 Old 09-25-2017, 01:42 PM   #1
andale927's Avatar
Posts: 193   (View Stats)
andale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant futureandale927 has a brilliant future
Default BNR S4 E25 Dyno
Made 365whp/341wtq, mods in sig
Also here's a video:
2013 Mazdaspeed 3 w/ Tech - Purchased Jan 2017
Power:
BNR S4 v2 Turbocharger | JBR 3.5" Aluminum Intake | JBR Battery Box | GFB Respons BPV |Depo Racing Catless Downpipe | Bosch 3 BAR MAP | JBR 3 Port EBC | Treadstone TR8 Kit w/ Piping | Autotech HPFP Internals | Ultimate Racing Catback | Cobb Accessport V3 | Devils Own Meth Kit (D05) | Custom Tru-Cool Oil Cooler | FREEKTUNED E30 Mix+Meth
Handling:
KW V3 Coilovers | CS Camber Plates | SPC Rear Camber Arms | Michelin Pilot Sport 4S 235/40/18 | Full Damond Motor Mounts | JBR Weighted Shift Knob | JBR Shift Bushings | JBR Rear Sway Bar | Damond Short Shift Plate
Other:
Cobb Polyurethane Exhaust Hangers | Speedline Hood Struts | Corksport CF Hood Scoop | Damond OCC Stage 1 | Corksport E-Brake | Corksport Steering Wheel | Avid.1 AV-20 Wheels 18x8 +35
andale927 is offline   Reply With Quote
The Following User Says Thank You to andale927 For This Useful Post:
Code Monkey (09-25-2017)
stock dyno & Cobb v-dyno numbers garf 2010 MS3 - Dyno Sheets/Discussions 45 04-08-2016 11:51 AM
AEM lets you hook up your car to a dyno at home with Dyno-Shaft Haltech Automotive News 2 11-23-2011 05:39 PM
Dyno runs: Renault Megane RS, Mazdaspeed 3 and Focus RS [Pics, dyno sheet and Video] ganque MazdaSpeed 3/6 - Dyno Sheets/Discussions 25 01-20-2011 02:03 AM
Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? desperado callado MazdaSpeed 3/6 - Dyno Sheets/Discussions 10 05-18-2009 11:27 AM
Page generated in 0.22432 seconds with 21 queries
