> 2010 MS3 - How-To's
Like Tree11Likes
  • 9 Post By dooderek
  • 1 Post By Raider
  • 1 Post By msantana101
 Old 03-29-2012, 04:34 PM   #1
2zz mr-s
dooderek's Avatar
Posts: 5,119   (View Stats)
Groans: 239
Default gen pu how to sticky thread
post up all the diy's you guys got and ill compile a how to sticky for you pu owners, let me know if i missed any
(after i get enough threads ill make everything look pretty)
engine
CX Racing FMIC install
SWAS - DISCONNECT ON A GEN2
Fuel Pump internals Install!
How-To: Gen2 mani install V2
Balance Shaft Delete and Baffle Kit GEN 2
How to: Install a switch for SWAS enable/disable
CP-e SRI + TIP Install
CNT DP Install Supplement DIY
cp-e FMIC Install
How-to: CP-E XcelNano Short Ram Intake
How to: Change Power Steering Fluid
suspension
H&R SPRINGS INSTALL
interior
How To Cure Your Doors of ChixPox
Shift Knob Threaded Insert Install DIY
Shift Anchor installation
http://www.mazdaspeedforum.org/forum/foru...into-pu-194037
exterior
HOW-TO independent fogs
DDM HID Kit
HOW-TO Turn fogs on without headlights and adjust aim
http://www.mazdaspeedforum.org/forum/foru...-speed-106944/
How To: Rear Wiper Delete (Detailed Version)
other
DIY Headrest Camera mount. ( GoPro2 )
Bluetooth Setup on your Speed
How To: Paint your Stock Rims
http://www.mazdaspeedforum.org/forum/foru...ir-kit-105601/
http://www.mazdaspeedforum.org/forum/foru...-angel-109332/
The Following 26 Users Say Thank You to dooderek For This Useful Post:
3wheeln (09-02-2014), adlpb (04-02-2012), ASHMS3 (03-30-2012), Awesomesauce (07-02-2012), castrocastro (03-29-2012), curving_edge (05-31-2014), Deslin (03-30-2012), dizzydtrain (03-30-2012), Dmurray06 (07-01-2012), evolizzee (03-27-2013), fishin53 (03-30-2012), Grikathehun (04-27-2012), JTMS3 (03-29-2012), makjur (05-01-2012), Mauro_Penguin (10-08-2013), melbaro (04-07-2012), Raider (03-30-2012), rfinkle2 (03-30-2012), Scoobs (03-30-2012), shaftyella (03-30-2012), Skunky82 (08-24-2013), SLOWHATCH (04-07-2012), TexasSpeed3 (03-30-2012), trf5000 (03-30-2012), VulgarKyle (02-18-2013), Wicked (11-22-2012)
 Old 03-29-2012, 04:36 PM   #2
UnknownSuperhero's Avatar
Posts: 2,462   (View Stats)
I came in here expecting some bashing. You are getting soft.
 Old 03-29-2012, 04:48 PM   #3
helmetface's Avatar
Posts: 5,685   (View Stats)
Groans: 219
HOW TO: Get Beat by a Sexier GenWON
 Old 03-30-2012, 06:55 AM   #4
Vinnie's Avatar
Posts: 714   (View Stats)
Vinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the worldVinnie is the leader of the world
Groans: 76
i know there's a how to: chargespeed lip floating around here somewhere... gimme a few minutes.
edit: http://www.mazdaspeedforum.org/forum/foru...-speed-106944/
'12 speed 3 CWP w/tech: DIZZY Tuned by Phate!,cobb AP,Autotech internals, cp-e nano, cp-e TIP, JBR 88 dogbone, JBR SSP/bushings, JBR rear sway bar, UR test pipe
RIP '08 speed 3 silver cp-e 75 duro RMM, cp-e intake, cp-e TIP, Jbarone SSP and bushings.
Vinnie is offline   Reply With Quote
 Old 03-30-2012, 07:33 AM   #5
So....does this mean I need to give you MSF bucks?
 Old 03-30-2012, 07:38 AM   #6
lilred's Avatar
Posts: 5,792   (View Stats)
I'm new and even I expected bashing lol
2010 velocity red mica ms3
AP/AT internals
JBR SSP/bushings
JBR RMM
JBR stage 2 OCC
CS test pipe
 Old 03-30-2012, 08:52 AM   #7
adlpb's Avatar
Posts: 6,998   (View Stats)
Groans: 669
My contribution:
cp-e FMIC Install
 Old 03-30-2012, 07:31 PM   #8
2zz mr-s
dooderek's Avatar
Groans: 239
thanks guys keep em coming
 Old 04-07-2012, 04:51 PM   #9
2zz mr-s
dooderek's Avatar
Groans: 239
bumpin to sticky
 Old 06-22-2012, 04:18 PM   #10
Aaron_Speed3's Avatar
Posts: 128   (View Stats)
Aaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant futureAaron_Speed3 has a brilliant future
any1 any how-to on a clutch install on the GenPu yet?
