> 2010 MS3 - How-To's
Like Tree9Likes
 Old 10-28-2013, 09:19 AM   #161
Lancer-AM's Avatar
Posts: 306   (View Stats)
Lancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the worldLancer-AM is the leader of the world
Genjuan and gen2 can both use the straight coupler instead of the 45* coupler. All you need to do is rotate the verticle pipe in line with the turbo outlet pipe. Either way you'll need to remove the tip pipe but then again, it only takes about a minute to do.
So if you can go with the straight coupler, why would you opt for the 45*? Is there any benefit? The straight coupler method looks to be the better way to set it up.
2010 Mazdaspeed 3 Tech
Stocking out
If a person says they 'work smart, not hard,' odds are they are lazy and stupid.
Lancer-AM is offline   Reply With Quote
 Old 10-28-2013, 09:28 AM   #162
El_Diablo's Avatar
Posts: 2,770   (View Stats)
Groans: 769
The 45* coupler comes with the kit. You have to purchase a straight coupler. The benefit would be a more direct shot to the intercooler and slightly shorter plumbing. Not a huge deal but I also prefer how it looks and the access it gives to the dipstick.
 Old 10-28-2013, 09:48 AM   #163
Lancer-AM's Avatar
I think that is the main reason people don't. Looks like the winning option though. That 45* bend was one of the things I was worried about with the kit but if the straight through option is available with an additional coupler, that makes this a pretty good piping option.
Stocking out
 Old 11-03-2013, 09:04 PM   #164
Darthspeed3's Avatar
Posts: 292   (View Stats)
Darthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the worldDarthspeed3 is the leader of the world
thanks to the op and everybody who posted on this one. I wanted to go with CP-E or Cobb for a FMIC but the money is crazy for what you get. I saw the CX setup and it looks like solid piping with a crap core and bpv. Seriously considering the PG piping kit and a good core. Should be a similar outcome for a lot less $$$.
Gen1 - Built and sleeved block, some headwork, Gen2 6266, FJ turbo kit, JMF with PI.
Darthspeed3 is offline   Reply With Quote
 Old 11-04-2013, 04:10 AM   #165
Jonathanhair07's Avatar
Posts: 1,601   (View Stats)
Jonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the worldJonathanhair07 is the leader of the world
Groaned at 8 Times in 4 Posts
lol. the BPV or BOV you get in the cxracing kit isnt all that bad. i ran it for a few months. has a nice sound to it due to the air port thats on the back. only thing is its like a 50/50 BPV. so you will have to be tuned for it or have a GA. i loved it. but i just got a great deal on a greddy, thats why i no longer run it.
2012 Mazdaspeed3
Columbus, Ga
FJ Performance Built Block/GTX3582r
Jonathanhair07 is offline   Reply With Quote
 Old 11-18-2013, 09:29 AM   #166
Hess22's Avatar
Posts: 31   (View Stats)
Hess22 is just really niceHess22 is just really niceHess22 is just really niceHess22 is just really niceHess22 is just really nice
Nice bumper
2013 SILVER PU CS SRI// CS TIP// CS SSP// CXRACING FMIC// Forge BPV// COBB AP// AT Internals// NGK Iridium Plugs// CNT DOWNPIPE// CUSTOM CATBACK// SOME CORN!
Hess22 is offline   Reply With Quote
The Following User Says Thank You to Hess22 For This Useful Post:
JTMS3 (12-13-2013)
 Old 12-12-2013, 05:11 PM   #167
MHHC5280's Avatar
Posts: 55   (View Stats)
MHHC5280 is a glorious beacon of lightMHHC5280 is a glorious beacon of lightMHHC5280 is a glorious beacon of lightMHHC5280 is a glorious beacon of lightMHHC5280 is a glorious beacon of lightMHHC5280 is a glorious beacon of light
Going to be honest with you, I just switched to the CX kit from my CP-E TMIC and I love this thing!
BAT-man likes this.
COBB AP V3, GT3071R,AUTO TECH HPFP, CPE Big Inlet,CPE XcelXL Intake, CNT DOWNPIPE, SWAPPED VVT, JBR 88 DURO , CX FMIC WITH TR8 ,3 Port EBCS JBR 88DURO RMM, JBR PMM
PURPLE DRANK
MHHC5280 is offline   Reply With Quote
The Following User Says Thank You to MHHC5280 For This Useful Post:
BAT-man (12-13-2013)
 Old 12-13-2013, 06:00 AM   #168
BAT-man's Avatar
Posts: 719   (View Stats)
BAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the worldBAT-man is the leader of the world
Groaned at 29 Times in 14 Posts
The "air port" is a fitting that was meant to serve as a potential secondary diaphragm influence, kind of like a two port wastegate. It's it not a 50/50 setup (unless you got a BOV that looks different in the pix I posted in the previous page) because the fitting is barely 1/8" while the actual return port is 1", which would make it 88/12 at best lol. The sound that you hear is not from that fitting, or mostly not from it, because I have it capped off and the sound is still there, it's the air that's rushing past the BOV valve itself. If you have the large port plumbed into the TIP, you wouldn't have to re-tune even if you didn't cap it the 1/8" fitting, but i prefer it capped, for more stable cruise conditions.
