> 2010 MS3 - How-To's
Like Tree35Likes
 Old 01-23-2012, 05:24 AM   #241
wolly6973's Avatar
Posts: 2,364   (View Stats)
Groans: 386
Not sure what the OTS maps command for fp for stage 1, but that may be all that is requested.
Also, cpe pumps tend to run closer to stock pressures than autotech & kmd.
Try upping the boost and increasing fp and see if you are still holding pressure. Do these in separate map revisions though, so you will know what pushes it over the limit.
 Old 02-02-2012, 01:29 AM   #242
sstevens805's Avatar
Posts: 194   (View Stats)
sstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the worldsstevens805 is the leader of the world
Just finished my install and saw a high pressure of 1777, not even WOT. Better already. Thanks for the instructions. You saved my ass.
sstevens805 is offline   Reply With Quote
The Following User Says Thank You to sstevens805 For This Useful Post:
rghispanic88 (02-07-2012)
 Old 02-02-2012, 07:33 AM   #243
mre
mre's Avatar
Posts: 50   (View Stats)
mre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of lightmre is a glorious beacon of light
installed my autotech internals this past weekend. Only a few busted knucles...the blue fuel line clip is not much fun. Great preasure, saw over 2000 when logging at wot. Instead of a zip tie on the fuel line, I used a wooden clothes pin that was installed with a pair of needle nose pliers....easy on and off and did the job of a ziptie.
11 ms3 lsm, cobb stage 2, rmm, sri, tih, fp internals, tmic, shifter bushings, test pipe, rear sway, DGauge, child seat.
Check out my track videos in the ms3 on my youtube channel meggerthree
mre is offline   Reply With Quote
The Following User Says Thank You to mre For This Useful Post:
 Old 02-06-2012, 12:12 PM   #244
TheRealDefman's Avatar
Posts: 532   (View Stats)
TheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the worldTheRealDefman is the leader of the world
A note to say thanks for this, it helped me thru it just a couple of hours ago. A couple of thoughts to add:
1. Before you undo the fuel line on the bottom put on some safety glasses, there may still be some pressure and a little gas may spray out... right in your eye. Don't count on reflexes!!
2. When putting the pump back on, keep an eye on the alignment of the bottom fuel line and when it's lined up go ahead and loosely connect it. I had to back my pump out about 1/4 inch to get it back on, that metal line does move much or easily.
3. I wiped down my workbench with a wet rag to clean it, and I used a glass dish (like a Pyrex cooking dish) to put the parts in... clean, non-absorbent, sides so parts don't roll off, etc... just clean it when you're done and don't tell the old lady what you did with it.
2012 Black Mica with Tech package.
Chock full of goodies and Dizzy tuned
TheRealDefman is offline   Reply With Quote
The Following 4 Users Say Thank You to TheRealDefman For This Useful Post:
DingoDave (03-14-2012), rghispanic88 (02-07-2012), TriO (02-07-2012), zpele (02-10-2012)
 Old 02-07-2012, 07:20 AM   #245
rghispanic88's Avatar
Posts: 3,131   (View Stats)
Groans: 263
your car squirted on your face. lol
2010 Black Mica
rghispanic88 is offline   Reply With Quote
The Following 4 Users Say Thank You to rghispanic88 For This Useful Post:
iggy097 (02-10-2012), TriO (02-07-2012), Weazsel (07-01-2012), zpele (02-10-2012)
 Old 02-07-2012, 08:08 AM   #246
TriO's Avatar
Posts: 676   (View Stats)
TriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the worldTriO is the leader of the world
Number 2 for sure... This was prob the most annoying part of the install for me. Had to back mine out about 3 times just so it would seat properly.
TriO is offline   Reply With Quote
 Old 02-08-2012, 11:20 AM   #247
captain slow's Avatar
Posts: 5,559   (View Stats)
Groans: 398
Ordered my Autotechs last night. I am terrified of doing this install after all the fail threads. I'll be keeping several of these how to's open.
 Old 02-08-2012, 11:59 AM   #248
bigriver's Avatar
Posts: 1,123   (View Stats)
bigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the worldbigriver is the leader of the world
Just free up as much space as you can and take your time. I took off intake and tip so i could see the hard fuel line because that gave me the most difficulty since it was just a hair too high to reinstall the pump. Start in the morning when engine is cold and minimal fuel in the lines. Dont need to pull the fuse. I kept a rag underneath to catch excess fuel, which wasnt very much. Have jp's phone number handy, lol.
