![]() Join Date: Mar 2016 Location: Crystal River, FL
Rep Power: 0 ![]() Thanks: 10
(Thread Starter) | Not Ranked : 0 score 1st question would i have had more accurate/better numbers doing a 4th gear pull? 2nd question do these numbers look low? mods are in sig also i know ambient temp plays a factor and i live in FL so it always hot as hell. 3rd gear dyno.jpg datalog5.csv datalog6.csv
__________________ 2010 VCM Mazdaspeed3 w/Tech 304whp/354wtq - Autotech hpfp internals, Corksport stage 2 intake, HKS SSQV full recirc, CXR FMIC, CFM 9 peg RMM, Cobb V3 AP, LTR7IX-11 plugs, Purple Drank tune @21psi 93 octane Last edited by 2010REDMS3; 04-29-2016 at 05:25 PM. |
Rep Power: 3748 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 8,745
| Post your log for this run.
(Thread Starter) | Not Ranked : 0 score ill post the logs in a few hours when I get home from work.
__________________ 2010 VCM Mazdaspeed3 w/Tech 304whp/354wtq - Autotech hpfp internals, Corksport stage 2 intake, HKS SSQV full recirc, CXR FMIC, CFM 9 peg RMM, Cobb V3 AP, LTR7IX-11 plugs, Purple Drank tune @21psi 93 octane |
| For future reference, posting a picture without the data to go with it will not get you very far at all. All I can tell you, based on that plot, is that you've got something very wrong with either A) the way you're taking logs, or B) the clutch is slipping badly.
(Thread Starter) | Not Ranked : 0 score ok well it could be the way im taking the logs the clutch doesn't feel like its slipping and the car pulls fantastically better than when it was stock.
For instance, here's a screen grab from a couple of plots overlaid on top of one another. The green curve is a K04 pull, and the blue curve is a BNR pull. Note the lack of sudden sharp changes of direction in any of the lines.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! Last edited by Vansquish; 04-29-2016 at 12:04 PM. | |
![]() Join Date: Mar 2015 Location: Norcross, GA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 45
| Not Ranked : 0 score why are his AFRs going crazy like that?
__________________ I'm stock bro. |
| It could be as simple as the tune targeting something like 11.4:1 and the ECU only knowing that 11.32 and 11.47 exist.
| The Following User Says Thank You to Vansquish For This Useful Post: | Dommo14 (04-29-2016) |
![]() Join Date: May 2009 Location: Huntsville, AL
Rep Power: 1431 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 1,522
| Not Ranked : 0 score Without seeing the data, my guess is that is a combination of wheel spin and SWAS kicking in.
__________________ True Red 2009 MS3 Damond Motorsports: RMM // Short Shift Plate Suspension: Koni Yellows // Swift Spec-r springs // Fatcat motorsports front bump stops // Rear Camber Arms Brakes: Hawk HPS pads // ATE Superblue fluid // Stainless Steel Brake Lines Other: CP-e Safe Seals // MattDamond shift plate // Masonvi shift knob // 3.5" WP w/recirc // RSB // IM + TB tigs // Synapse Engineering FMIC + BOV // Autotech internals Tune: hypnotic tuned Critical Stats: // 305whp/352tq // 13.34 @ 98 - Mason Dixon Dragway - 4/13/14 Titanium Gray 2006 Mazdaspeed 6 Damond Motorsports: OCC // Short shift plate // Turbo oil feed restrictor bolt Other: Autotech internals // Ebay M2 DP // Masonvi shift knob // |
| The Following User Says Thank You to nindoja For This Useful Post: | Jakeypoo (05-01-2016) |
![]() Join Date: Jan 2015 Location: Williamsburg, VA
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
Groaned at 3 Times in 1 Post
| Not Ranked : 0 score I'm tuned by Ryan from pd and I know he targets 20psi....youre hitting 13? Have you done your maf Cal yet? Sent from my iPhone using Tapatalk
__________________ 2012 Mazdaspeed 3 CS SRI + TIP - CS TMIC - CS Catted DP - Autotech HPFP Internals - Denso ITV22 Purple Drank Tune in process |
something Is up with the vdyno program, if you look at the datalog it shows I hit 20psi at 2900rpm but the dyno graph says I don't hit 20psi till about 3800rpm and if you look at the datalog I hold 20psi for a bit but the dyno graph shows it immediately dropping after I hit it.
