Like Tree9Likes
 Old 01-24-2014, 08:24 PM   #1
Agent_Orange's Avatar
Posts: 3,575   (View Stats)
Groans: 665
Default Getting some corn in the diet
I finally have some time to devote to getting a proper E85 tune going. So after absorbing some words of wisdom from @ms3blackmica; I made the appropriate changes to my 93 map, and filled up with a 25% mix. Below are the initial results. I realize it's somewhat of an apples to oranges comparison between these logs, being there is a ~50 degree difference in ambient temps, but I just wanted to see where I'm at before I start ramping up boost and timing. The only other changes were the addition of a 3-port EBCS, and boost levels dialed back slightly.
Any input/feedback is welcomed.
Once again, a big thank you to Nishan for setting me up with my initial tune, and for the knowledge he continues to impart upon myself and our community.
rfinkle2 and MZRSPEED like this.
The Following 4 Users Say Thank You to Agent_Orange For This Useful Post:
Easter Bunny (04-21-2014), Koke382 (01-26-2014), ms3blackmica (01-26-2014), WetzMS3 (04-21-2014)
 Old 01-24-2014, 08:55 PM   #2
sidekick's Avatar
Posts: 3,093   (View Stats)
Bump in the road? That's a really odd looking torque curve.
Agent_Orange (01-24-2014), Pu Manchu (01-24-2014)
 Old 01-24-2014, 08:58 PM   #3
MSF's Punishing Member
Pu Manchu's Avatar
Posts: 2,992   (View Stats)
Groans: 546
definitely want to find a consistent spot to datalog, preferably both ways on the same stretch.
The Following 3 Users Say Thank You to Pu Manchu For This Useful Post:
Agent_Orange (01-24-2014), chaser27 (04-03-2014), rfinkle2 (01-25-2014)
 Old 01-24-2014, 09:01 PM   #4
Groans: 665
Most likely wheelspin. Roads here are still somewhat icy/snowy, but even on dry sections, she is eager to break traction. Shitty all-seasons don't help either. Going to try and get better logs as conditions improve.
I log the same stretch every time.
Last edited by Agent_Orange; 01-24-2014 at 09:01 PM. Reason: MSF Database - Automerged Doublepost
Pu Manchu (01-24-2014), sidekick (01-24-2014)
 Old 01-24-2014, 09:16 PM   #5
sidekick's Avatar
Cheater.
 Old 01-24-2014, 11:21 PM   #6
Groans: 665
Got one with no wheel spin. Slightly more realistic numbers.
Now to find MBT!
I'll add more as the iterations come.
 Old 01-25-2014, 06:53 AM   #7
06yellowroush's Avatar
Posts: 108   (View Stats)
06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold06yellowroush is a splendid one to behold
Considering doing the same once I install my internals. Wondering what kind of horsepower increase you can get from just putting some e85 in.
06yellowroush is offline   Reply With Quote
 Old 01-25-2014, 07:04 AM   #8
manila's Avatar
Posts: 1,767   (View Stats)
E85 is proven to have huge gains over a 93 map. It is also a good knock protectant.
Some guys that are running the K04 and bolt-ons are in the 320 range.
'12 MS3 Black Mica w/ Tech
 Old 01-25-2014, 07:56 AM   #9
WAMBUSHHHH!'s Avatar
Posts: 1,599   (View Stats)
if you search in this section or the ECU tuning section, there are some logs/dynos of the 2013's being tuned with some corn, intake and internals that are getting close or right on the dot for 300HP...throw a DP/TP and you're probably over 300HP at that point..
 Old 01-25-2014, 12:46 PM   #10
Groans: 665
As you can see from the second graph I posted, just dumping in some Eth will give you great protection against knock, but it won't yield instant power results, or anything significant at least.
Power gains will come from tuning, I.E ramping up boost and timing. I have a 2nd revision ready to flash and log, but unfortunately it's snowing right now, so WOT logging is out. As soon as the roads are dry, I'll post another graph from the new iteration and hopefully it will demonstrate some gains.
