![]() Join Date: Aug 2012 Location: San Fernando Valley, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 309
Groaned at 9 Times in 2 Posts
(Thread Starter) | Not Ranked : 0 score 2 days before the event, I pumped 100 octane race gas to stave off any knock. I also performed a boost leak test morning of; just to ensure everything was OK (I found a leak at the BPV which was remedied). All mods are listed in my signature. The Result: I Made 227 WHP and 266WTQ on a dynojet (ambient temp around 70*f). I was too stupid to realize that i should have logged the car while it was on the dyno, so i cant provide those. ![]() To be perfectly honest, i was expecting something in the neighborhood of 280whp and ~300wtq (wishful thinking, i suppose) My questions: I understand that all cars are different and OTS maps generally suck, but can cars really vary that much? or can i just assume that my that there is something wrong with my car? will an E-tune (e85) really get me to where i wanna be, which is ~300whp and ~350wqt (and ~80hp gain and ~90wtq) ? i have logs from a few days before the event. I don't know if they'll be of any use, but ill attach them anyway.
__________________ Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM-- |
![]() Join Date: Mar 2011 Location: St. Boni, MN
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 355
Groans: 34
| Not Ranked : 0 score Hmm... was expecting ZZB.. |
| The Following 21 Users Say Thank You to speed_freak91 For This Useful Post: | bob^3 (07-23-2013), bstover17 (07-31-2013), Cheapspeed (07-16-2013), CorkSport (07-18-2013), cshunter (07-16-2013), Dralphy (07-17-2013), Easter Bunny (07-23-2013), El_Diablo (07-23-2013), gigliotti175 (07-31-2013), himurax13 (07-16-2013), Mfinlay04 (07-16-2013), Micha (07-16-2013), ms3rick (07-23-2013), obijack (07-23-2013), SarcasticOne (07-17-2013), shopety2012 (07-23-2013), sleepyspeed6 (07-16-2013), SofaKingAwesome (07-31-2013), tbot (07-16-2013), Voltron (07-25-2013), Zdraveca (07-25-2013) |
![]() Join Date: Sep 2012 Location: Elizabeth, NJ
Rep Power: 3180 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 7,265
Groans: 665
| Not Ranked : 0 score OTS is your problem. Plenty of e-tuners on here, pick one! |
| Not Ranked : 0 score Based on the temperatures in that log you my have really heatsoaked your IC and ran into lots of KR. Did you have a bag of ice on it on the dyno? If you get KR you can lose 35-40whp easily. Did you add E-85 as fuel or race fuel? Also on a flat stretch of road with proper airflow going to the car what does Vdyno say? The Stg2 S-OTS 93 maps will get you more power than 227whp. You should be around 275-285 whp and around 320 ft lbs if the car is not heatsoaked and everything is in order mechanically like shown in this dyno: http://www.mazdaspeedforum.org/forum/foru...0413-dyno.jpeg
| The Following 4 Users Say Thank You to Lex For This Useful Post: |
| Not Ranked : 0 score You should have been good for ~250HP/300WTQ based on your mods in 70F, no way 280 on an OTS tune. If I had to guess, your shit was probably heat soaked, ambient temps don't matter when the car is sitting idling for 10 minutes before the pulls. As soon as that intercooler heat soaks and your intake heat soaks there goes 20HP right there. It's good to manage heat soak with ice as those guys are setting the car up and strapping it down. I happen to know that the CPE heat soaks like a mother fucker. 230HP would be about right for a heat soaked car. Your LTFTs look off and you hit some KR at 4300 which should be addressed. Welcome to a turbo car in the summer. I would like to introduce you to my friend Methanol injection.
