 Old 06-08-2016, 06:46 AM   #1
TORQUERULES's Avatar
Posts: 283   (View Stats)
Default My first VDyno runs with a Stratified Stg 3 tune (93 octane)
It was done yesterday and the car was minor heat soaked on the first run and I tuned right around and ran the second run (so more heat). It was 75 degrees outside and a little humid. My modifications are in my signature. I live in WV so the roads are NEVER smooth...
2017 Mazda CX-3 Meteor Gray
 Old 06-08-2016, 07:14 AM   #2
jtday's Avatar
Posts: 650   (View Stats)
Correction factor needs to be 1.01 and I suggest smoothing 3.
2009 MS3 GT
The Following User Says Thank You to jtday For This Useful Post:
TORQUERULES (06-08-2016)
 Old 06-08-2016, 07:18 AM   #3
How about this? Smoothing at 3 and correction custom at 1.01.
File Type: jpg Dyno with custom 1.01 correction and smoothing at 3.jpg (78.3 KB, 72 views)
 Old 06-08-2016, 07:20 AM   #4
This one is set correction at 1.01 and smoothing back to 1.
File Type: jpg Dyno with custom 1.01 correction and smoothing at 1.jpg (72.2 KB, 50 views)
 Old 06-08-2016, 07:35 AM   #5
I don't think it looks too out of line with my mods though. I hope not. It feels very strong. Traction is an issue...
I just used the weight they had in the 2013 Mazdaspeed profile and of course added my weight. I also changed the tire diameter to the correct one.
 Old 06-08-2016, 02:44 PM   #6
jtday's Avatar
That looks really solid man. I'm on an older version of their e85 tune and you're making as much as I am.
2009 MS3 GT
 Old 06-08-2016, 03:16 PM   #7
Thanks. I am surprised with how strong she runs. They just sent me back a revised tune with some APP adjustments I wanted and to tweak stuff from my log review.
Sent from my ONE A2005 using Tapatalk
 Old 06-09-2016, 07:48 AM   #8
Mmahan3510's Avatar
Posts: 93   (View Stats)
Mmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of lightMmahan3510 is a glorious beacon of light
Groaned at 19 Times in 6 Posts
you can see my mods, and i just did a datalog and entered it into vdyno, with correct BATs and im right at 315/362, fully bolted and E30 tune. you numbers are strong for 93. looks great!
2012 Mica Black Speed3, 3" CS intake/TIP, CS MZR bypass valve, CS hpfp internals, CS 3 port EBCS full interupt, NGK 1 step colder plugs, Ebay catless DP, 2nd cat delete, resonator delete, Custom Magnaflow axle back, CS OCC, EGR delete, throttle body coolant bypass, CS 70 duro RMM, firehawk indy 500 225/40/18, DM SSP, rear adj control arms, 3.5" shift extender, MofiyStreet 450oz ball shift knob, Purple Drank Tuned 93 map/Purple Drank Tuned E30 map, 295/337 dyno jet heatsoaked at 150 BAT, 314/362 vdyno at 100 BAT
Mmahan3510 is offline   Reply With Quote
The Following User Says Thank You to Mmahan3510 For This Useful Post:
TORQUERULES (06-09-2016)
 Old 06-09-2016, 07:50 AM   #9
Mmahan3510's Avatar
heres the vdyno
 Old 06-09-2016, 08:43 AM   #10
Thumbs up
Originally Posted by Mmahan3510 View Post
heres the vdyno
Wow, thanks. I am actually on the light side on weight in my VDyno profile I am sure, but i went with the numbers they have for the MS3 and my actual weight of 200lbs. I am sure my car weighs a little more (maybe only 25-30lbs though) than a stock MS3 and if I played with that (if I actually weighed my car) the numbers would go up by a couple of hp, Lol. I am not concerned with that though because just like an actual dyno the numbers will vary day to day conditions to conditions. I also don't want to post anything different (car profile-wise) than what anyone else on here is doing so I can make a good comparison. It is a great tuning tool though.
The car is really strong and surprised me. I got the APP files revised and loaded the new 93 tune last night. Feels perfect. I can't wait to try E85.
 Old 06-09-2016, 08:50 AM   #11
On a side note, Stratified did not indicate anything unusual on my log review so that made me feel good.
 Old 06-09-2016, 08:51 AM   #12
Mmahan3510's Avatar
e85 makes a huge difference! i was only 93 tuned for about 3 weeks before i went e85. only things i still would like to do are JBR RSB and CS TMIC
 Old 06-09-2016, 08:53 AM   #13
Thumbs up
The CS TMIC really helped me I believe. It works like a charm.
Also, ever thought of the Progress rear bar? I went from the JBR, which I could never get the noise out of, to the Progress and it works amazingly.
 Old 06-09-2016, 09:18 AM   #14
Police - Grammarhead
Vansquish's Avatar
heres the vdyno
You need to go into your log and change the throttle position to 75% throughout the pull. Right now, VDyno is doing weird stuff to your logs because it is improperly interpreting the data.
jtday (06-10-2016)
 Old 06-09-2016, 09:18 AM   #15
Mmahan3510's Avatar
I like progress parts, I'm just afraid it will be way too stiff for DD. How do you think it feels? Are you gen Juan or gen pu?
Sent from my VIVO XL using Tapatalk
 Old 06-09-2016, 09:21 AM   #16
Thumbs up
Gen 2. It is not too stiff at all. I think it balanced the car out perfectly. It is neutral with no understeer and you can induce oversteer if you want, but if you choose not to it stays nice and flat/neutral. It is how the car should have came from the factory.
 Old 06-09-2016, 09:36 AM   #17
Mmahan3510's Avatar
thanks for the input!
 Old 06-09-2016, 11:03 AM   #18
No problem!
How To: Stratified Tune Lex Stratified Automotive Controls 1 07-24-2014 12:22 PM
Stratified Tune? ape_ck Stratified Automotive Controls 7 08-04-2013 08:21 AM
Local Tune 91 octane VD jakdan714 2010 MS3 - Dyno Sheets/Discussions 5 07-30-2013 10:39 PM
Stratified (Lex) Tune! (330/393 VD) psychophyr Stratified Automotive Controls 11 02-23-2012 04:39 PM
93 octane tune using 92 oct/e-85 mix? thehead MazdaSpeed 3/6 - ECU Computer Tuning 26 06-29-2011 11:24 PM
Page generated in 0.35756 seconds with 24 queries