2012 mazdaspeed 3, black mica w/ tech package, AFE drop in dry filter, Autotech internals and CS rmm inserts. .
bigriver is offline   Reply With Quote
 Old 02-08-2012, 12:53 PM   #249
Pedal-Force's Avatar
Posts: 419   (View Stats)
Pedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the worldPedal-Force is the leader of the world
I wouldn't recommend not pulling the fuse. You don't know how much pressure might still be in there. Just 1000 psi is enough to cause serious problems by injection under the skin. It takes an extra few seconds, not worth skipping.
Sent from my DROIDX using Tapatalk
2010 MS3 - Liquid Silver - tech package, Nav, Bose - Cobb AP - HPFP from HPFPUpgrades - JBR Cro-Mo Dogbone RMM - JBR SSP and solid bushings - tinted windows - Ultragauge - CS SRI/TIP - Super duper tranny fluid - Denso ITV22 plugs.
wish list - Catted DP, EGR block off, intake and throttle thermal gaskets, OCC, throttle coolant bypass
maybe list - BSD, top or front IC, cat back exhaust
2010 CX-7 Grand Touring - Silver - Fiance's car (owned by me though).
Pedal-Force is offline   Reply With Quote
 Old 02-08-2012, 04:21 PM   #250
bigriver's Avatar
Not sure how you get 1000 psi from a cold engine that has intake and tip removed and no power. Seems like pulling the fuse is unnecessay.
If I'm wrong, I'd like to buy a pump that can do that.
@freundb - be sure to wear safety glasses.
 Old 02-09-2012, 08:39 AM   #251
If you don't have a leak then the pressure doesn't go down much after shutting the car off, even after hours. At least from what I've seen on the gauge.
 Old 02-09-2012, 08:58 AM   #252
wolly6973's Avatar
Groans: 386
If you let it sit all night it does. I have done fp after sitting overnight and sitting for an hour, and there is a huge difference. No worries about stuff spraying out at you if it sits overnight.
The Following User Says Thank You to wolly6973 For This Useful Post:
rfinkle2 (02-09-2012)
 Old 02-10-2012, 08:29 PM   #253
DingoDave's Avatar
Posts: 764   (View Stats)
DingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the worldDingoDave is the leader of the world
Groans: 43
Groaned at 8 Times in 4 Posts
Same results here as well.. Overnight.. no problems.. Car sitting for an hour and half gets you some decent fuel spillage but only from the yellow connector fuel line. The low pressure one coming from the tank. Didn't have any problems with the high pressure metal line or the blue connector fuel return line. (granted I took off the yellow line first.. .then the blue line.. then the metal line)
Demo likes this.
2013 Black Mica Mazdaspeed 3 - Current daily
2006 WWP Mazdaspeed 6 - Soon to be daily
2006 BCM Mazdaspeed 6 - Project
Tuned with by
DingoDave is offline   Reply With Quote
 Old 02-11-2012, 08:43 PM   #254
MSPEED's Avatar
Posts: 26   (View Stats)
MSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud ofMSPEED has much to be proud of
Here's a video of me and a couple guys installing internals on Pauls GenWon
MazdaSpeed Fuel Pump - YouTube
[SIGPIC]http://graphicriver.net?ref=ClaytonAllen[/SIGPIC]
MSPEED is offline   Reply With Quote
The Following 3 Users Say Thank You to MSPEED For This Useful Post:
adrager622 (02-13-2012), Bubba Ho-Tep (03-24-2012), mituc (02-12-2012)
 Old 02-11-2012, 11:44 PM   #255
Dmurray06's Avatar
Posts: 3,279   (View Stats)
thats a good video..."like throwing a hotdog down a hallway" i almost fell off my chair, haha.
Last edited by Dmurray06; 02-11-2012 at 11:45 PM. Reason: MSF Database - Automerged Doublepost
 Old 02-13-2012, 12:01 PM   #256
adrager622's Avatar
Posts: 745   (View Stats)
adrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the worldadrager622 is the leader of the world
Groans: 46
Awesome video! This should be added to the first post, along with the walk-through. Removing the pump is easy, but this visual aid to walk you through the internal install is great. This will really help when I tackle this project in the spring. I love the reaction when the stock internals come out. "Is that the pain in ther ass one?" "yes" "That's it?!?"