![]() Join Date: Jul 2011 Location: Danvers, MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 9,418
| Not Ranked : 0 score ^^Agreed The tq you were expecting is definitely plausible minimizing heat soak, but realistically speaking, even under perfect conditions, there's only a select few peeps that have gotten close to 300 whp without meth, e85 or any form of supplemental fueling and without being fully bolted. Definitely not saying that it's impossible, but it's extremely unlikely on an OTS map Time to get freek'd. dizzied or stratospheric my friend
__________________ 2006 Black Mica MS6 GT FreekBuilt Longblock, Manley 9.5:1, Manley H Beams, BW S300SX 6268 1.00 A/R, Dual Tial 38mm MVR EWG, Twinscroll Tubular Top Mount, EGR Delete, Labontes Stage 2 Meth Kit w/ D10, Grimmspeed 3 port EBCS, 3 Bar Map Sensor w/ Matt Jackson Harness, PERM 4" Intake, Cp-E HPFP, CX Racing FMIC, HKS SSQV V3, NGK IX 6510's, Toyota Injector Seals, PERM Catless 3" Turboback w/ dual Magnaflow Magnapaks, PERM Top Mount Valve Cover, PNP Intake Mani, BSD, ACT ZX4-HDG6, Bilstein HD Shocks, H & R Springs, Stoptech Slotted Rotors w/ API Ceramic Pads, JBR Heavy Shift Knob Stock motor w/ GT2871r: 380 awhp, 375 awtq @ 24 psi (e85 only) ![]() - 13.1 @ 110, 2.1 60 ft |
| The Following User Says Thank You to Fail_6 For This Useful Post: | rfinkle2 (07-23-2013) |
![]() Join Date: Nov 2012
Rep Power: 0 ![]() ![]() Thanks: 3
| Not Ranked : 0 score I dyno my car the same day with fully bolted running a 3 gallon mix of E85 and hit 282whp and 322trq.... that was a little surprising low numbers... Sent from my DROID BIONIC using Tapatalk 2 |
![]() Join Date: Aug 2012 Location: San Mateo, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,022
| Not Ranked : 0 score I'm getting 210whp/232 wtq on VD based on his logs from the day before... Seems extremely low even for an OTS map. Needs an etune.
__________________ CRMetallic 2019 Mercedes C43 AMG SOLD MNBlue 2012 S4 Prestige... a few mods SOLD IB 2015 3.8 Gencoupe Ultimate BLOWED UP DIB 2014 Mustang 5.0... a few mods SOLD - LS 2012 MS3 Cobb AP//SF//CAB Autotech HPFP Corksport TMIC//BPV//TIP//BTbs JBR 88a RMM Sure M3 TP OBX CBE Tanabe NF210's ADVAN RG-D 18x8 +38 Freektuned 50/50 E85 |
| The Following User Says Thank You to jseams For This Useful Post: | rfinkle2 (07-23-2013) |
![]() Join Date: Feb 2012 Location: Richmond, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,815
Groans: 255
| Not Ranked : 0 score OP, you should swing by the Target meet tomorrow night after 9:00 off the Balboa exit on the 118 and let me take a look at your setup. Was the race gas that you filled up with unleaded? If not, you might have just destroyed your cats. When was the last time you did a compression check? Sent via blown passenger side speakers.
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress |
| The Following User Says Thank You to himurax13 For This Useful Post: | rfinkle2 (07-17-2013) |
Here are a couple of 3rd gear logs I gathered tonight.
__________________ Cobb AP+ Stratified OTS--JBR Powerpath Stage III intake-- Turbosmart BPV--AutoTech Fuel Pump Internals--CPE TMIC-- OBX test pipe+ UR catback--ITV-22 plugs-- H&R springs--CPE RMM- JBR PMM and TMM-- | |
![]() Join Date: Apr 2010 Location: BC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,102
| Not Ranked : 0 score Dirty air filter? Sent from my HTC One S using Tapatalk 2
__________________ Whoever appeals to the law against his fellow man is either a fool or a coward. Whoever cannot take care of himself without that law is both. For a wounded man shall say to his assailant, "If I Die, You are forgiven. If I Live, I will kill you." Such is the Rule of Honor |
Groans: 224
| Not Ranked : 0 score Someone obviously stole your turbo.
| Not Ranked : 0 score The car is running 16 psi and extremely rich. I'm sure that is by design given it is an ots map, but you can't expect to be anywhere near 300 hp with 16 psi and low 11 afr targets. |
| The Following 3 Users Say Thank You to rfinkle2 For This Useful Post: |
| Not Ranked : 0 score The logs look ok - nothing bad there. Your car is flowing well and boost is staying low. Also you are going WOT at 2500 RPM. Go WOT at 3000 RPM and punch the throttle as it will give you a stronger boost response.