I drive fast, I turn fast, I do everything fast. I even breakfast. I tend to confuse people with my sudden changes of heart. Sometimes I even confuse myself, which tends to cause problems.
"... if u can't find' em - grind 'em"
- old Chinese proverb
http://www.mazdamotorsports.com/
BAT-man is offline   Reply With Quote
 Old 12-13-2013, 03:23 PM   #169
i stand corrected. thanks but i didnt really mean that it was a actual 50/50. i thought i was just designed to release some air. i did call cx racing on the right way to run it. they said just leave it as is. but i no longer run it. ended up getting a greddy bov
2012 Mazdaspeed3
Columbus, Ga
 Old 12-14-2013, 11:43 AM   #170
nixon99's Avatar
Posts: 18   (View Stats)
nixon99 will become famous soon enoughnixon99 will become famous soon enough
Good write up
nixon99 is offline   Reply With Quote
The Following User Says Thank You to nixon99 For This Useful Post:
JTMS3 (12-17-2013)
 Old 09-04-2014, 03:44 PM   #171
blake0521's Avatar
Posts: 302   (View Stats)
blake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud ofblake0521 has much to be proud of
Yes I know this thread is old as shit but does anyone know if the stock bpv hose is long enough to work with the cxracing piping kit?
2010 Mazda Speed3-
Mods:
Cobb sri-Cobb tip-Cobb dp-Cobb bvp xle-Cobb ap v3-Cobb shift knob-AutoTech internals-JBR occ stage 2-JBR short shift plate-JBR solid shift bushings-JBR motor mounts (80 rear 70 side)-JBR TruTorsion 125 rear sway bar - JBR FMIC with crash bar and TR8 - Snow Performance meth kit with devils own fuel cell
Next up: tune.
blake0521 is offline   Reply With Quote
 Old 09-04-2014, 04:03 PM   #172
Cevaes_64's Avatar
Posts: 1,066   (View Stats)
It will BARELY reach... Get an aftermarket one
Sent from my SM-N900P using Tapatalk 4
 Old 09-04-2014, 05:12 PM   #173
blake0521's Avatar
Thanks for the tip!
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 09-11-2014, 07:38 AM   #174
creole's Avatar
Posts: 23   (View Stats)
creole has a spectacular aura aboutcreole has a spectacular aura about
If you use the OEM bov on the CX bov flange, it will leak past the two inner bov holes. The oem bov has a large diamond shape seal, which doesnt seal againts the two inner flange bov holes. Epoxy putty the holes or similar if you use the oem bov.
Gen2 | SU Tip+Sri | Autotech | Ghetto TP | ITV22 | CobbAP Stage2 | JBR Trill 80 | MD OCC V1
creole is offline   Reply With Quote
 Old 09-11-2014, 01:38 PM   #175
blake0521's Avatar
What about the cobb bpv?
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 11-04-2014, 09:01 AM   #176
tdement's Avatar
Posts: 103   (View Stats)
tdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud oftdement has much to be proud of
Groaned at 27 Times in 10 Posts
Was looking to install mine last night. Everything looked good, set it up and took off the bumper, until it came to bracing the core. The brace I received makes 0 sense. There are 3 pre-drilled holes on the top/bottom of the core, but the brace does not accommodate ANY of them. It's like this piece was just thrown in there. Am i supposed to use this as scrap and bend my own braces/drill holes?
Just curious if anyone else is having this problem... Something to note that I bought this from a guy on Craigslist, though it seemed to be in the original packaging and pretty much untouched.
tdement is offline   Reply With Quote
 Old 12-16-2014, 02:06 PM   #177
speed3black87's Avatar
Posts: 75   (View Stats)
speed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud ofspeed3black87 has much to be proud of
Groaned at 8 Times in 3 Posts
Is it worth the upgrade from a streetunit top mount to the cx front? I like the idea of having the core at the front of the car but feel I would have a better quality core with the streetunit on top. Also, with the GEN 2, has anyone modified the grill so the intercooler is easier to see. I would want to show that shit off.
2012 MAZDASPEED 3 BLACK MICA -COBB SRI - COBB TIP - STEBRO CBE -ULTIMATE RACING CATLESS DOWNPIPE- STREET UNIT TEST PIPE -AUTOTECH INTERNALS - STREET UNIT TMIC - CORKSPORT TRUNK BRACE- STREET UNIT RMM (BROKE) JBR 88A RMM - CPE PASSENGER MOUNT - CPE TRANSMISSION MOUNT -COBB ACCESSPORT -SNOW PERFORMANCE STAGE 2 BOOST METH INJECTION KIT- DAMOND OCC -XXR 531 18X9 HYPER SILVER 235/40/18 GFORCE TIRES- PIRRELI PZERO RACING SLICKS ON OEM RX8 R3 RIMS- KSPORT SPEC AR COILOVERS - TURBO SMART BPV-DENSO ITV22'S
STRATIFIED TUNE BY LEX
speed3black87 is offline   Reply With Quote
 Old 12-16-2014, 03:57 PM   #178
g00s3y's Avatar
Posts: 2,127   (View Stats)
Groans: 438
Yes, many people have modified the smile, search around and you will find many pics.
