> 2010 MS3 - How-To's
  • 1 Post By ahfunaki
 Old 02-21-2013, 09:19 AM   #1
Redfor's Avatar
Posts: 82   (View Stats)
Redfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant futureRedfor has a brilliant future
Default CorkSport LED Rear Bumper Lights
Didn't someone do a DYI on corksport-led-rear-bumper-lights ??? I thought I read one on here but cant seem to find the DYI anymore. I did my install last summer and thought I'd throw out the info for anyone interested.
Anyways! Wanted to add that you can put a Trailer Wiring harness on it to give full functionality of the LED Strips... Trainer Wiring Harness
Without the harness, the LED Strips can be Wired to Either your Brake Lights OR blinkers but not both. With the Harness you have full functionality.. ie Brake and turn signal at the same time.. One will be bright, other Blinking, etc..
Just do yourself a Favor and DO NOT use the inline splice clips that come with the LED kit.. Had to go back and re-wire everything due to bad splices using the clips.
Let me know if anyone wants a Video of the LED strips working.
Redfor is offline   Reply With Quote
 Old 02-21-2013, 09:21 AM   #2
Spec's Avatar
Posts: 4,472   (View Stats)
The fuck are you on about? Alright I see. Why don't you write up a how-to
Alexander (02-21-2013)
 Old 02-21-2013, 09:35 AM   #3
Redfor's Avatar
Still searching for the old one before I do. Possible I read it somewhere else. I just wish I would have taken pictures of everything when I did my install.. Rear bumper Removal is a pain!! But will have to at least draw out a wiring diagram for everyone.
 Old 02-21-2013, 09:40 AM   #4
Alexander's Avatar
Posts: 841   (View Stats)
Alexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the worldAlexander is the leader of the world
Groaned at 43 Times in 16 Posts
Just do a write up. Even if there is another one it could probably use updating. I've had these led lights sitting in my dorm room for months, its about time I get to putting them on and I want to do it right
2011 Mazdaspeed 3
Cobb v3 AP | Autotech CDFP | JBR Sri | JBR Balance Shaft Delete | JBR Rear Sway Bar | JBR 88 duro RMM | M2 Testpipe | Corksport Tip | Corksport Short Shifter | Corksport SSP | Corksport Shifter Bushings | Cobb Counterweight | H&R Lowering Springs | Joseph Koni Shocks/Struts | SPC Rear Camber Arms
Alexander is offline   Reply With Quote
 Old 03-02-2013, 02:42 PM   #5
chrisattack18's Avatar
Posts: 256   (View Stats)
chrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond reputechrisattack18 has a reputation beyond repute
i just installed mine today. i want to go back later and wire them into the brake lights
2012 Velocity Red Mazdaspeed 3
Cobb Accessport / Cobb FMIC / James Barone Racing Chrome Molly RMM / Corksport OCC / Corksport SRI+TIP / Corksport LED reflectors / ATP Turbo 3" DP / SSP EGR Delete / Autotech FP Intenals / ARK Catback Exhaust
chrisattack18 is offline   Reply With Quote
 Old 03-04-2013, 02:49 PM   #6
DownSideFX's Avatar
Posts: 234   (View Stats)
DownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the worldDownSideFX is the leader of the world
Groaned at 25 Times in 9 Posts
I submitted the product to CorkSport as the only readily available ones were from some shady e-bay seller and the price was much higher (like $90 shipped I want to say). They put together good instructions and I added a few things before they posted it to their website for download.
I didn't use the splice clip either, in fact my trial led reflectors didn't even come with them. I went straight to the license plate light and haven't had any problems in over a year.
I'm curious if the blinker one would be sync'd up or if the lights would be out of time.. that would drive me insane. I didn't want to bother with it. Smoked reflectors with a plastidip'd valence is the way to go!!
Garage: 2014 Evolution MR, 1983 Volvo 242 Turbo
Past: 2010 Mazdaspeed3
Do not donate to this fucking shithole. lol
DownSideFX is offline   Reply With Quote
 Old 03-05-2013, 10:44 PM   #7
The Nut's Avatar
Posts: 1,571   (View Stats)
A buddy of mine in MOCC has them hooked up as lights, brake lights, and turn signals. They sync just fine. In every aspect of their use, their not as bright as the rest of our tail lights. But I and he don't think they're Corksport's as he bought them off eBay from (someone?/someplace?). But regardless, they came with the wiring to hook them up with all three functions. And like I said, the turn signal aspect sync's just fine. I fucking want them! C'mon @CorkSport; HOOK A BROTHA UP!!!
2012 BLACK MICA w/TECH
91 & Corn diagnostics by:
 Old 03-05-2013, 11:13 PM   #8
The best way to connect is solder and heat shrink. Not everyone has solder and heat shrink so the splices come in to play.