Groans: 255
| Not Ranked : 0 score OP, let me know if you want to swing by and do a compression check. I live near the Nordhoff exit of the 405. Have you done some logs with regular 91 octane and the 91 map?
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress Last edited by himurax13; 07-22-2013 at 11:07 PM. |
| The Following User Says Thank You to himurax13 For This Useful Post: | rfinkle2 (07-23-2013) |
![]() Join Date: Apr 2012 Location: Los Angeles
Rep Power: 426 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 956
| Not Ranked : 0 score "OTS" should get renamed "OTT" (Only Tll Tuned)
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: |
| The Following 4 Users Say Thank You to The Nut For This Useful Post: |
| Not Ranked : 0 score Stage 2 maps definitely delivered some butt dyno verifiable results, but getting @atvfreek; to uncork the inner beast is a completely different experience. We had some unseasonably cool temps here tonight, and my car was misbehaving *very* nicely. I didn't log, but I expect those numbers in my sig would've been appreciably higher/faster. I've only had summer temps to grab logs. As a side note - this also sorta verifies my thought process on the thermal mass issues with TMIC upgrades. Doesn't soak as fast, but once it's hot, it's going to stay hot. Choose your poison with TMICs.
| The Following 2 Users Say Thank You to JgamB For This Useful Post: | ms3blackmica (07-23-2013), rfinkle2 (07-23-2013) |
| Not Ranked : 0 score The car doesn't lose any power running these afrs.
![]() | | #19 | ![]() |
| Not Ranked : 0 score This particular car Lex, or the Mazdaspeed on pump gas in general? I have a lot of respect for your knowledge of ecu tuning, but am not sure that low 11 afr's are ideal for power, even on the ms3. As a matter of fact, I know you to be a heavy user and advocate of vdyno, and I have plenty of vdyno plots to prove otherwise. |
![]() | | #20 | ![]() |
![]() | | #21 | ![]() |
Groans: 255
__________________ "Stockish" Black Mica 2010 MS3 Genpu Pickles Tune in progress | |
![]() | | #22 | ![]() |
![]() | | #23 | ![]() |
Anyhow, I'm sure you know why it is the car is disappointing the OP and will explain it to him. | |
![]() | | #24 | ![]() |
![]() Join Date: Nov 2010 Location: Jacksonville, Florida
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,647
| Not Ranked : 0 score OP was your hood open or closed?
__________________ 2004 Dodge Dakota- SLT 4.7L V8- Burgundy 2013 Kawasaki Ninja 636 (Zx6r)- Green/ Black 2014 Honda Grom-Red 2014 Yamaha Grizzly 350- Blue 2007 Yamaha Raptor 700 GYTR- White- [SIGPIC][/SIGPIC] |
![]() | | #25 | ![]() |
| Not Ranked : 0 score I think I may be missing something here. The OP was hoping for closer to 300 hp. The OP is running an ots tune which on his car was producing ~ 16 psi with relatively rich afr's (imo). OTS tunes are not going to produce 300 hp, no matter if they are produced by Cobb, Stratified or any other tuner. |
| The Following User Says Thank You to rfinkle2 For This Useful Post: | faeker (07-23-2013) |
![]() | | #26 | ![]() |
Groans: 255
I am fairly certain that I am making close to 100 HP more than the OP with my "Stockish" setup but my tune is a bit more aggressive and I am running the corn.