 Old 12-16-2014, 04:11 PM   #179
blake0521's Avatar
Save your self some time and get a nice fmic if you go that route. I am already upgrading my set up after having it for 2 k miles because it won't support my power goals. Spend the money once so you don't waste money twice.
2010 Mazda Speed3-
Mods:
Next up: tune.
The Following User Says Thank You to blake0521 For This Useful Post:
speed3black87 (12-16-2014)
 Old 12-16-2014, 04:23 PM   #180
ASHMS3's Avatar
Posts: 1,362   (View Stats)
Groans: 126
There are nicer options out there, but you can pair cx piping with a treadstone core for about half of what those nicer kits cost.
Using bad grammar from my cell phone.
 Old 12-16-2014, 04:51 PM   #181
The CX racing supports upto 400 ponies does it not? I would be happy to be anywhere near that ( planning on staying k04 ) I just find on the hot days the top mount really shows it's faults. Seeing the price point on the CX racing it's a bargain if it will out perform my current set up. Plus it cleans up the engine bay nicely. Fuck it, I will order it up. I can always snag a tr8 core in the future.
 Old 12-16-2014, 05:54 PM   #182
blake0521's Avatar
I am moving from the tr6 with cx piping to jbr piping and a tr8l because my build should be around 500 plus whp with the pte5858. If you are stock block even if you go bt the tr6 should work. It's rated at 400 hp which IMO is a lot on a stock block. Then again I have only been in the game for a bit.
2010 Mazda Speed3-
Mods:
Next up: tune.
 Old 12-17-2014, 04:06 AM   #183
ASHMS3's Avatar
Groans: 126
Stock block will hold 400, you just have to keep the torque at bay in the low to midrange. Its all in the tune.
The Following User Says Thank You to ASHMS3 For This Useful Post:
Drive By Fire (12-17-2014)
 Old 04-21-2015, 02:43 PM   #184
Fosy's Avatar
Posts: 37   (View Stats)
Fosy has a spectacular aura aboutFosy has a spectacular aura aboutFosy has a spectacular aura about
@OP
Hey man, I noticed your couplers and clamps are not the ones provided with the CX kit. Could you please provide the sizes for these? The ones I got with my CX kit are terrible and i'm leaking boost ><
Fosy is offline   Reply With Quote
 Old 03-03-2016, 10:15 PM   #185
hugeyetti's Avatar
Posts: 38   (View Stats)
hugeyetti is an unknown quantity at this point
Sorry in advance for the reincarnation of the post lol. Great writeup! helped me install my fmic! But did anyone else not be able to put the plastic undershield that goes directly under the fmic back on? The main one is on, but the front "lip" one does not fit anymore. Is this just me, or is this normal?
hugeyetti is offline   Reply With Quote
 Old 03-13-2016, 11:41 PM   #186
2010ms4-1's Avatar
Posts: 2   (View Stats)
2010ms4-1 is an unknown quantity at this point
@JTMS3;
I used your write up for my install and went great! thank you
@BAT-man;
the pictures you have posted with your write up were not available. was wondering if you had them somewhere else?
2010ms4-1 is offline   Reply With Quote
 Old 05-17-2016, 05:38 PM   #187
Breezynator's Avatar
Posts: 10   (View Stats)
Breezynator is an unknown quantity at this point
Originally Posted by 2010ms4-1 View Post
@JTMS3;
@BAT-man;
How are you liking it so far? I'm considering when the time comes going FMIC.
Breezynator is offline   Reply With Quote
 Old 05-22-2016, 10:01 PM   #188
2010ms4-1's Avatar
it's not too bad but recently my car at 77k fell victim to the smoking turbo fad. before this though it seemed to help BATS pretty good.
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/cx-racing-front-mount-intercooler-install-81388/
Mega "How to" thread for genpu speed3s! - Mazda3 Forums : The #1 Mazda 3 Forum This thread Refback 06-03-2014 12:34 AM
xenon bulb replacement This thread Pingback 01-13-2014 06:20 PM
Cx Racing FMIC BlackedOutSpeed6 MazdaSpeed 3/6 - Turbo Induction 17 06-16-2011 07:30 PM
CX Racing FMIC Test CX Racing 2010 MS3 - Turbo Induction 20 04-05-2011 08:09 AM
Another WOT run after FMIC install llescaflownell
Cobb ATR Support
14 07-14-2010 08:33 PM
Page generated in 0.48374 seconds with 39 queries
