![]() Join Date: Apr 2011 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
(Thread Starter) | Not Ranked : 0 score I posted my vdyno numbers from my GTX3067r a while back, but here's an actual dyno I did this weekend. A few changes were made to my self tune, and I've kept torque lower to hopefully give the engine more longevity. This run was actually my second run, so I probably had some heat soak since my meth isn't working at the moment. The tires spun on the rollers during the first run. Here's a link to the video. https://www.facebook.com/sean.diasda...2/?pnref=story
__________________ Engine | GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe | | ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX | | Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth | Handling | Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob | | JBR Rear Sway Bar | Cobb Springs | |
| The Following 6 Users Say Thank You to CHUNKYBOWSER For This Useful Post: | 09TrueRedGTX (06-30-2015), Code Monkey (06-30-2015), Jeremy M (06-30-2015), MSpeedDemon3 (06-30-2015), NCspecV81 (06-30-2015), Tifosi42 (09-09-2016) |
![]() Join Date: Aug 2014
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 251
| Not Ranked : 0 score Nice numbers and a flat torque curve. Great work! |
![]() Join Date: Jan 2014
Rep Power: 0 ![]() Thanks: 2
| Not Ranked : 0 score Good stuff. I think i've seen your car around. Looks clean. And now fast! |
| stock dyno & Cobb v-dyno numbers | garf | 2010 MS3 - Dyno Sheets/Discussions | 45 | 04-08-2016 11:51 AM |
| BNR S3 DYNO NUMBERS??? | Speed3KG | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 142 | 01-13-2016 01:34 PM |
| Dyno numbers seem low. | nzjase | 2010 MS3 - Dyno Sheets/Discussions | 15 | 07-15-2013 11:16 AM |
| Stock dyno numbers | Ace99899 | Gen2 MS3 General Discussion | 9 | 10-19-2011 05:36 AM |
| Results on an AWD dyno vs. a 2WD dyno: closer to actual power on the road? | desperado callado | MazdaSpeed 3/6 - Dyno Sheets/Discussions | 10 | 05-18-2009 11:27 AM |