![]() | | #27 | ![]() |
![]() Join Date: Feb 2012 Location: so cal
Rep Power: 1301 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 649
| Not Ranked : 0 score MR. OP! will an E-tune (e85) really get me to where i wanna be, which is ~300whp and ~350wqt (and ~80hp gain and ~90wtq) ? I dynod at 307//357 with less mods then you, on corn from @Lex; In california also. so YES. careful with that race gas shit, will eat up your sensors.. Also next time throw 1-1.5gal of E85 for you. Will help way more. I'm pretty sure the low numbers as said by a few people was due to HeatSoak, and KR
__________________ Sold: 2010 MS3 siLver. E85(25%) - Stratified DynoJet - 307//357 Suspension: H&R springs//Sensen Mazda5 struts; TB Performance TractionBar//Trunk Brace Brakes: CorkSport Pads; Centric Blanks Other: UltraGaugeEM; JBR 88D Rmm; JBR SSP//Bushings; EGR unplug;CF 3m vinal on trim in side car Official 60-100mph Times Official Video battles Official Youtube Channels
:-( 2014 - Dodge Dart.. (Blue Turtle) | |
| The Following User Says Thank You to ms3rick For This Useful Post: | SLOWHATCH (07-23-2013) |
![]() | | #28 | ![]() |
__________________ 2006 Mazdaspeed6 FreekTune | 91 | JBR 3", PMM & RMM | CS Racepipe, TMIC & TMM Inserts | Autotechs ![]() | |
| The Following User Says Thank You to sidekick For This Useful Post: | ms3rick (07-23-2013) |
![]() | | #29 | ![]() |
__________________ 2012 BLACK MICA w/TECH Go: Cobb- AP(v2)//AT- Internals//ETS- TMIC//CorkSport- True 3" Intake/Camber Plates/BPV/Boost Tubes/Recirc Tube//Denso- ITV22's//NATOR- TP//JBR- 80a Duro TMM & PMM/SSP/Counterweight/Anchors//CP-E- Stage II RMM//Tri-Point- RSB w/Monster Endlinks//GT-Spec- 4 Points Ladder Brace/Mid Chassis Brace/Front 4-Point Brace/Front & Rear Lower Tie Bar/Trunk Reinforcement Brace//Bosch- 3 Bar MAP Sensor//Technafit- SS Brake Lines//KW- v3 Coilovers//Swift- Springs (8K front/6K rear)//BC- Rear Spring Perches Shoes: MB- Battles (Matte Gunmetal) 18X8 +43 wrapped wit Michelin PSS's 245/35/ZR18 Rice: Tint//Blacked Out Badging//CorkSport - Hoodlifts/Engine Compartment LEDs//JBR- Special Edition Cylindrical Knob Stereo: Full Custom Mobile Audio/Video Entertainment System 91 & Corn diagnostics by: | |
| The Following User Says Thank You to The Nut For This Useful Post: | Elvisrosales88 (08-22-2013) |
![]() | | #30 | ![]() |
Groans: 111
| Not Ranked : 0 score As far as I know race gas + pump gas advance timing values = loss of power. The race gas will burn a lot slower than an equivalent (in octane rating) E mix. That's where the loss of power comes from IMHO.
![]() | | #31 | ![]() |
| Not Ranked : 0 score Where did you get that info? A faster burning fuel = less timing advance, a slower burning fuel = more timing advance to burn the same amount of fuel in the same period of time. A proper ignition timing curve for the given fuel should create similar power, if everything else remains equal. "Race gas" generally just means higher octane(100+), but AFAIK, that does not change flame speed, only resistance to detonation. Heat has a large affect on flame speed and E85 cools the combustion chamber quite a bit, which would lead me to believe it will burn at a slower rate and require more ignition advance.
![]() | | #32 | ![]() |
Groans: 111
With the right timing curve there's actually a power gain from burning the same amount of fuel. Same situation for E mixes, burning a certain amount of ethanol results in less caloric energy than burning the same amount of pump gas. But with proper timing it works better.