The set we sell is wired so you can use them as markers and brakelights or turn signals. The response time on LEDs is really good so I dont see any sync problems with the lights.
Do you have one of our calendars? There is a code in there to save 50% off with the purchase of another part on any of the LED products we offer. If you dont have one of the calendars get one, there is a deal each month.
-Derrick
DownSideFX (03-06-2013)
 Old 03-05-2013, 11:39 PM   #9
The Nut's Avatar
-Derrick
How do I get a calendar Mr. Corksport? I mean Derrick.
 Old 03-06-2013, 12:46 AM   #10
ahfunaki's Avatar
Posts: 764   (View Stats)
ahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the worldahfunaki is the leader of the world
Good call on using the trailer harness! I actually have one of these Curt Custom Fit Vehicle Wiring for Mazda 3 2010 - C56011 that I'm going to use when I pull my ATV ( along with the hidden hitch of course).
I'll just get another end and solder it onto the bumper lights and plug it into that. And I'll just unhook them when I'm pulling the trailer.
Can't wait for the weather to get nice so I can really start working on my car again...
[ 2010 Black Mica Speed3 w/tech package ]
go | COBB AccessPORT | Autotech HPFP Internals | TurboXS Catless Downpipe | TurboXS Race Pipe | Ultimate Racing Catback w/Magnaflow Resonator | Corksport Urethane Exhaust Hangers |
JBR Boost Tubes | cp-e Nviscid Pipe | cp-e XcelNANO SRI | cp-e HeliHose | cp-e Stage 1 xFlex RMM | JBR SSB | RDS-05 Rear Sway Bar |
Torque Solutions Delrin Shift Knob | Block8Head Dual Defrost Pod | Aeroforce Interceptor | Prosport Evo Boost Gauge
show | BC Racing BR Coilovers w/Koyo | SPC Rear Camber Arms | Avid.1 AV-06 18x8 +42 225/40 | 2011+ Tech Headlights | Corksport Tow Plate |
Morimoto 5000k bi-xenon / 3000k fogs | 3BSpec Switchbacks | Corksport LED Rear Bumper Lights | S204 STi Lip
ahfunaki is offline   Reply With Quote
 Old 03-06-2013, 01:32 AM   #11
The Nut's Avatar
Will this particular harness allow for hook up of all three functions (tail light, brake light, & turn signal)? And would you need 2 of them? (One for each Corksport reflector replacement?)
 Old 03-06-2013, 11:32 AM   #12
Zoomspeed's Avatar
Posts: 370   (View Stats)
Zoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the worldZoomspeed is the leader of the world
I've had these sitting in my room for like 8 months I really need to get these lights on
Performance CobbAPCobbSRI/TIPAutotechInternalsDensoITV22 PlugsForgeBPVJBRDog Bone MountSpeed DaddyCatless DownpipeGreddyOCC
Appearance DDM5000k Headlights/3000k FogsCobbShift KnobCorksportLED Bumper LightsDepoLED Tails
E85
Zoomspeed is offline   Reply With Quote
 Old 03-06-2013, 11:35 AM   #13
Give this a shot.
Corksport Calendars
-Derrick
 Old 03-06-2013, 09:38 PM   #14
ahfunaki's Avatar
Yep, I don't see why not. And nope, one adapter should be all you would need.
I've attached a diagram showing what wire would do what coming off of that Curt adapter.
The Nut likes this.
The Following User Says Thank You to ahfunaki For This Useful Post:
The Nut (03-06-2013)
 Old 03-08-2013, 06:41 AM   #15
Thats how i have mine. So much win!
The Following 2 Users Say Thank You to chrisattack18 For This Useful Post:
DownSideFX (03-09-2013), The Nut (06-04-2013)
 Old 06-27-2013, 05:47 PM   #16
Redfor's Avatar
Ok! Someone asked for a video of the tail lights and here they are. Ignore the water mark, had to convert the videos from m4v to mp4... phew! Anyways!
First video is to give you a idea how they look during the day (both videos recored around 6pm Eastern) The 2nd Video I backed into the garage a little to give you a better idea how they look in the dark. Somewhat low quality to keep the file sizes down.
Note: As I was saying before in the thread I had to use a trailer harness, but those of you that have normal bulbs may not have to. The directions that come with the LED strips say EITHER brake or Turn signals if I remember correctly, but could be wrong. One last thing.. If you do install the kit, DO NOT use the dam wire splices!! they will cause you a massive headache trying to figure out why its not working... (Yes.. Been there, and spent another hour or so redoing it all the hard but correct way)
btw, I did a combination with lights on and off. left, right, left w/ brake, right w/ brake, and hazards. These are Not smoked.
