![]() Join Date: Apr 2011 Location: Tampa, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 88
__________________ Engine | GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe | | ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX | | Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth | Handling | Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob | | JBR Rear Sway Bar | Cobb Springs | |
| The Following 13 Users Say Thank You to CHUNKYBOWSER For This Useful Post: | AlexInNS (12-09-2014), Cevaes_64 (03-10-2015), Cheapspeed (11-19-2014), Code Monkey (11-19-2014), Darth_Nuruodo (11-19-2014), Mauro_Penguin (11-26-2014), mize13 (11-26-2014), stanley0910 (11-26-2014), therapist510 (11-26-2014), Tifosi42 (09-09-2016), twenty5psi (11-26-2014), Voltwings (11-26-2014), Ziggo (11-19-2014) |
![]() Join Date: Dec 2012 Location: Richmond, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 5
Groaned at 31 Times in 14 Posts
| Not Ranked : 0 score Wow, delivery looks super smoooooooth
__________________ ΜΟΛΩΝ ΛΑΒΕ 2014 Honda Grom 125cc's of FURY! now more furious w/ 181cc's 2015 F150 Platinum 2012 MS3 Liquid Silver Autotech HPFP Cobb AP & CBE Corksport FTB Enkei Raijin 18x8 et45 JBR 3.0WP, RSB, RMM & SSP II Stratified Tune TrackMasters hood prop and ecu reloc. TurboSmart BOV |
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Was the Log done on a slightly up hill near the end. Curious of where your boost ramps up around 5800rpm the HP starts to drop off instead of holding or increasing the HP..Looks like a nice curve though.
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
![]() Join Date: Jun 2012 Location: Jacksonville, FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 24,365
Groans: 171
| Not Ranked : 0 score Was this on the stock mazda flange and ATP hot side?
__________________ -Fearless vampire killers, banned in DC, how low can a punk get? -Delray/Grieco Mazda or Direct Auto Body, ask me why you should NOT take your car to either. ![]() -It is more fun to drive a slow car fast, than it is to drive a fast car slow |
![]() Join Date: Mar 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 683
| Not Ranked : 0 score Mine does the same thing, power drops off even though boost is ramping up. Seems like stock block flow restriction somewhere.
__________________ Was: 2012 with GTX3071 and BF Goodrich g-Force Rivals Now: 2015 Mustang GT 5.0, soon to be track toy |
| The Following User Says Thank You to Plimmer For This Useful Post: | CHUNKYBOWSER (11-26-2014) |
![]() Join Date: Dec 2012 Location: Venice,FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 438
| Not Ranked : 0 score @Mauro_Penguin This car has stock unported IM and stock exhaust manifold as well, standard ATP setup. This is an impressive turbo, the 67R GTX wheel really needs the GT30 turbine to breathe.
__________________ 2013 MS3 VRM w/Tech -unSure Track RMM//Cobb AP//AT HPFP Internals//HTP 3" Intake//UR Resonated TP//UR CBE//JBR Weighted Shift Knob//JBR Shifter Cage Bushings FlowTuned 2 Gallon E85 blend 307whp/336wtq |
| The Following 2 Users Say Thank You to twenty5psi For This Useful Post: | CHUNKYBOWSER (11-26-2014), Mauro_Penguin (11-26-2014) |
| Not Ranked : 0 score Looks excellent, i'd be real happy with that power band.
__________________ Past: - 2010 Speed3 W/ GTx3576 ~500 whp - -Sold- -Mustang 5.0 450 whp / 352 wtq -Sold- Current: 2012 Loaded Speed3 - Stock 2001 Miata - Basically stock ... Something, somewhere, went horribly wrong. Fastest gtx3576 powered, 6th port injected, 25% e85 fueled, stock suspension, silver mazdaspeed 3 in South Houston. Because its my internet record, and I said so. |
| The Following 2 Users Say Thank You to Voltwings For This Useful Post: | CHUNKYBOWSER (11-26-2014), Mauro_Penguin (11-27-2014) |
![]() Join Date: Aug 2010 Location: Salina, KS
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 454
| Not Ranked : 0 score That's smooth torque. I see you self tuned, how much time did you spend on it/do you have much more room for tuning?
__________________ Need more parts. |
| The Following 2 Users Say Thank You to stanley0910 For This Useful Post: | CHUNKYBOWSER (11-26-2014), Mauro_Penguin (11-27-2014) |
I would also like to note that I'm basically on the stock catback, minus muffler. 2.5" piping or whatever stock is. I'm actually going to be putting the stock muffler back on.
__________________ Engine | GTX3067R | Cobb AP | Autotech Internals | HTP 3.5" Intake | M2 Long Downpipe | | ATP FMIC | Forge V1 | Grimmspeed EBCS | 3 BAR MAP | NGK Iridium IX | | Damond EGR Delete | JBR OCC | E33 Self Tune | DO7 Meth | Handling | Damond RMM | Damond PMM | JBR 88a TMM | JBR Shift Weight & Knob | | JBR Rear Sway Bar | Cobb Springs | | |
| The Following 2 Users Say Thank You to CHUNKYBOWSER For This Useful Post: | Mauro_Penguin (11-27-2014), stanley0910 (11-26-2014) |
| Not Ranked : 0 score [QUOTE=CHUNKYBOWSER;2760652]I took some time with tuning... Maybe about a month to the final map. I went through about 15 revisions on the 93 tune and about 6 on the E85 map. [QUOTE] Did you back off the boost and raise timing then add boost back with the E85 tune or did you leave the boost the same as the 93 map and then add timing?
__________________ Need more parts. Last edited by stanley0910; 11-26-2014 at 09:33 AM. Reason: Messed up the quote |
| The Following User Says Thank You to stanley0910 For This Useful Post: | Mauro_Penguin (11-27-2014) |
| Not Ranked : 0 score You can PM me if you want to discuss this in more detail, but whats your timing up top? These little turbos will take a good deal of timing without acting up, so you could effectively lower your boost a tad (to free up some fuel head room) and make up the difference with timing. Though there is always a balance, might require some playing around with it. I had a guy whose IWG 3071 was creeping to 28 psi, and would max out the fuel system even on 93 ... had to get real creative with his tune a few times to keep everything happy lol. I dont mean to come in and try to take anything from what you've done here though, like i said before, i'd be very happy with that powerband.
| The Following 3 Users Say Thank You to Voltwings For This Useful Post: |
(Thread Starter) | Not Ranked : 0 score [quote=stanley0910;2760667][QUOTE=CHUNKYBOWSER;2760652]I took some time with tuning... Maybe about a month to the final map. I went through about 15 revisions on the 93 tune and about 6 on the E85 map.
| The Road to an EFR 9180 Build | NCspecV81 | 2010 MS3 - Big Turbo Builds | 1465 | 06-02-2018 12:06 PM |
| Zachy Poo's GTX3067R Build | Zpuhalla | 2010 MS3 - Big Turbo Builds | 217 | 12-11-2014 01:08 PM |
| GTX3067R | NCspecV81 | EdgeAutosport.com | 9 | 03-03-2014 05:37 PM |