 Old 01-26-2014, 10:13 AM   #11
Yeah I know haven't driven my speed either this snow in NJ sucks an they cant clean the streets for shit either!
 Old 01-26-2014, 10:20 AM   #12
Nishan
ms3blackmica's Avatar
Posts: 5,635   (View Stats)
Good stuff man.
Turn the boost up and have some fun
www.tunedbynishan.com
Agent_Orange (01-26-2014)
 Old 01-26-2014, 07:05 PM   #13
Groans: 665
Added some boost and bumped timing a bit.
The Following 8 Users Say Thank You to Agent_Orange For This Useful Post:
chaser27 (04-03-2014), Hush (01-26-2014), lilred (01-26-2014), ms3blackmica (02-01-2014), rfinkle2 (04-22-2014), sidekick (02-01-2014), WAMBUSHHHH! (01-26-2014), WetzMS3 (04-21-2014)
 Old 01-26-2014, 07:15 PM   #14
lilred's Avatar
Posts: 5,792   (View Stats)
Nice gains man!
tapafuck
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 02-01-2014, 01:57 AM   #15
Nishan
Now we're talking!
Agent_Orange (02-01-2014), chaser27 (04-03-2014), sidekick (02-01-2014)
 Old 02-02-2014, 12:43 AM   #16
Nishan
Feel free to email me some logs Matt.
I don't mind taking a look if you would like me to.
Agent_Orange (02-02-2014), PUGENE (10-21-2014), rfinkle2 (04-22-2014)
 Old 02-02-2014, 01:31 AM   #17
Groans: 665
Will do.
Thanks!
 Old 02-10-2014, 07:03 PM   #18
Blkpearl's Avatar
Posts: 353   (View Stats)
Blkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond reputeBlkpearl has a reputation beyond repute
Groaned at 19 Times in 9 Posts
so need to throw in some corn with the 93. whats your ratio of mix?
Blkpearl is offline   Reply With Quote
 Old 02-10-2014, 07:18 PM   #19
Groans: 665
Read the OP.
 Old 02-10-2014, 07:26 PM   #20
JgamB's Avatar
Posts: 2,566   (View Stats)
Read the OP.
Got a recent log? Curious to see how far you've progressed with the tuning.
 Old 02-10-2014, 09:14 PM   #21
Groans: 665
I don't.
Snow sucks.
Hope to have a couple revisions soon.
JgamB (02-13-2014)
 Old 02-11-2014, 03:48 AM   #22
Blkpearl's Avatar
Whoops. Missed that. Thanks
 Old 02-11-2014, 07:02 AM   #23
I don't.
Snow sucks.
ain't gonna get any better either man...we're about to get another 6-8 inches. FUCK OFF WINTER, MSF HAS TUNES TO FINISH UP!
The Following User Says Thank You to WAMBUSHHHH! For This Useful Post:
Agent_Orange (02-11-2014)
 Old 02-13-2014, 03:25 PM   #24
ChaunceyM's Avatar
Posts: 948   (View Stats)
ChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the worldChaunceyM is the leader of the world
6-8? I wish we only got 6-8". We had about 9" over-night (measured by dog) and 12" by the time it all stopped. Hopefully this rain takes the sting out before it starts up again tonight.
On the plus side, the MS3 with a set of Blizzaks makes short work out of wet snow. Can't have any high-speed fun, but it's easy to get up to e-brake turn speeds. Or drive up a 12% grade.