2010 MS3 Black Mica
-JBR RSB, JBR Boost Tubes and BPV hose, JBR 80a RMM, CP-e Nano SRI, 6000K HIDs
adrager622 is offline   Reply With Quote
 Old 02-14-2012, 05:55 PM   #257
Groans: 398
Got my Autotechs, read the instructions and watched the video. In most how tos that steel fuel line on the bottom is to be undone while the fitting on the pump is to not move. According to the video and instructions you remove the fitting anyway.
Also, is it really necessary to do all of that? Or can I just do the internals?
 Old 02-14-2012, 05:58 PM   #258
Nliiitend1's Avatar
Posts: 5,749   (View Stats)
I'm unsure of what exactly you're asking...
Yes, the pump must be removed completely to swap out the internals (meaning that removing all of the fuel lines from the pump is indeed necessary).
Stance is not a verb.
2008 MS3 GT
2016 MX-5 Club
 Old 02-14-2012, 06:05 PM   #259
bigriver's Avatar
You disconnect the pump from the hard line. Not really necessary to disasemble and clean the entire pump unless you think its that dirty. I just swapped the internals.
 Old 02-14-2012, 07:26 PM   #260
Groans: 398
Yeah, sorry. My post was kind of confusing. Basically, the video posted above shows the guys taking apart the entire pump. They removed the piston, spring, retainer but also took out the pressure relief valve, the fuel line fitting and the pump cover and all the stuff inside. I was wondering if that's all necessary. I just figured I'd do the internals cleaning the threaded cylinder that goes over the piston.
 Old 02-14-2012, 08:59 PM   #261
Nliiitend1's Avatar
Ah, gotcha. That makes sense. I hadn't watched the video...
2008 MS3 GT
2016 MX-5 Club
 Old 03-02-2012, 12:33 PM   #262
b1iNkl82's Avatar
Posts: 39   (View Stats)
b1iNkl82 is a splendid one to beholdb1iNkl82 is a splendid one to beholdb1iNkl82 is a splendid one to beholdb1iNkl82 is a splendid one to beholdb1iNkl82 is a splendid one to beholdb1iNkl82 is a splendid one to behold
This is a great thread. I'm getting my internals soon and this will def help.
Can someone clean this thread up and add/edit the first post to include some of the additional thoughts?
2011 MS3 Black Mica w/ Tech Pkg
Stage 1+SRI+TIP COBB AP Tuned, SURE Torq R3, SURE Aeros, SURE Countershift, SU/TS Dual BOV, SURE Return, SURE ShortCut, SURE Anchors, SURE Sidewinder, SURE Flow M3
Rally Armor Mud Flaps, SURE TVS Caps, SU Front Blacked Out Emblem, Blood red rear "Evil" M, rest is debadged.
b1iNkl82 is offline   Reply With Quote
 Old 03-02-2012, 03:22 PM   #263
sveli's Avatar
sveli will become famous soon enoughsveli will become famous soon enough
Default Blue and Yellow connector
Is this the instruction for removal of the blue connector?
and this for the yellow?
2010 MPS (European Mazdaspeed 3) Pearl White
sveli is offline   Reply With Quote
The Following User Says Thank You to sveli For This Useful Post:
rghispanic88 (03-02-2012)
 Old 03-02-2012, 06:16 PM   #264
DingoDave's Avatar
Groans: 43
Looks right to me
Tuned with by
 Old 03-02-2012, 06:47 PM   #265
Groans: 263
yes sir
2010 Black Mica
 Old 03-02-2012, 10:50 PM   #266
bigriver's Avatar
Ya just be careful with the yellow clip and dont let it fall off into no mans land. The blue clip does not have to come off completely. It can be halfway off.
 Old 03-06-2012, 12:17 PM   #267
Jhornbrook's Avatar
Posts: 708   (View Stats)
Jhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the worldJhornbrook is the leader of the world
Groaned at 6 Times in 4 Posts
Alright I just did my install went well took me 2 hours took my time had a few assholes around telling me to not fuck shit up. Any way after I primed a few times I started the car obviously it was a rough start up but when I gave it a little gas I saw that my fuel pressure would hang at like 1600 until the rpm went back down. Is the hanging pressure normal. I read most of the thread and didn't see a answer to the hanging pressure. Is it normal?