2012 MS3 w/Tech
SURE SRI | SURE TIP | SURE RMM | SURE VENTUS BPV | COBB AP | AUTOTECH INTERNALS | SURE LESS MONEY |
CORKSPORT LED Bumper Lights |
The Following 3 Users Say Thank You to Redfor For This Useful Post:
CorkSport (06-28-2013), tclegg (06-27-2013), The Nut (06-27-2013)
 Old 07-07-2013, 03:50 PM   #17
hsraffety's Avatar
Posts: 106   (View Stats)
hsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud ofhsraffety has much to be proud of
Can you do a video that walks through how you wired it up? Or at least showcase how you wired it up?
2012 Crystal White Pearl Mazdaspeed3 - Cobb AccessPort // Cobb Short Ram Intake // Cobb Turbo Inlet Pipe // Autotech HPFP // Race Pipe // CP-E Stage 2 xFlex RMM // Hawk HPS Rotors and Pads
hsraffety is offline   Reply With Quote
 Old 07-12-2013, 02:03 AM   #18
DFC300's Avatar
Posts: 47   (View Stats)
DFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant futureDFC300 has a brilliant future
Neutral  :  -1 score
How are these different from the ones on eBay? I already got one from eBay and I'm not happy with the build quality. Some of the LEDs don't light up evenly or it's pointing downwards.
Sole where's my chopsticks?
DFC300 is offline   Reply With Quote
 Old 07-12-2013, 07:50 AM   #19
Spec's Avatar
I think you answered your own question bud.
 Old 07-12-2013, 11:31 AM   #20
Redfor's Avatar
Unfortunately I do not have a video or step by step directions, I wish I would have made one when I did mine. Doing one now would consist of me taking the whole rear end of the car apart which is hard to find time for.
The Corksport LEDs do come with some very good directions, but will have to admit that the install is a pain and there's no short cuts. You WILL need to jack up the rear end and put it up on jack stands. The next step is to remove BOTH rear wheels (hence the jack stands). Think this is why most people buy them and save them for a day when they have a lot of spare time. ( Don't be a idiot.. USE Jack stands... )
The Biggest advise I can give is DO NOT use the spice kits that come with the LED strips. I figured i'd save myself time by using them and found that they were not making good connections / splices. Therefore had to go back and do it the right way.. a lot of wire cutting, stripping and re-splicing. Basically use the same splices you would use for stereos.
As I stated before, using a trailer wiring harness will allow your LED strips to work as normal tail lights, brake, and blinker as in the video above. Link to the wiring harness is also above. I am not sure if you will need these if you have normal tail lights ( My tail lights are LED due to tech package ).
I do not know anything about the e-bay version, but I have yet to have any problems with any of the LEDs on the Corksport ones.
Im pleased with mine, minus the pain of the install. Some people say its a waste of money, me personally, I like'em. That and if you ever get rear ended (before you hit'em with a tire iron) you can ask them which of the 5 brake lights did they not see.. hehe..
2012 MS3 w/Tech
The Following User Says Thank You to Redfor For This Useful Post:
VooDreau (07-17-2013)
 Old 09-20-2015, 09:55 AM   #21
speed3okie's Avatar
Posts: 960   (View Stats)
speed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the worldspeed3okie is the leader of the world
Wired up some quick disconnect plugs for my bumper lights, in case I ever have the need to pull of the bumper.
Mod List:
CORKSPORT : Shifter Bushings / Interior Led Kit / Hood Struts / Short Ram Intake / Coolant Tank / Ecu Relocation-Battery Box / Disi Silicone Boost Tubes / Mid-chassis Brace / Fog Light Kit / Mud Flap Kit / Underhood Led Light Kit /
Disi Silicone Bypass Valve Hose / Turbo Inlet Pipe / Mazdaspeed MZR Bypass Valve / Leather Shift Knob / MS3 Race Rear Motor Mount /Adjustable Short Shifter /
Strut - Spring Combo Set
JBR: Tru-Torsion 3-Way Adjustable Rear Sway Bar / Transmission Side Motor Mount 80a Durometer /
Passenger Side Motor Mount 80a Durometer /
DIODE DYNAMICS: Interior Led Kit
SPC : Rear Camber Arms
Ebay: Race Pipe
Optima: Red Battery
MOOG : Front and Rear End Sway Bar End Links
AutoTech : HPFP Internals
35% Tint
-------------------------------Not done yet-------------------------
Need More Parts
speed3okie is offline   Reply With Quote
Rear Bumper PushingRedline 2010 MS3 - How-To's 3 11-07-2012 11:27 AM
Product Release! Corksport 2010+ Mazda 3/Mazdaspeed 3 LED Bumper Lights CorkSport CorkSport 8 02-15-2012 10:26 PM
Corksport Front Bumper prenedo MazdaSpeed 3/6 - Appearance 11 05-15-2010 07:22 AM
Page generated in 0.43221 seconds with 32 queries