2011 Mazdaspeed 3: Totaled
Aaron_Speed3 is offline   Reply With Quote
 Old 07-01-2012, 11:36 AM   #11
bump for this question =]
 Old 07-01-2012, 12:09 PM   #12
It's prolly really close To the genwon thread. It's in VIP.
Aaron_Speed3 likes this.
ASHMS3 (07-01-2012)
 Old 07-01-2012, 12:30 PM   #13
aggierandy's Avatar
Posts: 2,241   (View Stats)
aggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the worldaggierandy is the leader of the world
Groaned at 18 Times in 14 Posts
Not much but you could add this one:
Sent from my DROIDX
2010 MS3 Mica Black Tech
Cobb AP | JBR RMM 70 Duro | JBR SSP | CS SRI+TIP | CS Racepipe | NGK Plugs | KMD Internals
CS Interior LEDs | Custom Hatch LEDs | Rear Wiper Delete | Custom "Evil M" | Red Taillights | Resonator Delete | SWAS Switch
aggierandy is offline   Reply With Quote
 Old 07-02-2012, 12:29 PM   #14
thanks bud
 Old 06-30-2013, 03:36 PM   #15
FrewBrew's Avatar
Posts: 72   (View Stats)
FrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond reputeFrewBrew has a reputation beyond repute
Just created this today - I searched high and low and couldn't find anything for the Gen2.
How To: Wire V1 to switched power
Former:
'96 Mazda MX-6 2.slow - idiot College driver mod; sexy paint
'01 VW GTI VR6 - sound, exhaust, swaybar, DD
Current:
'13 White PU - JBR RMM, RSB, APv2, CS SRI and TIP
Grocery Getter '11 Subaru Forester
FrewBrew is offline   Reply With Quote
 Old 10-08-2013, 02:39 PM   #16
RallySportDirect's Avatar
Posts: 1,452   (View Stats)
RallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the worldRallySportDirect is the leader of the world
How-to: Install Rear Adjustable Camber Arms - Eibach
How-to: Transmission magnetic drain plug and fluid change
How-to: Install your Autotech fuel pump internals
How-to: Cobb Shifter Weight
How-to: Whiteline Front and Rear Sway Bar Installation
How-to: Oil Change
How-to: CP-E Stage 2 Rear Motor Mount
How-to: Pedders Extreme XA Coilovers
How-to: AccessPort Flash
How-to: Install TurboSmart Dual Port BOV
How-to: Install CP-E Turbo Inlet Hose
How-to: Install CP-E Triton Dual Cat-Back
Last edited by RallySportDirect; 10-08-2013 at 02:53 PM. Reason: MSF Database - Automerged Doublepost
RallySportDirect is offline   Reply With Quote
The Following 5 Users Say Thank You to RallySportDirect For This Useful Post:
adlpb (10-08-2013), aromig (10-04-2014), liljae8 (07-25-2015), Mauro_Penguin (10-08-2013), msantana101 (10-08-2013)
 Old 10-08-2013, 02:56 PM   #17
msantana101's Avatar
Posts: 1,517   (View Stats)
Thanks for all the how-to posts Tanner.
Sent from my iPhone using Tapatalk - now Free
RallySportDirect likes this.
FreekTuned
RallySportDirect (10-08-2013)
 Old 11-04-2013, 02:51 PM   #18
How-to: Rally Armor Mudflap Installation
 Old 11-12-2013, 04:51 PM   #19
How-to: JBR Shift Knob Installation
 Old 11-19-2013, 04:47 PM   #20
How-to: Install JBR Short Shift Plate Kit
 Old 11-19-2013, 06:24 PM   #21
How-to: JBR Solid Shifter Bushings
 Old 11-20-2013, 05:32 PM   #22
How-to: Install JBR Intercooler Boost Tubes
 Old 12-15-2013, 04:46 AM   #23
How-to: Install Eibach Pro-Kit Lowering Springs
 Old 01-02-2014, 08:15 AM   #24
How-to: Install JBR Passenger Side Motor Mount
 Old 01-02-2014, 05:21 PM   #25
How-to: Install JBR Tranmission Side Motor Mount
 Old 10-07-2015, 07:40 AM   #26
Added HOW TO: Swap gen1 seats into a pu - Mazdaspeed Forums
This thread probably needs more linked, so post em up.
aromig (10-08-2015)
Why no Sticky for Coilovers yet? Scoobs 2010 MS3 - Suspension & Brakes 9 04-02-2012 06:20 AM
Sticky Shifting into and out of third redmnsterut MazdaSpeed 3 - Engine, Transmission & Driveline 9 08-23-2011 02:24 PM
sticky suggestion thread (gen2) rfinkle2 2010 MS3 - How-To's 5 03-15-2011 10:31 PM
TSB and recall Sticky? Jesse MS3GT Website Help/Feedback 8 09-17-2008 05:49 PM
Page generated in 0.47606 seconds with 31 queries