__________________ 2008 Cosmic Blue Mazda 3MPS Bilstein B12 + CS Camber plates + Eibach camber arms, SSR Type-F, Michelin PS4 225/40/R18, Cobb RMM, StopTech Street Pads + Stoptech Slotted disks, SouthBend Enduro Stage3 clutch, genpu TMM + CS Insert, TheSpeedLine 2X Rear Cross Floor and Rear Middle Lower Strut bars, Tanabe 4 Point Under Brace, Whiteline Bumpsteeer corection kit JBR Tru-3" + CS CAI Box, CP-e TMIC, Cobb XLE, NGK LTR7IX, UR v3 catted DP and res&catted TP, Cobb CatBack, GS EBCS, Autotech internals, GTX3071r gen2, CS 3.5BAR, Guardian Angel, CoolingMist WMI, VCTS Delete, stock ported IM, CorkSport cam shafts Mahle 88mm 4032 9.6:1 pistons, Manley rods, CA625+ head studs, King rod&main bearings, CS seals, DCR VVT, Koyorad radiator. StratiVersaTuned FTW to 28PSI, self-tuned to 32PSI 2008 Icy Blue Mazda CX7 6 Speed Manual SU TMIC, Autotech HPFP internals, Cobb XLE, Cobb EBCS, CorkSport 3.5BAR MAP GTX2867R gen2, stock spark plugs, stock cats and stock exhaust FTW, JBR Tru-3" Silicone intake TheSpeedLine Top and Lower Strut bars self-Versatuned to 22PSI | |
![]() | | #33 | ![]() |
(Thread Starter) | Not Ranked : 0 score @himurax13; I'm usually at that meet every Wednesday. I'll show up and take the tools. Sent from my SPH-L720 using Tapatalk 2
![]() | | #34 | ![]() |
![]() | | #35 | ![]() |
(Thread Starter) | Not Ranked : 0 score So last night I went to meet and with the help of @himurax13; i got a compression test. Everything seems to be in order (aside from some poorly gaped spark plugs which were corrected). I ran two 4th gear logs. I noticed that on the first log i have KR > 2.0 and really high BATS (~50* above ambient). Can someone check these logs for me? BTW Vdyno numbers are still very low. WTF?
![]() | | #36 | ![]() |
Groans: 255
Also, you need to add Injector Duty Cycle and Intake Valve Adv to your logging list. What did the VDyno read at?
![]() | | #37 | ![]() |
No I changed the map back to 91 Octane. I Vdynoed at 199hp/256lbs and 234hp/263lbs for data log 1 and 2 respectively. Sent from my SPH-L720 using Tapatalk 2
![]() | | #38 | ![]() |
| Not Ranked : 0 score I've never seen +10% LTFTs on one of @Lex;'s JBR specific maps, they are usually spot on - maybe it's something to do with your CAI getting turbulence? I'm grasping here, but I don't see too many people running them. That 2nd log doesn't really look all that bad for the apparently shitty fuel and the persistent KR in the meat of your torque production, but you're certainly not making good power. You might need meth to get this sorted.
![]() | | #39 | ![]() |
Groans: 255
![]() | | #40 | ![]() |
| Not Ranked : 0 score Lol - I meant with the Powerpath intakes / appropriate MAF housing diameter.
| MY RESULTS WITH DIZZY TUNNING-BY BUCKER- B4 AND AFTER "REAL" DYNO RESULTS | stc terminus | 2010 MS3 - ECU Computer Tuning | 2 | 07-30-2012 10:43 PM |
| 08.5 MS3 dyno results | Base14 | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 20 | 02-09-2011 02:24 PM |
| Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? | desperado callado | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 10 | 05-18-2009 11:27 AM |
| My Dyno Results | aaronc7 | MazdaSpeed 3/6 - Troubleshoot/Diagnostics | 34 | 06-09-2008 09:44 AM |
