Like Tree11Likes
 Old 05-23-2016, 07:07 AM   #1
Mmahan3510's Avatar
Posts: 93   (View Stats)
Mmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of light
Groaned at 19 Times in 6 Posts
Default 362whp and 405wtq
Just curious how accurate some of you guys think this accessport vdyno is. I am e85 tuned at 21.5-22psi by purple drank as it says in my signature. Temp was bout 65 flat straight road and no wheel spin at the track of this vdyno. I know these things can be sketchy sometimes, but this seems fairly accurate. Thoughts???
2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT
Mmahan3510 is offline   Reply With Quote
The Following 5 Users Say NO Thank You to Mmahan3510 For This Un-useful Post:
faeker (06-08-2016), g00s3y (05-23-2016), MD1032 (05-23-2016), rymanmazda (06-08-2016), Vansquish (05-23-2016)
Page generated in 0.58863 seconds with 32 queries