Corksport: SRI & TIP, Strut Tower Brace, Coilovers
CP-e: RMM
JBR: Rear Sway Bar (with Moog End Links)
TWM: Full Replacement Shifter
Cobb: AP
AutoTech: HPFP Internals
Ebay: Test Pipe
ChaunceyM is offline   Reply With Quote
 Old 02-13-2014, 07:11 PM   #25
lilred's Avatar
Ha and here I am thinking about fmic to fight days like today at 85+
tapafuck
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
Agent_Orange (02-14-2014), chaser27 (04-03-2014)
 Old 02-14-2014, 12:15 AM   #26
JgamB's Avatar
tapafuck
You can expand your JBR collection in a few months when he releases the FMIC piping kit, just score yourself a TR6 or TR8 core.
 Old 02-14-2014, 12:28 AM   #27
Nishan
tapafuck
Jose we are taking logs out here in 12* weather running out of fuel at 18 PSI on BT's LOL
Agent_Orange (02-14-2014), lilred (02-14-2014), rfinkle2 (04-22-2014)
 Old 04-02-2014, 11:25 PM   #28
Groans: 665
I managed to do a few quick revisions tonight and netted some gains. I think it's fairly close to the knock limit on this setup as instances of KR ~2 start to appear up top (hence the afr dip).
The next move is getting a 3" intake and increasing the mix to 30%.
@JgamB; @ms3blackmica;
JgamB (04-03-2014), rfinkle2 (04-22-2014)
 Old 04-02-2014, 11:40 PM   #29
Groans: 665
Forgot the log.
 Old 04-03-2014, 07:42 AM   #30
JgamB's Avatar
It's unusual for me to see KR at 5K rpm, it's usually at spool and at or above 6K, but I squeeze an extra half gallon of Eth in during the winter months because of winter blended E70. You aren't just getting less alcohol, you're getting more 87 octane filler trash. My AFRs are slightly richer so I don't worry too much about being off my mix by a little bit.
You should roost around in 3rd gear and monitor KR to see if you're getting any more blips like that or if it was just an anomaly. It looks like a bump / rattle to me - usually I get another tidbit of knock as I'm winding it out if it's not enough corn, and your log cleaned up completely.
Agent_Orange (04-03-2014)
 Old 04-03-2014, 09:43 AM   #31
Groans: 665
It's unusual for me as well. I normally see the 0.35 - 0.7 counts if anything. That's why I'm thinking it's legit knock.
I richened the AFR up top a bit and pulled .5* to see if that quells it when I grab more logs later.
Also I just realized that's the wrong log (it was late).
This is the log associated with that last graph.
Thanks for the input man.
JgamB (04-03-2014)
 Old 04-03-2014, 10:02 AM   #32
JgamB's Avatar
That looks a lot more like insufficient octane. A bit surprising you're not getting more timing out of it, but fuel varies so much it's hard to really say what "25%" blends will yield.
Your K04 is holding boost *really* well at high RPM, so I'd definitely be tapering in more fuel to keep the cylinder temps in check - it's probably contributing to your knock.
 Old 04-16-2014, 11:21 PM   #33
Nishan
It's getting warm again Matt!
 Old 04-20-2014, 09:16 AM   #34
Groans: 665
I know! Old man winter can go fuck himself! Time for unhindered street tuning and bitches in short skirts!
Just installed the 3" intake and I'm currently dialing the MAF in.
Initial results look good, and I got rid of a huge bottleneck. I was only able to flow around 290 g/s before, now I can see upwards of 330. Calculated load took a big jump also, it peaks at around 2.7 now!
Moar graphs soon!
 Old 04-21-2014, 04:51 PM   #35
Moar graphs soon!
great, now I want a 3in intake. stop posting, ya dick.
Agent_Orange (04-21-2014)
 Old 04-21-2014, 06:21 PM   #36
Moar graphs soon!
Question, without a lot of research before asking, how much of that flow gain was from the PNP IM vs the DP?
I'm running a 3.5" HTP with a cp-e tmic and test pipe, and that only nets me 290 g/s. After talking with @rfinkle2 I was planning on CBE/DP next to gain more flow. But those Relentless powder coated manifolds do look sexy. Any idea how much of an increase in flow you saw just from the pnp im?