Ultimate Racing // testpipe, catback // TWM // Full Replacement Shifter, Short Shift Boot // Cobb// AP // Sure aeros, sidewinder, shortcut, ags SS knob, return, chargetubes, countershift // Corksport // License Plate Relocate, Fog Light LED's, Interior LED's, Poly Exhaust Hangers, Oil Catch Can // PTP// HPFP Upgrade, 2150 rail valve // H&R // SS Coilovers // SPC// Adjustable Camber Arms // Hawk// HPS Brake Pads // Ebay Chargespeed Lip 06-07 STI Lip // DDM 8K 55W HIDs // JBR// Rear Sway Bar, 88D RMM, AP Mount //WHITELINE// Front End Links // ETS// TMIC//
Jhornbrook is offline   Reply With Quote
 Old 03-06-2012, 01:00 PM   #268
Groans: 263
yes thats normal. but there is no designated fuel pressure when just "giving it some gas" only idle and WOT i believe.
2010 Black Mica
 Old 03-08-2012, 07:14 PM   #269
Boatcop1's Avatar
Posts: 256   (View Stats)
Boatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the worldBoatcop1 is the leader of the world
Still have not found an answer to this? Is it mandatory to take the whole pump apart or are we just doing the internal swap? I will be attempting in a few weeks. Just curious.
Boatcop1 is offline   Reply With Quote
 Old 03-08-2012, 07:36 PM   #270
foodtime's Avatar
Posts: 225   (View Stats)
Whole pump does not need to be disassembled. Remove bolt, unthighten BIG nut, thread in autotech or KMD bolt internals with spring and "hat", tightend down BIG nut, then done!
Boatcop1 likes this.
The Following User Says Thank You to foodtime For This Useful Post:
b1iNkl82 (03-08-2012)
 Old 03-08-2012, 08:46 PM   #271
Groans: 398
Read foodtime. Just do the install of internals. Do everything if u want but its not necessary. If u plan on running e85 u might want to. That's a whole different discussion tho.
 Old 03-08-2012, 08:59 PM   #272
Boatcop1's Avatar
Saweet, thanks bro. Although corn is starting to make its way to my neck of the woods I dont see me making the switch.
 Old 03-10-2012, 10:38 PM   #273
gpower07's Avatar
Posts: 162   (View Stats)
gpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of lightgpower07 is a glorious beacon of light
shit...today i did my autotech internal...but i didn't lop with motor oil on the piston and spring....am i going ok? i already start the car...warm up for 30 min. and drove for half mile!!!!!
gpower07 is offline   Reply With Quote
 Old 03-10-2012, 10:41 PM   #274
Spoofmastafly's Avatar
Posts: 1,444   (View Stats)
Seriously? You didn't think to put oil on the internals? Do you have any way to monitor them? I would take the pump apart and put a lite coating of engine oil on them.
 Old 03-10-2012, 11:56 PM   #275
gpower07's Avatar
i have a AP. everything looks good. idle at 420-450psi. pressure built up quick(2k-3k rpm around 1600PSI. never try WOT.
 Old 03-11-2012, 03:24 PM   #276
gpower07's Avatar
should i take it out and redo it again?
 Old 03-11-2012, 04:58 PM   #277
Don't bother. You've already driven it. It's oiled now. The reason you oil it yourself is because otherwise it's dry for the first few revolutions. If it was gonna get damaged, it's already done, no need to to redo it. You'll find out eventually.
The Following User Says Thank You to Pedal-Force For This Useful Post:
 Old 03-14-2012, 12:22 AM   #278
gpower07's Avatar
i dipped the piston with the O ring into gasoline. will that kill the O ring? if so. i can take it out and redo everything again.
 Old 03-14-2012, 12:27 AM   #279
850wagonT5's Avatar
Posts: 40   (View Stats)
850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of850wagonT5 has much to be proud of
This may be a stupid question, but...what's the reason for upgrading the internals as opposed to just getting a whole new higher flow pump??
850wagonT5 is offline   Reply With Quote
 Old 03-14-2012, 12:50 AM   #280
Groans: 263
The pump that is replaced is not in the gas tank, its the one on top of the motor (somewhat).
There are no other "higher flow pumps" per say, Like Cp-e all they do is replace the internals themselves, test it and then sell it for a ridiculous price along with a warranty.
internals work just as well as a new pump which in essence is the same pump with new internals.
