Like Tree16Likes
  • 11 Post By PapaSmurf
  • 3 Post By PapaSmurf
  • 1 Post By PapaSmurf
  • 1 Post By 2.0t03speed
 Old 08-16-2015, 11:06 AM   #1
PapaSmurf's Avatar
Posts: 8,236   (View Stats)
Default Papasmurf 860whp/677wtq
So yesterday I finally had the opportunity to get on the dyno and turn the car up.
The log/dyno sheet is attached.
This car is an absolute beast, the weather was on my side since it was a 9000ft density altitude. so the SAE correction factor was quite well.
The car made just shy of 700 uncorrected hp with the 9000ft DA
This car at sea level could easily make 800+ and very well close to 900 if the car could hold more boost. As you can see in the logs the car hits 41psi and holds to 6800ish then drops to 35psi by 8k. This is an issue that is trying to be fixed.
Fuel is 100% E85, DW 2200CC injectors in my PI rail. Duel DW 340LPH in tank pumps.
I'm holding out for cooler weather and a lower density altitude for the track. The car as it sits now should easily trap 140+. I just have to get a good 1/8th mile down before i make a full pull. Track is nazi's with the 135mph/11.5 rule.
860whp/677wtq
2.7 V6 Ecoboost
The Following 40 Users Say Thank You to PapaSmurf For This Useful Post:
2.0t03speed (08-17-2015), 802MS3 (08-17-2015), ArmanRus (08-16-2015), Boost_creep (08-17-2015), Brendanb (08-17-2015), bwspeed (08-16-2015), Code Monkey (08-16-2015), dan7225 (08-17-2015), djern (08-16-2015), doctavus (08-17-2015), Dralphy (08-16-2015), Easter Bunny (08-16-2015), Etipp98 (08-16-2015), EwMPS (08-17-2015), GARRETHEXTREME (08-16-2015), h.h.sk1nny (08-27-2015), Hush (08-16-2015), itslogics (08-31-2016), ItsNox (08-17-2015), JgamB (08-17-2015), Justin@Freektune (08-16-2015), Koke382 (08-17-2015), Lex (08-17-2015), lnumbp (08-16-2015), Mauro_Penguin (08-16-2015), Mazdazilla6 (08-17-2015), MD1032 (08-19-2015), NoRegrets (08-17-2015), rtabagaboy (08-16-2015), Scare Dem (08-16-2015), sh4d0w (08-16-2015), Shampu (08-16-2015), Snyeed (08-16-2015), SofaKingAwesome (08-17-2015), SpeedRebirth (08-17-2015), taf0422 (08-16-2015), WetzMS3 (08-17-2015), xxdjfate76xx (08-17-2015), zjnspeed3 (08-16-2015), [R]usty (08-16-2015)
 Old 08-16-2015, 11:22 AM   #2
mxlplx71's Avatar
Posts: 3,269   (View Stats)
Groans: 128
Congratulations on the great build.
09 Speed3 ,sold
2015 06 ms6 parted
2016 07 cosmic MS3
PapaSmurf (08-16-2015)
 Old 08-16-2015, 11:55 AM   #3
Mauro_Penguin's Avatar
Posts: 1,997   (View Stats)
Groans: 171
Shooting for 9's?
At least whoop that damn neon.
 Old 08-16-2015, 11:56 AM   #4
PapaSmurf's Avatar
That neon ran a 10.8 at like 135 and has since been parted out and sold
860whp/677wtq
2.7 V6 Ecoboost
Easter Bunny (08-16-2015), Mauro_Penguin (08-16-2015), WetzMS3 (08-17-2015)
 Old 08-16-2015, 12:32 PM   #5
RE-ACTIONENGSPEED3's Avatar
Posts: 401   (View Stats)
Great numbers!!!how are you reving 8000rpm with AP is that an option i have in mind that was avaliable untill 7700rpm??
Also , what size maf you are?
Cant wait to see this car to strips...
2008 speed3
True red.
Pte 6466 & AWD Mode on !!!!
 Old 08-16-2015, 12:51 PM   #6
PapaSmurf's Avatar
Nah you can Rev to 8k on the AP.
4inch maf.
860whp/677wtq
2.7 V6 Ecoboost
The Following 8 Users Say Thank You to PapaSmurf For This Useful Post:
Code Monkey (08-16-2015), Easter Bunny (08-16-2015), Justin@Freektune (08-16-2015), Mauro_Penguin (08-16-2015), Mazdazilla6 (08-17-2015), MD1032 (08-19-2015), RE-ACTIONENGSPEED3 (08-16-2015), WetzMS3 (08-17-2015)
 Old 08-16-2015, 01:04 PM   #7
rtabagaboy's Avatar
Posts: 363   (View Stats)
rtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the worldrtabagaboy is the leader of the world
Groaned at 7 Times in 3 Posts
Great work! That's fantastic everything! What extra gear do you need to go below 11.5? Cage?
2008.5 BlackMica Mods:
- Cobb SRI, Turbosmart BPV, CPE RMM 60d, TRZ TMM, TopSpeed PMM, HTP Turbo Inlet... I'm workin' on it.
AZ Status!
rtabagaboy is offline   Reply With Quote
 Old 08-16-2015, 01:08 PM   #8
PapaSmurf's Avatar
Yeah cage and under car protection incase of catastrophic failure
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-16-2015, 01:20 PM   #9
Putin 2.3T's Avatar
Posts: 1,040   (View Stats)
Any ideas as to why you can't boost beyond 41psi? Only reason I ask is because I will be running a 6466 on my build and I want 50+psi, lol. If you're having issues with the hotside, then I can only assume those issues will be the same for me. Curious.