Going to search for other results now.
Agent_Orange (04-21-2014), rfinkle2 (04-22-2014)
 Old 04-21-2014, 06:32 PM   #37
Groans: 665
I would post some comparative logs for you but my old laptop's HD is fried. From what I can recall the PNP did net some modest gains in flow, between 5-10 g/s, and this is most likely because the VTCS flappers were deleted. Remember, the purpose of a PNP on this IM is to BALANCE flow rates across the runners, not necessarily increase it.
If your having trouble breaking 300 g/s with a 3.5" intake, I would definitely look to your exhaust setup as the bottleneck.
Catless ftw!
rfinkle2 and WetzMS3 like this.
The Following 3 Users Say Thank You to Agent_Orange For This Useful Post:
rfinkle2 (04-22-2014), WAMBUSHHHH! (04-21-2014), WetzMS3 (04-21-2014)
 Old 04-22-2014, 03:05 PM   #38
sho
sho's Avatar
Posts: 537   (View Stats)
sho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the worldsho is the leader of the world
Catless ftw!
I'll agree with this. I'm seeing 314g/s consistently from 4600rpm up with 3.5" intake, upgraded tmic and DP and 3" cb-e
2007 ms3 GT, sunlight silver
Manley platinum series 88mm pistons, Manley h beam rods, L19 head studs, custom cometic mlx head gasket, massive speed balance shaft delete, massive speed oil pan baffle, OEM Rod and Main bearings, vband pte 5862 .82AR journal bearing turbo, Cp-e exhaust manifold, custom 3" vband downpipe, 3" cnt Catback, pw46 ewg, tr1235 fmic, tial Q BOV on hotside pipe, 3" cold side piping, JMF V2 w/ PI, CS big TB, PERM pcv plate with jbr sealed can and ebay VTA can, custom VC vent with VTA can, SP63 gen 1 vc breather cap, Cp-e injector seals, mazdaspeed accessory coilovers, Hotchkis 32mm fsb and rsb, Damond Motorsports RMM, TMM & PMM.
FD wheels
E48 mix
Tuned by Realgib3
Purchased 8/3/12 - 25,314 miles on chassis and motor
6/21/18- 234,700 miles on chassis, 73,200 on built motor
sho is offline   Reply With Quote
The Following User Says Thank You to sho For This Useful Post:
WetzMS3 (04-22-2014)
 Old 04-22-2014, 03:24 PM   #39
chaser27's Avatar
Posts: 1,276   (View Stats)
Groans: 42
IMO g/s comparison between cars or even different MAF cals is pointless. I can change my MAF curve 15% up top, show 15% more g/s adn my AFR's etc. will all be spot on (assuming I don't go over 2.5 load)
It is moreso dependent on your calibration than anything. There is a hidden "OL" fuel trim taking place in the background.
Coming at ya with all 297/359
ECU: self-tuned
RADAR: Passport Escort 9500ci
The Following 2 Users Say Thank You to chaser27 For This Useful Post:
sho (04-23-2014), WetzMS3 (04-22-2014)
 Old 05-28-2014, 04:39 PM   #40
Nishan
Where you at son?
Making any solid power?
Agent_Orange (05-28-2014)
Im ready for some corn... DSIT995 MazdaSpeed 3/6 - E85 Fueling 14 08-15-2013 01:20 PM
Took a sip of the corn !! jracer MazdaSpeed 3/6 - E85 Fueling 44 01-15-2013 06:49 AM
Snaild on corn snailD 2010 MS3 - Dyno Sheets/Discussions 13 11-23-2012 10:58 PM
Another Corn Fed PU trf5000 2010 MS3 - ECU Computer Tuning 73 08-12-2012 09:07 AM
2 gal's of corn + chinacharger dooderek MazdaSpeed 3/6 - ECU Computer Tuning 15 01-10-2012 01:52 AM
Page generated in 0.59569 seconds with 34 queries
