![]() Join Date: Jun 2013
(Thread Starter) | Not Ranked : 0 score First off, big thanks to Alex. The overall experience was very pleasurable and super easy. I would recommend these guys in a heartbeat. Second, maybe someone would be so kind as to take my log and put it into their virtual dyno and post the picture? I have an old VD or something, and it doesn't show the peak numbers and it's not as cool looking as everyone else's. Har. Thanks G00s3y. Got it figured out. Just click on the attachment a few times to get a full size one.
__________________ 2013 Mazdaspeed 3 VRM. 28k miles. JBR RMM, Cobb SRI, OBX TP, APv2, Autotechs, CS BPV, 235/40/18 Nitto NT05. Stratified, 4gal E85. Last edited by DansSpace; 10-20-2014 at 07:33 PM. |
| The Following User Says Thank You to DansSpace For This Useful Post: | Lex (10-20-2014) |
Groans: 438
| Not Ranked : 0 score You can download the newest version of Virtual Dyno here - http://www.virtualdyno.net/public/VirtualDyno_Setup.exe
__________________ 2013 Mazdaspeed 3 VRM. 28k miles. JBR RMM, Cobb SRI, OBX TP, APv2, Autotechs, CS BPV, 235/40/18 Nitto NT05. Stratified, 4gal E85. | |
| Not Ranked : 0 score Is that a pothole or are you just excited to see me? What's up with the dip in the beginning?
![]() Join Date: Sep 2012 Location: Flemington, NJ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 75
| Not Ranked : 0 score 289HP on E85???
__________________ |
| The Following User Says Thank You to tikous360 For This Useful Post: | ArmanRus (10-22-2014) |
![]() Join Date: May 2012 Location: Los Angeles, CA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 39
Groaned at 8 Times in 4 Posts
| Not Ranked : 0 score Why 289 HP? You at altitude? I'm making that power with pump gas.
__________________ Cobb AP V3 // Cp-e HPFP // Cobb SRI TIP // Cobb DP // Cobb FMIC // Denso ITV22 // Cp-e Triton Cat-Back // Forge V2 BPV // JBR 88 Duro RMM Cobb SoCal tuned |
Not sure exactly why it does that. I changed it and updated the attachment in the OP Where I live is about 2700' ASL.
__________________ 2013 Mazdaspeed 3 VRM. 28k miles. JBR RMM, Cobb SRI, OBX TP, APv2, Autotechs, CS BPV, 235/40/18 Nitto NT05. Stratified, 4gal E85. Last edited by DansSpace; 10-20-2014 at 07:35 PM. Reason: MSF Database - Automerged Doublepost | |
(Thread Starter) | Not Ranked : 0 score Does that seem low for the altitude? For comparisons sake, I took a VD on the Cobb stage2+ map right before the tune and was somewhere around 250/285 with the same mods, so I gained 39hp and 46tq from that. If something is wrong with my car or tune, perhaps I can get some insight..
High heat and altitude certainly don't help the situation. Otherwise your targets, AFRs, timing, fueling are all on point.
I was then informed that the heat and altitude were less than ideal conditions after replacing the bpv, and that the flow was just a by-product of where I live.. A dryflow filter was suggested after the fact to add a bit more flow, but in no way was it indicated as a problem. Maybe this discussion could continue via e-mail or pm. I have most of the e-mails saved, and don't see a cat or wastegate ever being mentioned.. I enjoyed my experience with Stratified, and I understand mechanical issues with the car are not something you can remedy via e-mail, but to see these two additional issues be mentioned after the fact makes me uneasy.. I would have been happy to attempt to diagnose or remedy them during the specified time, rather than have them mentioned after the fact when you state the car isn't flowing as it should..
Heat and altitude certainly played a role as we were tuning in very hot weather above sea level. Every car is a little different in how much it flows and I mentioned the bpv and air filter as they are the easier to swap and less expensive items. I then maximized what your current hardware could do via the tune. In the end it is about your personal goals. If you would like to increase power I can certainly help make suggestions on what parts to address next based on your hp goals. Please don't hesitate to email me. I have all your tuning information, logs, and tunes on file.
![]() Join Date: Jun 2012
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 242
| Not Ranked : 0 score Try a dry filter, cheap and easy
__________________ Gen 2 2012 - Precision 6062 Turbo - CPE Exhaust Mani - PTE 46mm EWG - 2NV Industries built Forged bottom end - PNP Head - JMF V2 Intake Mani- Custom DP UR Cat Back - HTP 4 inch intake - TR8 FMIC - Custom FREEKTUNE METH Port Injection - Cobb 3 port EBC- Autotech internals - FREEKTUNED. |
| Stratified Results with Lex | shane5747 | Stratified Automotive Controls | 7 | 01-07-2014 09:36 PM |
| Delphi posts lower Q4 results, but expects improved 2013 results | Haltech | Automotive News | 0 | 02-05-2013 11:40 AM |
| Stratified SoCal Dyno Day Official Results, Pictures, Videos | Lex | Stratified Automotive Controls | 61 | 12-15-2012 11:58 AM |
| Stratified! 284/326 | Midnitehours | Stratified Automotive Controls | 0 | 10-05-2012 09:12 AM |
| MY RESULTS WITH DIZZY TUNNING-BY BUCKER- B4 AND AFTER "REAL" DYNO RESULTS | stc terminus | 2010 MS3 - ECU Computer Tuning | 2 | 07-30-2012 10:43 PM |
