> 2010 MS3 - How-To's
 Old 10-04-2015, 01:09 PM   #1
Spyder91290's Avatar
Posts: 11   (View Stats)
Spyder91290 will become famous soon enoughSpyder91290 will become famous soon enough
Default Grimmspeed EBCS
Hey all,
I realize this may be a dumb ass question, but Grimmspeed instructions are shit for this. I recently upgraded to a bnr s3. I hooked up the ebcs but my tuner is telling me that I have an issue. After talking to a few people, I'm thinking I have 2 of my ports switched up. Could someone tell me what port should go to what?
Thanks!
Daniel
Spyder91290 is offline   Reply With Quote
The Following User Says Thank You to Spyder91290 For This Useful Post:
Whitebullet (03-17-2019)
 Old 10-04-2015, 05:25 PM   #2
tparker14's Avatar
Posts: 180   (View Stats)
tparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond reputetparker14 has a reputation beyond repute
Are you trying to run 2 port or 3?
13 Speed3 ~ CWP ~ FREEKTUNE
AP v2 ~ JBR 3" ~ Swift Springs ~ Lenso GT-05 18x8.5 ~ Autotech HPFP ~ M2 DP ~ DO Stage 2 ~ CX Racing/TR8 ~ Custom CB ~ Saikou Michi OCC ~ JBR EGR delete ~ Damond RMM ~ CX Piping/TR8 ~ TWM heavy knob
07 Speed3 ~ CWP (rekt)
tparker14 is offline   Reply With Quote
 Old 10-04-2015, 05:37 PM   #3
3 port.
 Old 10-04-2015, 05:48 PM   #4
JakeMS3's Avatar
Posts: 1,164   (View Stats)
Groaned at 7 Times in 5 Posts
Go check out the stratified website. I think they have an illustration of how to hook it all up.
2013 LSM w/tech
Cobb AP V3, CBE
CS Turbo tuned by PD
JBR FMIC Pipe Kit w/TR8
CP-E TIP/3.5" Intake
DM OCC/TMM
Forge V2 BPV
Bilstein B8 w/Swift springs
Wilwood 6 pot BBK
EBC RedStuff rear pads
Konig Hypergram 18x8.5"
 Old 10-04-2015, 05:48 PM   #5
tparker14's Avatar
Have you tried this setup?
 Old 10-04-2015, 05:50 PM   #6
That's what I'm going to do, I was just hoping someone with a grimmspeed ebcs could confirm.
Thanks!
 Old 10-04-2015, 05:54 PM   #7
tparker14's Avatar
They care both mac valves so they have the same setup. I used cobb instructions for my JBR install without issues as it is also a mac
 Old 10-05-2015, 05:47 AM   #8
TiGraySpeed6's Avatar
Posts: 3,981   (View Stats)
Basic configuration:
Port 1 – vent – connect to TIP/TIH
Port 2 – action – connect to WGA
Port 3 – source – connect to full pressure boost source
340hp / 371tq
 Old 10-05-2015, 05:54 AM   #9
anavrinIV's Avatar
Posts: 4,490   (View Stats)
Groans: 63
The S3 should have a boost tap on the turbo that goes to port 3 so you don't have to tee into the BPV port. The others connect as shown. I had a grimmspeed and hooked it up per everyone's instructions and it worked fine. If you hook it up wrong it can hold the wastegate closed full time...I did this as well and don't recommend it.
Blue Pu.
Grimmspeed EBCS? Need It? RedBliss MazdaSpeed 6 - Engine, Transmission & Driveline 5 07-28-2010 07:43 AM
GI Grimmspeed EBCS aviator79 MazdaSpeed 3 - Engine, Transmission & Driveline 181 03-04-2010 07:53 AM
Page generated in 0.27913 seconds with 25 queries