__________________ 2010 VCM Mazdaspeed3 w/Tech 304whp/354wtq - Autotech hpfp internals, Corksport stage 2 intake, HKS SSQV full recirc, CXR FMIC, CFM 9 peg RMM, Cobb V3 AP, LTR7IX-11 plugs, Purple Drank tune @21psi 93 octane | |
| You're looking at the wrong scale on the graph.
Your datalogs show that the car is hitting ~19.xxpsi by around 3200-3400rpm, peaking at around 20 by around 4000rpm, and then tapering off. This tracks with what a reasonably safe tune for the K04 should do. Something is still very wrong with the logs/graphs though. You're having wheelspin, clutch slip, or SWAS is interfering with the pulls you're making. Try turning SWAS off and take a 4th gear log on the flattest, straightest road you can find.
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | |
![]() Join Date: Mar 2014 Location: Durham, NC
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 10
| Not Ranked : 0 score Looks like power is where it should be ish.... I was making about the same on 93 on a 6 but not in FL heat... That also included a test-pipe though which I don't see in your mods including the drive-train loss it'd probably put you right there. Although there's something really wrong with the plot... definitely make sure the road is level and you're not logging while going over a bridge or something.
__________________ 2006 Super Clean BCM MS6 Corksport Intake/TIP - Test Pipe - CS FMIC - Freektune - Autotech HPFP - 18x8 Wheels with Nitto NT05's 235/40/18 - H&R Coilovers - SPC Balljoints - CS RMM - Magnaflow CBE - DM Power Steering Cooler - CAR LED Tails - EBC Yellowstuff w/ Centric Blanks - Xcarlink w/ Bluetooth Module Waiting to be installed: Diff Braces - TMM Insert |
__________________ Having trouble finding something on MSF? Use MS3Shadow's search tool:SEARCH MSF HERE! | ||
![]() | | #19 | ![]() |
| Not Ranked : 0 score I'm looking at the datalog he posted...
![]() | | #20 | ![]() |
| Which one? Datalogs 5, 6, and 7 (the only ones I can seem to find) all show that he's hitting ~20psi, just not where in the rev-band he says he is.
![]() | | #21 | ![]() |
![]() Join Date: Dec 2013 Location: Surprise, AZ
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 368
| Not Ranked : 0 score When you say turn the SWAS off, is that turned off when DSC is off? I turn off DSC before every pull and I get inconsistent vdyno power curves, on the exact same road. How much wheel turn would make SWAS kick in? I'm gen1, by the way.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD |
![]() | | #22 | ![]() |
(Thread Starter) | Not Ranked : 0 score From what I read you physically have to unplug the SWAS
![]() | | #23 | ![]() |
| Not Ranked : 0 score Hmm. I'll do some reading. SWAS is gay.
![]() | | #24 | ![]() |
(Thread Starter) | Not Ranked : 0 score if all its doing is keeping me from getting accurate dyno numbers then I wont bother lol the butt dyno is happy so..
| The Following User Says Thank You to 2010REDMS3 For This Useful Post: | Atticaz (04-30-2016) |
![]() | | #25 | ![]() |
| Not Ranked : 0 score True dat. Just sucks when you wanna see the numbers. Lol. I guess I just need to hit up a Dyno Day. Butt Dyno is thrilled with every drive.
![]() | | #26 | ![]() |
(Thread Starter) | Not Ranked : 0 score agreed.
![]() | | #27 | ![]() |
| Not Ranked : 0 score Post #10 . I'm on my cell so there's a good chance I missed something but datalog 7 was the latest post when I replied Sent from my iPhone using Tapatalk
![]() | | #28 | ![]() |
![]() | | #29 | ![]() |
| Not Ranked : 0 score You never answered my question if you have a test pipe.... If you had a test pipe you'd probably gain quite a bit of power... If you DO have one I'd expect to see higher numbers for you honestly.