2011 Mazdaspeed 3 [Sold]
 Old 08-16-2015, 01:22 PM   #10
PapaSmurf's Avatar
I think it has to do with the way my boost controller is set up. I'm only taped into the side of the gate and I want to say I need to tap into the top of the gate also.
It also may be my altitude.
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-16-2015, 01:26 PM   #11
Putin 2.3T's Avatar
That's how I was planning to run my wastegate. VTA the top-port and only use the side port. I might need to have the WGA and EBCS brought back to a vacuum source instead of VTA.
Altitude doesn't have that much of an impact on boost. At least that's what I've been told. I live at sea level so it's all gravy for me.
Non the less, 860whp is beyond impressive. That is one hell of a build. What size head-studs are you running?
 Old 08-16-2015, 01:34 PM   #12
PapaSmurf's Avatar
10mm L19's and the block is oringed
Ziggo, ItsNox and Justin@Freektune like this.
860whp/677wtq
2.7 V6 Ecoboost
Easter Bunny (08-16-2015), Justin@Freektune (08-16-2015), Mauro_Penguin (08-16-2015), Mazdazilla6 (08-17-2015), mxlplx71 (08-17-2015), WetzMS3 (08-17-2015), Yatta (08-17-2015), Ziggo (08-17-2015)
 Old 08-16-2015, 01:59 PM   #13
Putin 2.3T's Avatar
The Following 3 Users Say Thank You to Putin 2.3T For This Useful Post:
Easter Bunny (08-16-2015), Swinger13 (08-17-2015), Yatta (08-17-2015)
 Old 08-16-2015, 04:52 PM   #14
PapaSmurf's Avatar
Video added
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-16-2015, 05:03 PM   #15
snailD's Avatar
Posts: 3,039   (View Stats)
I didn't see what you ended up doing for this build? care to share the engine specs?
 Old 08-16-2015, 05:15 PM   #16
PapaSmurf's Avatar
Check my build thread. Papasmurf Round 2
860whp/677wtq
2.7 V6 Ecoboost
 Old 08-17-2015, 04:58 AM   #17
Snyeed's Avatar
Posts: 743   (View Stats)
Groaned at 8 Times in 4 Posts
Awesome numbers, love that Kozmic top mount kit.
417whp 428tq 12.037@117.2mph
PapaSmurf (08-17-2015)
 Old 08-17-2015, 09:25 AM   #18
kbspeed3's Avatar
Posts: 15   (View Stats)
kbspeed3 is just really nicekbspeed3 is just really nicekbspeed3 is just really nicekbspeed3 is just really nice
Wow. Inspiring. Congrats.
kbspeed3 is offline   Reply With Quote
 Old 08-17-2015, 09:40 AM   #19
2.0t03speed's Avatar
Posts: 1,302   (View Stats)
as long as you have a proper exhaust you can hit that boost level. We hit 48psi on kr's car with a 3.5" exhaust and the 6466. You are at sea level like us so it's easier to hit these high boost numbers vs smurf being at 5700ft above sea level.
The Following 2 Users Say Thank You to 2.0t03speed For This Useful Post:
Easter Bunny (08-17-2015), Putin 2.3T (08-17-2015)
 Old 08-17-2015, 09:42 AM   #20
Putin 2.3T's Avatar
3.5" exhaust, man.. and here I thought I was being a pioneer, lol. Just about all of my good ideas have been done before.
 Old 08-17-2015, 09:46 AM   #21
PapaSmurf's Avatar
All the hood exit guys are on 4 inch haha
2.0t03speed likes this.
860whp/677wtq
2.7 V6 Ecoboost
2.0t03speed (08-17-2015), Easter Bunny (08-17-2015), Justin@Freektune (08-17-2015)
 Old 08-17-2015, 09:48 AM   #22
we had to on his ms6 with the 3" exhaust we couldn't get past 38psi. swapped to the 3.5 and boom faster spool and was able to get all the psi's.
ItsNox likes this.
 Old 08-17-2015, 10:01 AM   #23
Justin@Freektune's Avatar
Posts: 954   (View Stats)
4" exhaust like a boss, and cool flames
PTE 6062
633HP/523TQ
Quickest/Fastest Mazdaspeed
4/22/2017 New England Dragway
2.0t03speed (08-17-2015), ItsNox (08-17-2015), PapaSmurf (08-17-2015)
 Old 08-17-2015, 08:54 PM   #24
SFWD 1934's Avatar
Posts: 973   (View Stats)
SFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the worldSFWD 1934 is the leader of the world
you could always just use CO2 for the gate to achieve desired boost. Sometimes the combo of gate placement and hotside sizing can cause you to lose that boost up top.
Jason
JRL Tuning 510-459-7229
www.full-race.com
SFWD 1934 is offline   Reply With Quote
The Following 2 Users Say Thank You to SFWD 1934 For This Useful Post:
Justin@Freektune (08-18-2015), PapaSmurf (08-17-2015)
 Old 08-17-2015, 09:01 PM   #25
4inch maf.
Funny. Not but a couple months ago there were a couple of individuals telling me it was impossible to get past 7800 on an AP. Maybe it's a genpu thing.
Anyway, congrats on the huge numbers! Can't wait to see how it does at a strip.
Papasmurf's New Numbers PapaSmurf 2010 MS3 - Dyno Sheets/Discussions 18 09-16-2013 11:10 AM
Papasmurf's new numbers PapaSmurf 2010 MS3 - Dyno Sheets/Discussions 45 11-16-2012 07:27 PM
Page generated in 0.46308 seconds with 33 queries
