average. My numbers varied from 270-305 but 285 was what it showed on most logs. Though, every car is different and will react differently to mods. Especially when using different tuners. Weather makes a lot of difference too
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score He told me to send him logs when I get on the dyno so that he can dial in a little more. So hopefully we can push out a little more after the dyno Sent from my VIVO XL using Tapatalk
![]() | | #23 | ![]() |
(Thread Starter) | Not Ranked : 0 score MD1032, should i ask for this to be done or will it even make enough of a difference for me to worry about? and i was under the assumption that 21-22psi is all the k04 can handle? i also have noticed in my logs that psi is dropping from that point all the way down to 16-17psi when i have seen a lot of logs posted up here that hold 18psi to redline
![]() | | #24 | ![]() |
Groans: 143
Holding 18 psi to redline might be an unrealistic expectation. Even on my car being fully catless and a big intake and upgraded intercooler, running 100% WGDC, I wasn't over 18 psi at redline most days, more like 17-17.5. It depends a lot on the weather.
__________________ 2007 Mazdaspeed3 GT | |
![]() | | #25 | ![]() |
(Thread Starter) | Not Ranked : 0 score My mix now is 4gal per tank. And I have 85k on motor now. I'm not too worried about the turbo at the moment. If it goes out I buy a CS replacement and call it a day. I also don't push my car everyday. This car is a DD that carries my wife and two kids around also. So if we turn up the wgdc and push another gal or two of e85, will I be able to see an improvement that is worth pushing the turbo that hard? Trying to stay somewhat reliable. Just put on a CS OCC today also to keep things clean Sent from my VIVO XL using Tapatalk
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score todays log, from the same place as yesterday, still seems right on point for where i am supposed to be power wise, also the graph looks much better and log looks awesome to me, please chime in and let me know what you guys think and if you see something i dont!
![]() | | #27 | ![]() |
(Thread Starter) | Not Ranked : 0 score i was really hoping to be around 320whp and 350wtq, is that going to be possible with more aggressive tuning?
![]() | | #28 | ![]() |
Groans: 143
| Not Ranked : 0 score OK...again, you need to set all your throttle position cells to 75% before importing the log into vdyno, or your vdyno will look like that...
![]() | | #29 | ![]() |
(Thread Starter) | Not Ranked : 0 score do you mean in the log? or do you mean through accesstuner? i do not have accesstuner software. can this be done through the AP? i did it through the log before i imported to virtual dyno and these are the 2 logs and 1 adjusted to 75. not sure if this is what you are looking for but they are all 3 very very close on the graph.
![]() | | #30 | ![]() |
![]() Join Date: Mar 2013 Location: Accokeek MD
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 81
Groaned at 7 Times in 5 Posts
| Not Ranked : 0 score Dude stop chasing numbers. If the car feels good and pulls good then just leave it at that. If you want real numbers go hit a dyno. Otherwise you are always going to disappoint yourself because you thought you were putting down more power blah blah blah...
__________________ 2013 LSM w/tech Cobb AP V3, CBE CS Turbo tuned by PD Corksport Catted DP/HPFP Internals JBR FMIC Pipe Kit w/TR8 CP-E TIP/3.5" Intake DM OCC/TMM Forge V2 BPV Bilstein B8 w/Swift springs Wilwood 6 pot BBK EBC RedStuff rear pads Konig Hypergram 18x8.5" |
| The Following User Says Thank You to JakeMS3 For This Useful Post: | MD1032 (05-24-2016) |
![]() | | #31 | ![]() |
| Not Ranked : 0 score In the logs. In that last log it looks like lines 25 through 199 should be set to 76 in the Throttle Position (%) column. If you add in Accelerator Pedal Position it will be easier to tell since that should, for WOT logs, go to 100% and you can just enter 76 in the TP column for the whole range where APP is 100
![]() | | #32 | ![]() |
(Thread Starter) | Not Ranked : 0 score ok, i got it now lol and yes i am going to hit a dyno maybe next week, working six days this week
![]() | | #33 | ![]() |
![]() Join Date: Nov 2011 Location: Raleigh, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,624
Groans: 63
| Not Ranked : 0 score where in NC are you?
__________________ Blue Pu. "Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." |
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score Greensboro, you? Sent from my VIVO XL using Tapatalk
![]() | | #35 | ![]() |
![]() Join Date: Oct 2012 Location: Austin, TX
Rep Power: 282 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 406
| Not Ranked : 0 score I follow this: How To: Setup and use Virtual Dyno Also, I've read recently that VDyno's DynoJet correction factor is much more accurate than it used to be; assuming you do the SAE correction too. See @g00s3y; post #22 stock dyno & Cobb v-dyno numbers I have similar mods to you, and my VDyno shows 326/365 at 64 degrees ambient temp. I have slightly more timing than you up top though. Once I find a way to justify the $125 for 3 pulls, I'll get actual numbers.
__________________ 2008 Mazdaspeed3 GT JBR TRU 3.5 Aluminum WP // Corksport TBE // JBR OCC Stage 2 // AP v3 (Tweaked [by me] E40 Tune) // Autotech Internals // Stratified EBCS // TWM Full Replacement w/ Type R Knob // CP-e Stage 2 RMM // JBR/Damond Full EGR Delete // Synchronic DV // NGK 6510s // FMIC [TR8 w/ JBR Pipes] // CorkSport Adjustable Struts/Lowering Springs // Progress RSB Jet Black Wax (06/24/2017) Better compression than Silaramic (02/20/2016) |
| The Following 2 Users Say Thank You to Shwaykid For This Useful Post: | impossible (06-07-2016), mxlplx71 (06-08-2016) |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score My Cobb dyno was the original post numbers and the virtual dyno were all the others that seem more accurate. I can do 3 pulls for $60 here, which is a great price! Sent from my VIVO XL using Tapatalk
![]() | | #37 | ![]() |
| Not Ranked : 0 score It'll be interesting to see where you end up - closers to DJ or 1.01 numbers. Be sure to post what type of dyno you're on. it'd be great to drop the 1.01 stuff
![]() | | #38 | ![]() |
(Thread Starter) | Not Ranked : 0 score Will do for sure! Sent from my VIVO XL using Tapatalk
![]() | | #39 | ![]() |
![]() Join Date: Oct 2011 Location: brooklyn, ny
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 240
| Not Ranked : 0 score @TiGraySpeed6; what should the settings on v dyno for the ms6 be? |
![]() | | #40 | ![]() |
(Thread Starter) | Not Ranked : 0 score I think 1.09....correct me if I'm wrong! Sent from my VIVO XL using Tapatalk