![]() | | #30 | ![]() |
(Thread Starter) | Not Ranked : 0 score oh sorry lol no I don't have a test pipe but I just ordered an fmic kit and a cpe catted dp
![]() | | #31 | ![]() |
| Not Ranked : 0 score If that's the case then your numbers are right on point, you gain quite a large amount of power once removing the 2nd cat (regardless of DP or not). You'll see some decent gains from that -- keep in mind in the heat 93 will be limited, E85 is king .Is your CPE a long downpipe that replaces the 2nd cat too? Not sure if companies still make a shorty DP (not including the test pipe section) -- but you need to get rid of that 2nd cat if it IS a shorty before you install that DP.
![]() | | #32 | ![]() |
![]() | | #33 | ![]() |
| Not Ranked : 0 score Ouch that sucks! I'm lucky I had a station open 5 mins from me! A lot of people will get a 15gallon gas caddy or several cans and go stock up once a month. Not that bad for the gains it provides, especially in the heat....
![]() | | #34 | ![]() |
(Thread Starter) | Not Ranked : 0 score yeah that's why im getting the fmic I figured it would considerably help with the high BAT's. when I wake up it starts out at 77 degrees then by mid day its anywhere from 90-100 outside lol
![]() | | #35 | ![]() |
sent from my Nexus 6P
__________________ 2013 Crystal White Pearl Mazdaspeed 3 w/ Tech Package BNR S4, XSPower v3 Exhaust Manifold w/ Tial 44mm EWG Cobb accessport V3, Dizzy Tune in progress CP-e stage2 rmm, tmic, hpfp JBR boost tubes, Tru-3.5in Intake inside a Corksport Cold Air Box, Catless Downpipe & Racepipe, bypass hose, hood scoop, BPV, hood struts, stubby antenna, Aluminum Skid Plate, EBCS, 3.5BAR MAP Sensor, Magnaflow Catback Exhaust DM Full EGR Delete, Passenger Motor Mount, Transmission Motor Mount., Coolant Bypass, VTCS Delete, NGK ILTR6A-7G ,G-LOC R6 Brake pads and Centric High Carbon brake rotors Looks: 25% tint front, 5% back, Heat-blocking front windshield film Escort Passport Max360, RGBW Halos/Demon Eyes 20'' LED Light bar Use my Updated Custom Google Search to search this forum since the advanced search here is broken | |
![]() | | #36 | ![]() |
(Thread Starter) | Not Ranked : 0 score After doing a bit of research I decided to be cheap and get the cx racing kit, itll be effective for my mods and weather conditions and if I want I can always eventually upgrade the core.
![]() | | #37 | ![]() |
Same boat, here. Live in AZ.
__________________ 2017 Mustang V6 - Soon to be Supercharged 2007 MAZDASPEED3 - SOLD | |
![]() | | #38 | ![]() |
![]() Join Date: Jan 2013 Location: McKinney, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 2,778
| Not Ranked : 0 score You could spray meth for cooling purposes only, some people also are putting meth in the gas tank as well but not sure how economical that is.
__________________ 3rd rebuild on the way...maybe... |
![]() | | #39 | ![]() |
(Thread Starter) | Not Ranked : 0 score meth in the gas tank eh? interesting lol, but yeah a friend of mine lives more south in FL than I do and with meth spray he pulls 66 degrees BAT whereas I pull 119-130 lol
![]() | | #40 | ![]() |
![]() Join Date: Jul 2013 Location: San Antonio, TX
Rep Power: 0 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Thanks: 301
| Not Ranked : 0 score I just finished up my tune with Will. This was my 2nd to last revision. Same setup as you plus a TP and CP-e TMIC. Deleting the cat would definitely free up some power. I'm at 20psi aswell |
| Purple Drank E-tune power gains | 2010REDMS3 | 2010 MS3 - ECU Computer Tuning | 17 | 04-12-2016 12:04 PM |
| Purple drank results | Mastertrixter | 2010 MS3 - Dyno Sheets/Discussions | 8 | 09-21-2014 02:33 AM |