2010 Black Mica
LinkBack to this Thread: http://www.mazdaspeedforum.org/forum/forum/f429/fuel-pump-internals-install-76252/
HPFP fitting ? Mazda MPS Owners Club This thread Refback 05-09-2015 01:43 PM
Fuel Pump internals Install! - Mazdaspeed Forums This thread Refback 01-17-2015 03:58 AM
? Bekijk onderwerp - Insane J - Mazda 3 MPS - Fuelpump upgrade, Autotech besteld. This thread Refback 10-14-2014 05:56 PM
russiakansk air base 76252 This thread Refback 07-29-2014 09:34 PM
Anleitung: HPFP Internals tauschen This thread Refback 03-05-2014 08:09 AM
How-To 's und Nützliches - [ALLE] HPFP Internals tauschen This thread Refback 02-22-2014 10:06 AM
overview for azarashi This thread Refback 11-27-2013 04:51 PM
Picked this up yesterday. My new 2013 Mazda Speed3, fully loaded. Couldn't be happier. : mazda This thread Refback 11-25-2013 01:30 PM
mikey32235's ride thread - Page 2 This thread Refback 11-13-2013 04:56 AM
What am i missing? Stage2 OTS - Page 3 This thread Pingback 09-02-2013 08:52 AM
Need help on internal retainer - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 06-29-2013 08:52 AM
fuel pump internals install help - Houston-Imports.com This thread Refback 06-28-2013 11:35 AM
2010-13 Mazda 3/Mazdaspeed 3 Forums - View Single Post - Hybrid blow off valve, opinions! This thread Refback 06-11-2013 04:04 PM
CPE Fuel Pump Mazdaspeed 3 - Reverse Lookup Directory This thread Refback 05-19-2013 03:52 PM
MAZDA FRENCH CLUB - ?????????? ? Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 05-18-2013 02:44 AM
Hybrid blow off valve, opinions! - Page 5 - 2010-13 Mazda 3/Mazdaspeed 3 Forums This thread Pingback 05-13-2013 05:43 AM
Autotech Install Help? This thread Refback 01-04-2013 05:14 PM
Testbericht vom Hypertech für den Mazda 3 MPS BL - Seite 21 This thread Refback 12-18-2012 03:27 AM
mikey32235 everything is broken - Page 2 This thread Refback 12-01-2012 10:42 AM
mikey32235 everything is broken help me thread. - Page 2 This thread Refback 11-24-2012 11:04 AM
Fuel pump?? This thread Refback 11-22-2012 03:45 PM
Random MS3 Chat Thread - Page 131 This thread Refback 11-07-2012 12:56 PM
HPFP fitting • Mazda MPS Owners Club This thread Refback 11-06-2012 04:34 PM
HPFP fitting • Mazda MPS Owners Club This thread Refback 10-10-2012 12:29 PM
Mazda MPS Owners Club • View topic - GroupBuy 2nd Chance! AutoTech HPFP Internals - $375 - Round2 This thread Refback 08-23-2012 09:40 AM
Testbericht vom Hypertech fr den Mazda 3 MPS BL - Seite 21 This thread Refback 06-17-2012 02:17 PM
Mazda MPS Owners Club • View topic - Group Buy: AutoTech HPFP Uprated Internals - updated - £245 This thread Refback 06-12-2012 01:35 PM
Austausch Krst.-Hochdruckpumpe - Seite 7 This thread Refback 06-12-2012 05:39 AM
Free PSP ISO Downloads EUR PSP ISO & CSO Downloads This thread Refback 05-02-2012 07:56 AM
Ou acheter des internes pour la HPFP - Mazda 3 Quebec This thread Refback 04-18-2012 04:12 PM
Austausch Krst.-Hochdruckpumpe This thread Refback 04-05-2012 11:56 AM
Mazda MPS Owners Club • View topic - HPFP fitting This thread Refback 02-19-2012 11:24 AM
Testbericht vom Hypertech fr den Mazda 3 MPS BL This thread Refback 02-18-2012 06:50 AM
MAZDA FRENCH CLUB - ?????????? • Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 01-28-2012 04:00 AM
NATOR TO unite! dp install anyone? This thread Refback 01-24-2012 09:49 AM
upgraded fuel pump internals This thread Refback 01-08-2012 10:34 PM
MAZDA FRENCH CLUB • Afficher le sujet - [Japanas] Mazda 3 MPS Gen.2 This thread Refback 08-27-2011 05:35 AM
KMD V2.1 Fuel Pump Internals AllLostThings MazdaSpeed 3 - Engine, Transmission & Driveline 9 05-23-2010 12:04 PM
oil in engine bay after pump internals install Realgib3 MazdaSpeed 3/6 - Troubleshoot/Diagnostics 2 07-24-2009 05:04 PM
Fuel pump internals cgburton12 MazdaSpeed 3/6 - Fuel, Nitrous & Water Injection 43 08-11-2008 01:29 PM
Page generated in 0.59853 seconds with 42 queries
