__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 Last edited by atvfreek; 02-19-2012 at 08:00 AM. |
| The Following 15 Users Say Thank You to atvfreek For This Useful Post: | 2011speed (01-12-2012), BigJimMs3 (01-11-2012), charlesfist (01-11-2012), ckMS3 (01-11-2012), Dahouse702 (01-11-2012), helmetface (01-12-2012), jrlms6 (01-11-2012), JTMS3 (01-11-2012), ms3bamf (01-11-2012), Oliverms3 (01-11-2012), redblur (02-26-2012), rfinkle2 (01-12-2012), rghispanic88 (01-11-2012), Teethkikr (01-12-2012), uncorked11 (01-11-2012) |
![]() Join Date: Jul 2009 Location: Ville, KY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,037
| Not Ranked : 0 score Nice curves and numbers you got there man. What did u change between the two runs? Also, would you happen to have a log of that run |
| The Following User Says Thank You to charlesfist For This Useful Post: | atvfreek (01-11-2012) |
![]() Join Date: Apr 2010 Location: Miami FL
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 3,836
Groans: 263
| Not Ranked : 0 score very nice, no meth nor e85 right?
__________________ 2010 Black Mica 2004 EVO 8 Green Monster The "7up" |
| The Following User Says Thank You to rghispanic88 For This Useful Post: | atvfreek (01-11-2012) |
![]() Join Date: May 2011 Location: MA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,578
| Not Ranked : 0 score Look how smooth that turbo spools up!
__________________ 2011 Ford Mustang GT Premium - 6spd manual, brembos, 3.73, Roush Axle Back, JLT Oil Seperator, Air Raid intake Previous - 2011 Mazdaspeed3 - Corned out FREEKTUNE |
| The Following User Says Thank You to ms3bamf For This Useful Post: | atvfreek (01-11-2012) |
(Thread Starter) | Not Ranked : 0 score That run with the lower numbers was a tune I was running a couple weeks ago that ran awesome, so between the 2 maps I added roughly 2 degrees of timing. I feel like the dyno is missing some top end power though. My log on the dyno has wgdc maxed and only 16psi, where on the street my wgdc maxes at about 90% and holds 17+psi. datalog 75 is on the dyno, and 77 is shortly after I left
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 |
| The Following User Says Thank You to atvfreek For This Useful Post: | charlesfist (01-11-2012) |
(Thread Starter) | Not Ranked : 0 score Nope, no e-85 near me, and my next mod will be meth, so I am going to rent some dyno time to tune for that. Thanks Scott! Once you get those internals in, we can get your car up there in power.
| The Following User Says Thank You to atvfreek For This Useful Post: | ms3bamf (01-11-2012) |
__________________ 2011 Ford Mustang GT Premium - 6spd manual, brembos, 3.73, Roush Axle Back, JLT Oil Seperator, Air Raid intake Previous - 2011 Mazdaspeed3 - Corned out FREEKTUNE | |
![]() Join Date: Feb 2010 Location: Lynn, MA
Rep Power: 3402 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,058
Groans: 76
Groaned at 22 Times in 20 Posts
| Not Ranked : 0 score You sexy fuck
__________________ 2006 Mazdaspeed 6 BNR S4 and supporting mods 2007 Mazdaspeed 3 Bolt on's and tune 2015 Taurus S.H.O Intake/Tune 2016 Ford Explorer Sport Stock |
| The Following User Says Thank You to BigJimMs3 For This Useful Post: | atvfreek (01-11-2012) |
![]() Join Date: Nov 2010 Location: valley stream , NY
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 52
| Not Ranked : 0 score nice numbers ! I hope to get close to the results with similar mods besides the TMIC
__________________ 2013 CWP Mazdaspeed 3 : COBB TIH, COBB Intake, COBB AP, GFB BPV, SURE Shortcut, counterweight, and shifter bushings, Rally Armour mud flaps, |
| The Following User Says Thank You to chintastic For This Useful Post: | atvfreek (01-11-2012) |
__________________ 2010 Speed3-PTE5858 Freek built/Freektuned 510hp420tq 11.321@129.93 | |
How much of that difference would you attribute to the ~20 degree boost air temperature difference between the two (cooler street log) Cooler air -> easier to make boost. | |
(Thread Starter) | Not Ranked : 0 score Some of it is cooler air, but I think some of it has to to with the load on the dyno as opposed to the street. I have been running the same boost curve since the summer time and on the hottest days it would hardly ever hit 100% wgdc.
| The Following User Says Thank You to atvfreek For This Useful Post: | charlesfist (01-12-2012) |
(Thread Starter) | Not Ranked : 0 score Updated OP with dynofile rather than shitty phone pic.
| The Following User Says Thank You to atvfreek For This Useful Post: | charlesfist (02-19-2012) |
