 Old 03-25-2015, 02:31 AM   #1
someguyondrugs's Avatar
Posts: 81   (View Stats)
someguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud ofsomeguyondrugs has much to be proud of
Default k04 e42.5 selftune
stock k04 e42.5 peak boost was supposed to be 21psi 4k-5k but only made ~19
mods in sig...this is my first go at a corn tune.
2012 CWP
AP V2, AT internals, COBB sf intake, NoName Ebay TIP, M2 long catless DP, JBR RMM, JBR SSP, Hankook v12s, E 48 selftune @ 326whp 380wtq
someguyondrugs is offline   Reply With Quote
 Old 03-25-2015, 03:10 AM   #2
Mastertrixter's Avatar
Posts: 386   (View Stats)
Mastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the worldMastertrixter is the leader of the world
try turning up the boost. you have the flow mods to support 20-21 psi easily. everything else looks pretty good
2011 speed 3
BNR s3 v2
snow performance wmi
dammon occ, egr deletes
htp 3"
cx piping with tr6 core
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
jbp ssp, weight, bushings, rmm, and rsb
koni oranges with road magnet springs
motegi mr116 18x8 +45
Powered by PURPLE DRANK
350/360 vdyno cf 1.01 on 91 pump only
Mastertrixter is offline   Reply With Quote
The Following User Says Thank You to Mastertrixter For This Useful Post:
someguyondrugs (03-25-2015)
 Old 03-25-2015, 03:17 AM   #3
btstarcher's Avatar
Posts: 4,852   (View Stats)
Why does calculated load never get above 2?
SnailTune in progress
The Following User Says NO Thank You to btstarcher For This Un-useful Post:
Sergey (04-14-2015)
 Old 03-25-2015, 03:22 AM   #4
good call, didn't even see that......
2011 speed 3
BNR s3 v2
htp 3"
ebay dp
corksport catback
autotech internals
grimmspeed 3port
turbosmart bpv
3bar
 Old 03-25-2015, 03:34 AM   #5
btstarcher's Avatar
If your targeting that small of a load, you won't achieve your boost targets. Once the load target is achieved, no more boost is required. At least that's the way I understand it.
 Old 03-25-2015, 04:54 AM   #6
Mike@Stratified's Avatar
Posts: 1,119   (View Stats)
Altitude probably coming into play here somewhat.
The Following User Says Thank You to Mike@Stratified For This Useful Post:
btstarcher (03-25-2015)
 Old 03-25-2015, 05:28 AM   #7
blue speed's Avatar
Posts: 237   (View Stats)
blue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond reputeblue speed has a reputation beyond repute
Groaned at 4 Times in 1 Post
Just checking, Your signiture does not mention a TIP just the Cobb sf. Do you have both?
Cobb shifter weight, CBE, RSB, knob Corksport BPV, boost tubes, SRI, TIP ,Ex hangers,80 Duro RMM & TMM insert CP-E TMIC, UR test pipe & catted DP, Hypertech, Autotechs. JBR Coolant bypass, intake gasket, air filter & BP hose.Konig wheels. Sure, FSB bushings.
blue speed is offline   Reply With Quote
 Old 03-25-2015, 07:09 PM   #8
Boost toon, usually have no problems reaching load over 2 or 19+psi. This is the first run I've had on the dyno since I've started tuning the car, second time ever. Dyno log shows the pull was only 3.7 seconds vrs my wot logs on the mexican streets which are closer to 11 seconds. My original toon called for 19psi peak boost, I'm now calling for 21psi 4k-5k...just haven't had enough time to tune for it before the dyno day.
here is a recent street log on this same revision before I was on the dyno.
and uh...video for attention
2012 CWP
 Old 03-25-2015, 07:14 PM   #9
oh, and yes...I have a no name EBAY inlet hose. Think its a CORP or some such nonsense
Mazda MAZDASPEED3 MAZDASPEED6 Silicone Inlet Turbo Intake Hose Black | eBay
2012 CWP
 Old 03-25-2015, 07:15 PM   #10
sheston's Avatar
Posts: 1,847   (View Stats)
You need something to cool your BATs.
I went with Meth and a bigger TMIC. I'll bet the high BATs are taking a lot of your power
Have you looked at how your VD changes with timing? You seem to hit high advance very fast....
 Old 03-25-2015, 07:43 PM   #11
Timing was increased slowly over 10 or 12 revisions, with positive increases in tq and hp.
Meth is going to be a necessity this summer living in AZ, but I have a few weeks of good weather yet.
Some of the guys at ES tuning recommended an EBCS...cobb specifically, saying I would make bigger horsepower...and if I actually hit 21psi I would. Going to continue tuning and hit that 21psi.
edit: alt was 2600ft in Tucson, I live and tuned the car in Phoenix @ 1100ft
2012 CWP
Feedback On Selftune Liltoaster540 MazdaSpeed 3/6 - ECU Computer Tuning 52 03-19-2013 07:15 PM
need some help with a selftune Uberfly MazdaSpeed 3/6 - ECU Computer Tuning 7 08-19-2012 08:14 AM
Virtual dyno of selftune BT2010speed 2010 MS3 - Dyno Sheets/Discussions 0 06-04-2012 08:19 PM
Page generated in 0.31453 seconds with 26 queries
